Old 10-05-2011, 07:09 AM   #1
andrewmp6
Anyone seen these control arms yet
http://michiganmetalworks.com/store/...&product_id=78 Works with a dropmember says it will lay out 33.5 od tire.
Old 10-05-2011, 08:00 AM   #2
OJ1988
Just a car guy
OJ1988's Avatar
Re: Anyone seen these control arms yet
Oh, ah.
Very nice. and pricey!
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 10-05-2011, 08:02 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Originally Posted by OJ1988 View Post
Oh, ah.
Actually cheaper than alot of tubular a-arms.
Keith
Convert to disc brakes.
Old 10-05-2011, 08:11 AM   #4
andrewmp6
I have seen his s10 ones in person they are heavy and his special upper ball joint he calls a jeebus joint does out flex any ball joint i have seen.Ridetechs a arms are a grand kp links are over a grand so its not that pricey next to what is out there.
Old 10-05-2011, 10:06 AM   #5
OJ1988
Just a car guy
OJ1988's Avatar
What material is used?
1973 Vega Drag Car
1970 C20 tow rig
Old 10-05-2011, 11:03 AM   #6
aggie91
I'm just glad to be here!
aggie91's Avatar
Those are from Jeebus. He is a member on here. Looks cool.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 10-05-2011, 12:52 PM   #7
tubbedII
needs more $$$
tubbedII's Avatar
So, if they work with a DM, does that mean they won't with a stock x-mbr?
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 10-05-2011, 01:54 PM   #8
aggie91
aggie91's Avatar
The upper would but the lower uses a different cross shaft. The stock cross shaft bolts to stock crossmember with u-bolts. The PB member uses something different.
Karl
The LST Challenge:
Old 10-05-2011, 02:12 PM   #9
lolife99
lolife99's Avatar
Here's a complete listing of the Chevy a-arms available.
http://michiganmetalworks.com/store/...ory&path=60_65
Keith
Old 10-05-2011, 02:23 PM   #10
OJ1988
Just a car guy
OJ1988's Avatar
Any idea on materials?
I'm guessing these are for the frame dragger and not the corner carver?
1973 Vega Drag Car
1970 C20 tow rig
Old 10-05-2011, 02:32 PM   #11
tubbedII
needs more $$$
tubbedII's Avatar
Makes sense why the pic doesn't have one on the lower
1970 2wd Blazer
Old 10-05-2011, 10:23 PM   #12
MADMIKE
They look neat but I would worry about those things folding up. Is there some form of triangulation I'm not seeing?
-Michael
MADMIKE is offline   Reply With Quote
Old 10-05-2011, 10:58 PM   #13
funkytechmonkey
funkytechmonkey's Avatar
The black ones look bedazzled.
Never wrenched a day in my life and now...
Im doing a frame off restoration on a 1968 C10
with a Porterbuilt Dropmember, Acuair E-Level kit,
Boyd Welds Gas tank and mild c-notch.
Click here to view my build
funkytechmonkey is offline   Reply With Quote
Old 10-06-2011, 12:33 AM   #14
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
I could be wrong, and I'm sure I am, but they look like they use a 1/2" to 3/4" plate. If you can fold those up, you're beating the crap out of them.
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline   Reply With Quote
Old 10-06-2011, 12:51 AM   #15
andrewmp6
These are steel plate your frame would bend before this will.
Old 10-06-2011, 05:08 AM   #16
MADMIKE
HAH! I was wondering if that was a chunk of plate steel. Unsprung weight.. whats that?
-Michael
Old 10-06-2011, 08:41 AM   #17
Shane
Shane's Avatar
you would be surprised how easy it is to bend flat 1/2" steel plate ...
Shane is offline   Reply With Quote
Old 10-06-2011, 04:10 PM   #18
dv8customs
dv8customs's Avatar
About 32 tons/foot on a press break...
Sounds like a lot to me
dv8customs is offline   Reply With Quote
Old 10-06-2011, 04:31 PM   #19
Shane
Shane's Avatar
those are pretty bold numbers considering you don't know the tensile strength or the type of steel used.
p.s it's a press brake, not break
Old 10-06-2011, 05:21 PM   #20
dv8customs
dv8customs's Avatar
Please excuse my spelling error.
That was just a general value based on mild steel with a 60,000 psi tensile strength. The uppers he produces are 1/2" steel plate which is more than adequate as the upper arms are locating devices for the spindle and most all of the forces are tension and compression type forces. I believe his lowers are made out of 3/4" plate, and while I do not know the exact material he is using I would still commit to saying that they are adequate for the job. It will take a considerable amount of force to bend a 3/4" plate that is roughly 10" wide and 18" long.
Old 10-06-2011, 05:46 PM   #21
Shane
Shane's Avatar
even at 60,000 psi tensile strength, 1/2" plate can be bent with as little as 10 tons under the right conditions (angle & width of bend, etc).
10 tons is really NOT a lot of force when it comes to the dynamics encountered in a suspension system with 3,500 lbs. plus riding on it. I'm not saying they aren't quality components, but if their design is truly "better" then I think the OEM's (not to mention the applications in motorsports) would have been making a-arms out of flat plate long before now due to the big decrease in costs to manufacture and shortened lead-times.
No flame meant, just stating the obvious from my perspective: 1/2" flat plate with NO supporting gussets? No thanks, my safety along with my passengers and everyone else on the road is not worth the chance.
Old 10-06-2011, 06:33 PM   #22
dv8customs
dv8customs's Avatar
I will disagree, but now the OP has an opinion from both sides with which to make his decision.
Flat plate arms are not a new idea and I believe have been used in the off road market for some time now.
Old 10-06-2011, 08:56 PM   #23
MADMIKE
Offroad as in rock crawling or Baja 1000?
Even if the steel was stiff enough to resist bending at the airbag mount, I highly doubt those two little bushing arms can resist any bending. I would be concerned about cracks forming at the welds and on those arms. Steel is a strong material, and you can design an arm to be lightweight and have infinite strength for a given application, but these arms look to have a finite lifespan on a heavy truck. I wouldn't want to do a chuckhole test with those arms.
-Michael
Old 10-06-2011, 09:27 PM   #24
dv8customs
dv8customs's Avatar
With regards to the offroad aspect I don't know first hand. I have seen it discussed previously. I debated about even mentioning it and probably shouldn't have.
At any rate, I stand by my opinion that these arms would be more than adequate on a day to day basis. There is always a scenario where something will fail and that can't always be predicted.
I plan to run these same arms on my truck and have no concerns in doing so.
Old 10-06-2011, 09:40 PM   #25
scooterskoolkustoms
scooterskoolkustoms's Avatar
I like the flat plate my 2 cents I was going to get mine from this place http://www.dallashotrodparts.com/
big old burb in primer.lot of work to do.
scooterskoolkustoms is offline   Reply With Quote
