Old 10-06-2011, 01:56 PM   #1
FrankieD
FrankieD's Avatar
70 C/10 from Cali to Illinois
I have been kicking around doing a build thread on mine so here it goes. I picked her up in February for $2400 and put her to bed till April when I could kick the wife out of the garage. She came from Modesto Cal. from what I understand the guy that did the work on the truck died and his son went out and brought mine and a 71 4X4 back. The truck had been painted blue and white the original color was gold. All it needed to put it on the road was tires, interior, front and rear glass then I got on this site and my mind started working.
So I went and bought a 72 for parts for $900. I took the glass and put it in mine then I wanted the 5 lug axles and disk brakes and it had a 350 which I thought would be a good swap for the 307.
Here are some pix of when I was putting her in the barn for the winter
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 10-06-2011, 02:04 PM   #2
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 70 C/10 from Cali to Illinois
Man, that's a great truck for $2400! It sounds like you're well on your way with it too.
Ryan
1969 Chevy milk truck
Old 10-06-2011, 02:23 PM   #3
VA72C10
VA72C10
VA72C10's Avatar
looks great!
Old 10-06-2011, 02:40 PM   #4
FrankieD
FrankieD's Avatar
This was the donor truck, it was supposed to have a Professionally rebuilt engine but it had a bad oil leak from the timing cover so when we got it to my cousins house and pulled the engine apart we found that the crank was scored like it was put together in a sand pile and the front cam bearing had spun so that went to the machine shop to be fixed $$$. Then I striped every thing I could off and took it to the scrap yard. Sold a lot of parts to members here. Thanks guys
Old 10-06-2011, 02:43 PM   #5
Dieselwrencher
That would be fun to run for a day or so!
Ryan
Old 10-06-2011, 02:58 PM   #6
FrankieD
FrankieD's Avatar
Yea the guy was so good in it he took a tire off a rim I was impressed. The scrap yard is only a 1/4 mile from my house.
Old 10-06-2011, 03:05 PM   #7
FrankieD
FrankieD's Avatar
I brought the 70 to my cousin’s poll barn and started disassembling it to pull the engine and cross member. She has a granny 4spd so the removable hump was nice.
Old 10-06-2011, 04:00 PM   #8
FrankieD
FrankieD's Avatar
Found some intersting info on the diffrences from the 70 to 72.
1. the window cranks are 3/8" longer because of the plastic door panels.
2. the 5 lug axel's can be used in the 6 lug housing the axel's are the same length, to swap you need to change the brakes and drums.
3.The cross member can be swaped in by just enlarging the top front bolt holes all the other line up.
4. Inner and outer tie rod ends are different size
The P/S pump pully dosen't line up with the 72 balancer using the 70 pully, working on this one but the fan and water pump line up
Old 10-06-2011, 09:16 PM   #9
Dieselwrencher
And also, I'm pretty sure you could have left the original cross member in there. All you needed to change was the spindles out for the 5 bolt conversion I believe.
Ryan
Old 10-07-2011, 08:02 AM   #10
FrankieD
FrankieD's Avatar
The ball joints are different they go in the 2 year increments 67/68 - 69/70 - 71/72 then 73 up are the same for all the 2wd shoe box model's. The 73-87 will also fit with the same modification on the cross member. The 73-87 are better because they have rubber bushings on the A-Frames. The main reason I didn't do just the spindles is that I had the 72 cross member and it was less work every thing went in one piece. Also the inner and outer tie rod ends are diffrent size.
Old 10-07-2011, 11:50 AM   #11
FrankieD
FrankieD's Avatar
I went to Wisconsin to look at a 71 for $1500 it was about a 3hr ride and it turned out to be a rust bucket so when I saw this one I jumped on it. The only rust I found was on the air intake for the vent it was full of leaves so I cut that out and patched it back in and painted it with POR 15.
I have the Cali Title and all the Cali regestation from 1970 till it was parked I think it was in 88 and a detailed list of work and $ that was put in it. The PO spent $600 for the paint suplies and $400 getting the 307 running
Old 10-07-2011, 02:30 PM   #12
Dieselwrencher
Cool deal!
Ryan
Old 10-09-2011, 10:36 PM   #13
FrankieD
FrankieD's Avatar
Took the the cross member to the car wash and made a mess but it cleaned up real nice. I used some ZEP Industrial Cleaner it is corrosive but it melts the 40yr old grease off of every thing . I sprayer everything with POR 15 it looks pretty good. I also cut the trans cross brace out so the reinstall of the engine and trans would be easier. I want it to look as clean as possable with out doing a frame off
Old 10-11-2011, 08:11 AM   #14
FrankieD
FrankieD's Avatar
Got the cross member in and brakes hooked up it has brand new calipers and rotors on it, Put new rubber brake lines on and new inner and outer tie rod ends. Bought a new booster and Master and new rear brakes & wheel cylinders and had the drums turned. Put new wheel seals in and installed the 5 lug axels.
The square washer is where I had to enlarge the bolt hole so it would line up
Old 10-11-2011, 11:46 AM   #15
Dieselwrencher
Nice progress! It's looking great!
Ryan
Old 10-11-2011, 01:02 PM   #16
FrankieD
FrankieD's Avatar
Looks like you have a few projects going. I was thinking about a dually 4X4 before this one but couldn't find one that wasn't rotten.
Old 10-11-2011, 02:09 PM   #17
FrankieD
FrankieD's Avatar
I loaded it up on the trailer and brought it back home to pressure wash the under side then sprayed it with POR 15, I top coated it with Rustolem Semi Gloss Black I think it came out pretty good.
Before:
Getting ready to paint:
Done:
Old 10-11-2011, 05:59 PM   #18
Dieselwrencher
Man, that looks great! Nice work.
Ryan
Old 10-11-2011, 06:00 PM   #19
Dieselwrencher
Yes I do. I'm trying to liquidate some right now too. I have thought about making my Longhorn a DRW too, but I want it to some what ride half way decent. That'll be hard enough with the hefty springs it has.
Ryan
Old 10-11-2011, 06:45 PM   #20
VA72C10
VA72C10
VA72C10's Avatar
Undercarriage came out awesome!
Old 10-11-2011, 08:14 PM   #21
hotrodchevy1999
Hotrodchevy
hotrodchevy1999's Avatar
Looking good
2017 1500 CREW CAB GMC
1997 C1500 Chevy
1971 CHEVY CHEVELLE SS 402BB :
1971 CHEVY C10 Stepside Project 71 cluncker http://67-72chevytrucks.com/vboard/s...ferrerid=89816
My Build Second Chance Suburban (SCS)http://67-72chevytrucks.com/vboard/s...d.php?t=424650
hotrodchevy1999 is offline   Reply With Quote
Old 10-12-2011, 08:35 AM   #22
FrankieD
FrankieD's Avatar
Thanks guys! I'm trying to figure out how some of these guy's do these big mods so quick but it could be just me being old and slow and maybe sometimes to much beer.
She had a little rot in the air in take for the vent so I cut that out sprayed POR 15 inside it before patching it in then sanded and painted the fire wall to cover the rattle can paint job the PO did. For doing it outside I got lucky and it came out pretty good it was fairly warm so the paint dries fairly quick
Old 10-12-2011, 12:44 PM   #23
VA72C10
VA72C10
VA72C10's Avatar
Firewall looks nice!
Old 10-12-2011, 02:21 PM   #24
Dieselwrencher
Great work! You're cooking with bacon grease now!
Ryan
Old 10-12-2011, 02:54 PM   #25
FrankieD
FrankieD's Avatar
T!HANKS
grease now!
I've been trying to keep the grease off
