Old 10-05-2011, 06:23 PM   #1
70k52wd
Blaze-Air
70k52wd's Avatar
Optima battery
Just wondering if an optima batt fits the factory tray using the factory hold down clamp. I need a really good batt for BIG stereo and air-pod, a/c and such.
70k52wd is offline   Reply With Quote
Old 10-05-2011, 07:52 PM   #2
jaros44sr
jaros44sr's Avatar
Re: Optima battery
Fits like a glove to a hand, just put one in mine last week
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-05-2011, 09:18 PM   #3
70k52wd
Blaze-Air
70k52wd's Avatar
Re: Optima battery
Thanks jaros. What group size, bottom shape did you get?
Old 10-05-2011, 10:58 PM   #4
jaros44sr
jaros44sr's Avatar
Re: Optima battery
Ill check it out tomorrow and give you demensions...need pics?
SAFETY FIRST
AS usual, off topic
Jim
Old 10-06-2011, 08:23 AM   #5
70k52wd
Blaze-Air
70k52wd's Avatar
Re: Optima battery
Sure, we love pics around here.
I'm wanting to order a batt online, so the size/fit is crucial.
Thanks.
Old 10-06-2011, 09:59 AM   #6
Burt4x4
Burt4x4's Avatar
Re: Optima battery
I use the Redtop 800cca
The battery resembles a six pack of cans..well at the bottom clamp on the tray I ground a U shape in the center of the clamp inorder to seat the clamp further in suronding the center 'can' for a better clamp..otherwise the clamp is just barley pinching the bottom of the batt inplace.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 10-06-2011, 10:07 AM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Optima battery
I had the 34/78 size in the blazer.
http://shop.optimabatteries.com/prod...59.0.0.0?pp=8&
Do some research on them.
After mine failed in less than 2 years,... I found out they recommend no more than a 2amp charge.
No 15 amp, 30 amp, or high amp fast chargers should touch these batteries.
Also they recommend a "Battery Tender" on them at all times, if you don't drive it everyday.
My buddies that have them in their daily drivers love them and have great success.
Mine failed even with storing it disconnected.
I went back to an AC Delco battery in the blazer.
I didn't know much about them until I started having problems.
Keith
Convert to disc brakes.
Old 10-06-2011, 11:10 AM   #8
jaros44sr
jaros44sr's Avatar
Re: Optima battery
Battery does seat in the back notch, and like Burt said you could cut out the front clamp. Mine isnt centered, but will be, after i cut the clamp
Good info. on the charger, hope i didnt cook it...next purchase,battery tender
SAFETY FIRST
AS usual, off topic
Jim
Old 10-06-2011, 07:25 PM   #9
70k52wd
Blaze-Air
70k52wd's Avatar
Re: Optima battery
Thanks guys for all the feed back and pics.
I do have a 2 amp charger and batt tender, I even pull the batt for long term parking.
I can mod the hold down easy enough. I'm just thinking about having such a colorful batt under the hood. I'm old, batts should be black and square.
I'm going to see what else is out there just to see all my options before I decide.
Old 10-06-2011, 07:34 PM   #10
jaros44sr
jaros44sr's Avatar
Re: Optima battery
They still make tar tops....if original is more your style, not that tar tops are original to 72s.
But, I believe I have seen reproductions of our era
Lol, I agree with you on black, but now that I just went past 60, my view of the way things are have changed.....function over form. I like it because, when I charge it, battery acid doesnt splash all over my core support, as did my diehard
Hey, I think someone resized my pics for me
SAFETY FIRST
AS usual, off topic
Jim
Old 10-06-2011, 09:07 PM   #11
lolife99
lolife99's Avatar
Re: Optima battery
My 34/78 series Optima battery bolted in with no modifications.
Keith
Old 10-06-2011, 09:18 PM   #12
msgross
msgross's Avatar
Re: Optima battery
After hearing tons of horror stories about these I spent $100 on a trusty Megatron from interstate...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 10-06-2011, 11:56 PM   #13
Firebirdjones
Re: Optima battery
I've never been happy with my redtop optima. The 6 pack shape didn't fit the tray correctly. It came with these cheap plastic clips that snapped on the bottom to form around the round barrels of the battery and make the bottom square, but the factory battery hold down still wouldn't hold the battery correctly. Any bouncing around and that thing was shifting all over the place.
I ended up making a bar accross the top with J-bolts to hold it in temporarily in fear of a battery fire.
I also don't like how close together the battery side terminals are.
I have had it for 2 years now without any starting issues however. I only bought it because I was informed of how tolerant they are from bouncing around off road. But if I had to do it all over again I'd go back to my AC Delco's for a more correct appearance and a proper fit.
As a matter of fact, I'd trade this thing in a heartbeat for an AC Delco. I hate looking at that optima, it's just ugly I'm old fassioned too and actually run the factory tar top style batteries in some of my other classics.
Firebirdjones is offline   Reply With Quote
Old 10-07-2011, 12:37 AM   #14
old man jimmy
Re: Optima battery
Here's a bit of battery trivia for you younger people. Back in the 70's Penny's came out with a lifetime battery, good for as long as you own your car. Guess what's in mine? After Penny's auto dept. went out, they contracted with firestone to replace them. Haven't paid for a battery since the mid 70's. So I have an Exide in mine. actually I have them in 2 of my rigs.
old man jimmy is offline   Reply With Quote
Old 10-07-2011, 10:17 AM   #15
SamMargritz00
SamMargritz00's Avatar
Re: Optima battery
I have the yellow top D34/78 in my blazer and i love it. the factory battery clamp holds it into place. I used the car selecter on the Optima Battery website and thats what came up for my 72. I have 1/0 gauge wire running clear to the back to run 1500 watts rms for my two kicker l7's, another amp for all my speakers, and a vintage air and i have had no problems at all. My headlights dont even dim at all when the bass hits.
SamMargritz00 is offline   Reply With Quote
Old 10-07-2011, 10:25 AM   #16
OJ1988
Just a car guy
OJ1988's Avatar
Re: Optima battery
I had a red top in my camaro and a yellow top in the 55. Both failed due to cars sitting even with battery disconnected.
I only trickle charged them as well.
I am going back to 'regular' type ones as well.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 10-07-2011, 10:34 AM   #17
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: Optima battery
Top post of my friends red top broke off so its now junk
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 10-07-2011, 10:41 AM   #18
jaros44sr
jaros44sr's Avatar
Re: Optima battery
DAM, dont be calling my battery ugly beauty is in the eyes of the beholder
I just wanted to stop battery acid from spueing all over my core support and firewall, I just put a new one in, and dont feel like changing it anytime soon
And, yes I remember JCPennies, still have my dads 3/8 drive drill. Think it was a Penncrest
Heres function over form
SAFETY FIRST
AS usual, off topic
Jim
Old 10-07-2011, 11:04 AM   #19
jaros44sr
jaros44sr's Avatar
Re: Optima battery
Did they not stand behind, and give him credit
SAFETY FIRST
AS usual, off topic
Jim
Old 10-07-2011, 12:47 PM   #20
Firebirdjones
Re: Optima battery
I meant that in the nicest way possible
I don't mean to come off harsh on the optima's appearance. I've just been running correct AC delco batteries in the classic cars for 20+ years, and even a correct autolite in the lone ford here.
So when I pop the hood on the blazer, that bright red optima just jumps out at me
At some point I'll go back to a modern version of the AC delco in there.
Old 10-07-2011, 12:54 PM   #21
Vintage Windmills
Vintage 4x4s
Re: Optima battery
I don't think he knew about the warranty or thought it would apply since it came in a vehicle he bought.
Personally, I've had good luck with Die hards from Sears.
Old 10-07-2011, 02:25 PM   #22
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Re: Optima battery
The only negative; Is when they sit and they drain. They will not hold a charge very well after that. I have a yellow top in my Blazer. Bought it when I had the money, sat it on the shelf for a year. Never came back to life - in the right way. It would lose its charge after a few days of sitting and running in the vehicle-extensivley. Looking for a replacement, maybe a Odyssey AGM Battery.
BTW, I had a red top that lasted 4 years without a problem, took it from the store, installed, never a problem.
Morale: don't let them die...
As for fitment: not a problem. Gotta play with the Optima plastic inserts for them to fit under the metal holdown clamp.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 10-07-2011, 02:29 PM   #23
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: Optima battery
im going to use a solar battery charger ,
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 10-07-2011, 04:33 PM   #24
70k52wd
Blaze-Air
70k52wd's Avatar
Re: Optima battery
Looks like with all things in life they're are some that do and some that don't.
I think I'm going to go Delco, I've kept under the hood extremly factory. I like the power of the optima, but I need form over function.
I'll power the air-pod with it's own batt hidden in the back. That's what started all this, the air-pod drained my batt, although the batt I knew was old and not holding a charge.
Old 10-08-2011, 07:03 PM   #25
Firebirdjones
Re: Optima battery
Yep, did that for about 3 hours and still wasn't happy with the fit. I could still grab it with my hands and move it enough to wiggle it loose, so I didn't trust that cheesy setup. I threw them in the trash and just made a bar accross the top with U-bolts.
When a battery comes with plastic snap on pieces to fit multiple applications I start questioning it's build quality, I thought I had a battery made with lego's
