66 GMC 4x4 Sub. Just got it!
First off, Im new here. Thanks for havin' me. Im new to the 60-66 Chevy truck/burbs. I have had 69 3/4 ton truck, 72 4x4 blazer, my daily drive is a 76 4x4 on 35s. This is my newest addition. Any suggestions will be appreciated.
Re: 66 GMC 4x4 Sub. Just got it!
Sharp! Oh to live on a state not infected with rust maggots.
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Nice truck, should make you proud. Post some interior and engine compartment pics.
Some Questions for Y'all,
-Why does the rear license plate hinge like it does? -What is a good tire size in stock susp.? 33s? -Switching out the closed knuckle dana to an open, what will be the issues? -Changing out the manual steering box to power? |
License plate hinges for when you when you have the tailgate lowered while driving with a load that extends further than the rear floor.
If you go to a taller tire you can purchase new larger diameter studs to help prevent the original studs from snapping. I used Wagner BD61186. From 7/16" stud original to 1/2". Last edited by aerotruk63; 12-01-2011 at 08:00 PM. |
I think that it hinges that way so that it is visible if driving with the tailgate down. I have run 33"x12 1/2x 15 for years , but think that I will go to a narrower tire next. wide tires cause to much stress on the frame around the steering box. narrower tires-easier to turn.
changing out to an open frt axle. drag link end will be your biggest problem unless you put in the newer p/s box. then everything just bolts in. I would just buy some new u-bolts is all if you buy yourself a 73-87 1/2t p/u or 73-91 suburban 4 x 4 donor you will get everything that you need. you have to relocate the rear spring perches about 3/4" on either side(axle) to install. frt drops right in. then you have the p/s and p/b setup. I do have what you need as I have an 84 roller here but to far away you can get the p/s box adaptor plate from capt.fab here on the board ron |
#9 | |
If you take requests, I'd like to see the rear seat backs. We are trying to collect information on Suburban rear seats. Norm
Link to Suburban Seat Thread : http://67-72chevytrucks.com/vboard/s...d.php?t=493957 Chevy's have a reputation for snapping wheel studs when taller/ wider tires are used. |
Norm; mine ran for years on 36x15x15 when I first got. no stud problems
ron |
#12 | |
My '76 has the frame kit from ord. both the bolt on and weld on. seems like i better do the same here before i have a problem at the steering box/frame connection. |
You got it Norm. What part of the seat you wanna see? just the back in general?
Yes please, to see if the pipe frame is exposed and the seat back is clad in vinyl or has a steel ribbed back.
Ron, I ran a 39" tire on 6 lugs, on mine, and snapped the front studs on the drivers side. I'm not insisting, simply recommending. If he changes out his diff's there might not be a problem. Last edited by aerotruk63; 12-01-2011 at 08:12 PM. |
#15 |
Enjoy your truck
Very nice truck - and it has an I.B.E.W. decal on the glovebox as well!
Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
#16 |
#17 |
#18 |
What a pretty smiling face!
So yours is the third truck Ive seen with the vinyl back and tube frame exposed. Thank You for doing that. Norm |
#19 |
#20 | |
ron |
#21 | |
#22 |
Ron, I took math in school as well, but thank you for pointing that out. What would you like to argue about now? lol
#23 |
#24 |
Have your steering box holes gone oval or is your frame showing any cracks?
#25 |
sell this beautiful rig to me i have a spare dana 60 an 14 bolt an some 36's an ls begin to go in it !!!!!!! I love it !!!! great score
