Old 11-07-2011, 04:27 AM   #1
slb1985
slb1985's Avatar
fiberglass over dashpad started...
So as with every other squarebody I have seen my dash pad has seen better days and I am to cheap to spend the money on a new one and I don't think the covers look good to me. Well I took a leap of faith and dove into covering mine after reading a couplre post on here and much more on other sites. I have never attempted to do anything with this stuff but I did it today and I think the rough product looks good I did take pictures and will post what I have done tomorrow after I try and get some filler in it. Was a little chilly today so just around 60 by the great lakes, wanted to make sure it was fully cured before I did anything else.
If anyone has some tips on dos or don'ts from the fill stage to paint feel free to let me know .
1987 R10 Silverado - Rusty But trusty Daily
1984 C10 Custom Deluxe - Newest Project
slb1985 is offline   Reply With Quote
Old 11-07-2011, 11:05 AM   #2
Moostifer
a fool with no money
Moostifer's Avatar
Re: fiberglass over dashpad started...
as with anything being painted... It's all in the prep work.
when you think your done with the prep, walk away from it for a few hours then come back and give it another "feel". Or have a couple of buddies check it over also.
what are your plans for the speaker holes?
Basicly stock 83 SWB with a few Bolt-ons
before, during and still during
http://photobucket.com/albums/y251/moostifer/truck/
http://photobucket.com/albums/y251/moostifer/motor/
Moostifer is offline   Reply With Quote
Old 11-07-2011, 06:24 PM   #3
slb1985
slb1985's Avatar
i built a center console to go between to go between the seat and the dashboard. that thing is gonna hold 2 6.5s the head unit and has holes for 2 cups. if i can make the dash look good as a final product it to will get fiberglassed and painted to match.
Old 11-07-2011, 06:39 PM   #4
slb1985
slb1985's Avatar
Wink Re: fiberglass over dashpad started...
so here are is the progress so far... this is what i started with took it out to see what was wrong with my defroster and snowballed to its own project
Old 11-07-2011, 06:44 PM   #5
slb1985
slb1985's Avatar
i tried to use duct tape for the backing to hold in some great stuff spray foam to fill the voids from the spreaker holes and the cracks after knocking down the high spots and loose spots
Old 11-07-2011, 06:50 PM   #6
slb1985
slb1985's Avatar
i sprayed in the foam in an attemp to fill in the holes but once it cured and it didnt do anything for the cracks and to get it flush with the dash i had to use a hot wire strung between 2 dowel rodes to cut it off. it didnt turn out the way i had invisioned but it did do the job i needed. i am sure there are better products to what i really wanted but im impatient and did this on a whim.
Old 11-07-2011, 06:54 PM   #7
slb1985
slb1985's Avatar
still wet in these pictures i went ahead and covered all of the holes with plans to cut out the vents and then vin there are a few air bubbles in it but i was going for cosmetics not strength so i hope that it dosent affect it. the hardest part i found on this stage was gettingit to sit flush around the gauges and stay flat at out side curve in middle.
Old 11-07-2011, 07:00 PM   #8
john_p
just pulled my dash today, 73, and it has that same look so i will be watching your progress.. i've bought padding and some vinyl and am going to try that route.. if it turns out i will post a picture.. do keep us posted..
john_p is offline   Reply With Quote
Old 11-07-2011, 08:59 PM   #9
rocking chevy
rocking chevy's Avatar
looks good so far.
rocking chevy is offline   Reply With Quote
Old 11-07-2011, 09:30 PM   #10
Da88burban
GM's 4 Life
Da88burban's Avatar
Lookin good.You should add some Kind of custom touch to it while your at it. I am in the process of fiberglassing a Junkyard dash for my Safari and am planning to shave it clean and add a 7" Monitor. But anyway I was wondering what are you going to do for the defrosting vents?
Jack
'54 Chevy 3100 "Just a Mess"
'74 Chevy Super 10 468BB "One Fast Rust Bucket"
'86 Pontiac Fiero GT
'88 Chevy burb "Tha Big Turd"
'93 GMC Safari "Bone Crusher"
.................____________
.............../______l___|___\____
;,;,;,;,;,;,;|__(O)_| __l___l__(O) |
Da88burban is offline   Reply With Quote
Old 11-08-2011, 04:34 AM   #11
slb1985
slb1985's Avatar
I am just gonna cut out the holes for them and the vin plate and put the factory grill back in it if I can
Old 11-08-2011, 05:39 PM   #12
dv8customs
dv8customs's Avatar
Looks like a good start. Chopped matt would have worked better for you around the gauges. It would have laid down better.
dv8customs is offline   Reply With Quote
Old 11-08-2011, 08:26 PM   #13
broey
Square
broey's Avatar
lookin good...
I left the defrost vents smooth on mine, came out a lot cleaner
Squarebody Syndicate
broey is offline   Reply With Quote
Old 11-08-2011, 10:16 PM   #14
bucannon
Salty Sailor
bucannon's Avatar
ive been thinking about doing something like this but i have never done any fiberglass work before... i hope this turns out well because i might have to try it.
if not ill do what broey did and use cloth over bondo, but i like having defrost haha
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 11-08-2011, 10:21 PM   #15
SeanPaintsFlames
SeanPaintsFlames's Avatar
I made a dash from a junkyard the same way speaker enclosures are made- with fleece stretched and stapled around the perimeter, then glass resin brushed into the fleece. It makes that instrument cluster area super easy. Once I finished it I realized it didn't fit well, so I sold it...
My 68 cougar restomod build:HERE
SeanPaintsFlames is offline   Reply With Quote
Old 11-09-2011, 12:43 AM   #16
slb1985
slb1985's Avatar
That smooth dash without the vents does look real nice but I need to have the defrost i went last year without it and if I can avoid it I won't this year
Old 04-15-2012, 02:13 PM   #17
slb1985
slb1985's Avatar
well the time of year has came again that its warm enough for me to try and finish this thing rode around all fall and winter with no pad looked horrible but anyway back on topic i forgot to take pics before i trimmed the glass but i got a craftsman multi tool for cristmas and that was the easiest way i found not having a dremmel tool. As for the gauge area not laying down very well after i trimmed it and test fit before adding filler it dosent seem like its going to be a problem. might want to add this is also my first time using any kind of body filler so its been a process. i ran out of bondo before i could get to the front but will be getting some more soon and will update once its finished enough i can move on to the next step. here it is so far
Old 04-15-2012, 02:17 PM   #18
slb1985
slb1985's Avatar
oh yeah, i changed my mind on the defrost vents i found some mesh stuff at work im going to kind inbed in the bondo if i can instead of the stock ones i think it will clean it up a little then i can carry that mesh to the floor console too kinda tie it in...
Old 04-15-2012, 02:41 PM   #19
slb1985
slb1985's Avatar
Couole questions about the sanding part for bondo how do I keep it flat and not wavy how will i know when its level enough to finish and lastly how much should I be sanding off just the high spots or most of the laid filler and leave it in the low spots...
Old 04-15-2012, 02:50 PM   #20
dv8customs
dv8customs's Avatar
First tip is to not by Bondo Brand filler. That stuff dries hard as a rock. I recommend Rage Gold.
For sanding get yourself a big paint stick and wrap the sand paper around it. That will keep everything flat.
Old 04-16-2012, 03:31 PM   #21
INSIDIOUS '86
INSIDIOUS '86's Avatar
You will prob end up sanding 80% off. Use a longer block sander on the flats and a smaller one on the small areas
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 04-16-2012, 05:41 PM   #22
RandyP
Getting Old; Going Broke
RandyP's Avatar
Spray a guide coat of black on before blocking. It will show you low spots and scratches you might miss otherwise. Do not use enamel for guide coat, it will gum up the sand paper.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 04-16-2012, 05:54 PM   #23
rs72z
rs72z's Avatar
Do your self a favor, when you are wiping the filler try and wipe it as smooth as possible. It will save you a lot of sanding time. It's not so critical on the the first wipe but after you get it close any additional filler needs to be pretty smooth.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 04-25-2014, 07:20 AM   #24
monte0185
monte0185's Avatar
Did you ever finish this? Would love to see what it looks like.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 04-25-2014, 08:06 PM   #25
slb1985
slb1985's Avatar
Yeah I kind of finished it ... It didn't turn out as nice as I seen in my head . It looks fine no more cracks but the are some spots I need to touch up . It's in the truck working as the dash I'll try ans get pics when i can. It will probably look better in the pictures ... Forewarning
