10-26-2012, 12:39 PM | #1 |
Re: What Did You Do With Your Truck Today ?
Great looking truck!
Renegade |
10-26-2012, 01:28 PM | #2 |
x2 ^
10-26-2012, 02:48 PM | #3 |
Tossed some stainless 3/4 trim rings on it, unbolted the front seat and ordered a pleated seat cover and matching headliner. It seems to never stop!
10-26-2012, 08:40 PM | #4 |
The starter was making a horrible sound. Crawled underneath and found that my starter housing is cracked from the PO torquing it too tight. At least I know what that sound is now! Off to the parts store again...
10-26-2012, 10:54 PM | #5 |
watched the snow melt off of it...
10-27-2012, 02:27 AM | #6 |
Got the pitman arm, steering box & column removed. Still need to separate column from box, or source a 60s / 70s column to use. Not really sure how to separate column... hammer hasn't worked yet.
10-29-2012, 02:15 AM | #7 |
Masked and resprayed the interior.
. . Then painted the hub caps and emblems, tossed on some buffed/ground whites and drove it to the Drive Inn for a shake. Found an engine for my Burb, so the Apache is now for sale Posted via Mobile Device |
10-30-2012, 09:31 PM | #8 |
hey guys -
For any of you 55- 59 chevy guys who are still utilizing your lower side cowl vent - i have a great tip for ya - for the doors i was trying a bunch of different materials to replace the worn cracked rubber . After buying the ''so-called'' replacment foam stuff for these vents - 3 times ( they tear v v easily - pure junk ) i tried other stuff and it all did not work . what is ''the'' best stuff is a old car or truck inner tube - get a busted one -make a template and a shot of wd-40 and there ya go - seals great !!!!! hope this helps out anyone. i am a guessin that the 47 -54 - guys may find a use for that tube rubber also ' |
11-01-2012, 06:56 PM | #9 |
My rear fleetside bumper just showed up today. It will be the first time iv'e had one on the the truck. I'm so excited i'll probably sleep with it tonight.
Posted via Mobile Device Last edited by meter swinger; 11-01-2012 at 06:57 PM. Reason: added |
11-01-2012, 09:37 PM | #10 |
Looks good. Ordered it from brothers on friday and its already here. Now to find some brackets.
11-01-2012, 10:10 PM | #11 |
If I put my bumper on the kitchen table, I'd probably end up sleeping with it too (out on the lawn). I'm sure she'd eventually cool down and let me back in the house though, as long as I didn't try to sneak the bumper back in. Looks good Meter. Make sure you put lots of polish on it.
56 Chevy PU http://67-72chevytrucks.com/vboard/s...d.php?t=531955 Question: Know how to sell your truck for $50,000? Answer: Spend $100,000 building it. |
11-01-2012, 11:01 PM | #12 | |
11-02-2012, 12:21 AM | #13 | |
11-02-2012, 09:34 PM | #14 |
Here is what I did with my truck on the 31st.......
11-01-2012, 10:14 PM | #15 |
Wow! Bumper envy! I worked on my firewall and frame. More scrubbing to remove 50+ years of grease and yuck. Sprayed my new posies drop springs. Hope to be ready for paint in a few weeks. Ready to have my truck back.
11-01-2012, 11:30 PM | #16 |
Drove it.... :-) 180 mile round trip to buy a Camaro T-5 5 speed. I was really surprised that I got 17mpg!!! Just gotta find an s-10 tail housing now.
11-05-2012, 12:19 AM | #17 |
Wanted to get the rear speakers off the floor, so I cut the box down so that it would fit in the cab corners.
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
11-05-2012, 03:09 PM | #18 |
Still finetuning the windows, on hold until the channels get here. Made a support for my floor jack to hold the doors during hinge installation.
11-05-2012, 05:35 PM | #19 |
nice work
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
11-07-2012, 09:19 PM | #20 |
Finished up my new transmission cross member. and got a quart of rust bullet.
11-08-2012, 03:48 PM | #21 |
Pulled the seat in the Apache and tore it down to the springs, rebuilding the foam and installing a new fitted cover.
11-08-2012, 11:49 PM | #22 |
the brown truck brought my front control arm bushings
11-09-2012, 11:10 AM | #23 |
FINALLY got the Lokar parking brake the way I wanted it and got the boot to fit without interference from the mounting bolts. I also fabbed up a (I think) pretty sweet shifter for the overdrive unit so I won't have to use that ugly cable and big red knob under the dash.(US Gear V2, not Gearvendors) I'll get the shifter handle chromed to match the other two, but I think it turned out kinda neat. I wanted the E brake handle to stick up some cuz I think it gives a little bit of the "old truck" look.
11-09-2012, 05:58 PM | #24 |
Looking good!
Renegade |
11-09-2012, 11:53 PM | #25 |
Happy Days...got my wheel spacers so I can use the stock wheels with disc brakes. Now to get all the Halloween items that are drying on the truck off so I can install these shiny pieces of metal.
