12-07-2011, 10:22 PM | #1 |
Parting out a 1972 Chevy Cheyenne C10 ***Parts list added 12-17***
*************Parts list added in post 59*************************
I have a 1972 Chevy Cheyenne 10 that is rough but I figure there are a few parts that need to be saved before the truck is disposed of. It was originally a v8 automatic but engine and transmission are missing. I am parting out the entire truck but I do have some parts already sold locally. I am planning on disassembling this truck Saturday December 10th. Post to the tread with interest and I will check and get pictures as soon as I can. I will need to remove most parts before the shipping charges can be figured. I accept PayPal or Bank Money Orders. Items that are already sold locally: Power brake booster, brackets, push rod, m/c and prop. valve front cross member, suspension and brakes rear differential power steering box and power steering pump Items I see that are worth saving: ******Parts list***** added 12-17**** 1. Shifter linkage & Frame Pivot-- missing transmission tab $20.00 plus shipping 2. Grille brace- rusty-- Free plus shipping 3. Hood latch-- $15.00 plus shipping 4. Hood pin and latch plate (attaches to hood)-- $6.00 plus shipping 5. Small block engine stands-- SOLD 6. Interm. steering shaft-- $10.00 plus shipping 7. Evap. Canister bracket-- $5.00 plus shipping 8. Flange for exh. pipe against exh. manifold-- $5.00 pair plus shipping 9. Washer bottle bracket-- $5.00 plus shipping 10. Washer Jug-- FREE plus shipping 11. Core support to fender brace-- rusty but solid-- Free plus shipping 12. Exh. bracket that rivets to the frame by transmission crossmember--$10.00 plus shipping 13. Tailgate support links-- SOLD 14. Tailgate pivots-- SOLD 15. Heater hose clip/ bracket-- $2.00 plus shipping 16. Center bumper brackets-- $5.00 pair plus shipping 17. Battery hold down bracket-- $2.00 plus shipping 18. Steering column, automatic-- $40.00 plus shipping 19. Steering column mount-- under hood with clamp-- $10.00 plus shipping 20. Steering column mount-- strap attaches to brake pedal bracket-- $6.00 plus shipping 21. Steering wheel (cracked) with horn button and horn parts-- SOLD Locally 22. Steering column trim (goes up to cluster)-- $6.00 plus shipping 23. Throttle cable bracket-- $5.00 plus shipping 24. Carrier bearing bracket-- rivets to the trailing arm crossmember-- $15.00 plus shipping 25. Misc. parking brake cable items including center cable-- SOLD 26. Door panels and armrest wood grain worn, extra holes drilled, chrome trim good-- $30.00 plus shipping 27. Gas tank, small spot that looks like possible rust below strainer-- SOLD 28. Rear step bumper-- SOLD 29. Tail light harness, See issues pointed out in post 138-- $15.00 Shipped 30. Harness from firewall to taillight harness-- $10.00 plus shipping 31. Headlight harness-- $18.00 plus shipping 32. Dash harness, fuse box looks ok, gauge cluster, non-a/c and no cig. ligher-- $20.00 plus shipping 33. Dome light-- SOLD 34. Fuel gauge wire, from tank to fuse box-- $5.00 plus shipping 35. Fuel lines that hook to the sending unit-- $5.00 plus shipping 36. Evap. lines-- $5.00 plus shipping 37. Sunvisors, sticking is loose--$15.00 plus shipping 38. Sunvisor clips-- $5.00 pair plus shipping 39. Dash cluster w/ gauges, no tach-- SOLD 40. Headlight and washer knob-- $5.00 plus shipping -- Washer Knob- SOLD 41. Glove box lid-- $20.00 plus shipping 42. Glove box latch catch (attaches to dash)-- $2.00 plus shipping 43. Reverse light housing, right side-- $5.00 plus shipping 44. Reverse lense-- SOLD 45. Taillight lense-- SOLD 46. Taillight housing-- $10.00 pair plus shipping 47. Cheyenne fender emblems-- $25.00 pair plus shipping 48. 8/350 emblems (frt. fender)-- $15.00 pair plus shipping 49. Headlight bezel-- $20.00 pair plus shipping 50. Left outside door handle-- $6.00 plus shipping 51. Jack tool hold down items-- $5.00 plus shipping 52. Speaker bracket-- SOLD 53. Door lock lever and retainer-- $5.00 plus shipping 54. Brace under steering column (flat panel)-- $5.00 plus shipping 55. Door handle and window crank (inside)-- SOLD 56. Automatic brake pedal-- $35.00 plus shipping 57. Heater controls (face rivets are a little loose, levers are good and move)--SOLD 58. Inside heater box with cables-- $35.00 plus shipping 59. Outside heater box-- rechecked and found a rusted hole in the metal part 60. Cowl panel, extra holes-- FREE NO shipping 61. Driveshaft-- $20.00 NO shipping 62. Cig. lighter delete-- SOLD 63. Roof panel (cut at the bottom of the a pillar and acrosss the rear below the double panel)-- $75.00 NO shipping Let me know what else you are interested in and I can inspect, get pictures and price. I will ship anything I can but I am limited on larger items and sometimes finding boxes. I do not have Greyhound shipping as an option. Thanks for looking *************Parts list added in post 59*************************
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. Last edited by Todd68Chevy; 03-05-2012 at 08:46 PM. Reason: Items sold |
12-07-2011, 10:25 PM | #2 |
Re: Parting out a 1972 Chevy Cheyenne C10 Rusty
More Pictures.
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. |
12-07-2011, 10:28 PM | #3 |
More pictures
12-07-2011, 10:38 PM | #4 |
Carpe manana
Does the truck still have the medium olive defrost vents in good shape?
12-07-2011, 10:41 PM | #5 |
Restoration Virgin!
steering wheel any good....if so please check shipping to 28031
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
12-07-2011, 10:49 PM | #6 | |
It would be useable but does have cracks. I will try to get better pictures.
12-07-2011, 11:02 PM | #7 |
Active Member
Shipping cost on seatbelts to 08008? If $10 or so and no damage to belts I'll take them. Price on door jamb vent ?
12-07-2011, 11:24 PM | #8 |
Restoration Virgin!
Todd...I'll pass...I didn't see that large crack along the base...thought it was a shadow
12-08-2011, 01:56 AM | #9 |
If the vent windows are chrome and glass is soft ray and in good shape! Ill take them pending price shipped to 58265
Posted via Mobile Device |
12-08-2011, 03:29 AM | #10 |
Just a Member
I know where you found this!!! Had my eye on it too... A little too far from me... Good find!!! Good luck with the sales!!!
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
12-08-2011, 07:56 AM | #11 | |||
Yes it is the one that was on Terre Haute Craigslist. It was only 25 miles for me. I was interested in the rust free tailgate but his rust free tailgate is full of bondo and has these bubbles under the paint. If they are not rust I guess I do not know much about old trucks. LOL It is pretty rough but I hate to see any of them just go for scrap.
12-08-2011, 08:12 AM | #12 |
How much for the heater controls and the lighter delete plug shipped to 22435?
12-08-2011, 08:00 PM | #13 |
Todd,
hows the gas tank? Is there any rust inside the tank or leaks? I might be interested. What is the amount? Is it also possible to ship to 63301, close to Saint Louis. Thanks, Ray |
12-08-2011, 09:47 PM | #14 |
Laid Back
Interested in the door panels!! Price shipped to 74804?
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
12-08-2011, 09:57 PM | #15 | |
Here are some pictures, just let me know if you want more. The shipping would be $11.00. The webbing looks good but dirty. The latches all work. The chrome is not great. The retractor covers are not as good as I thought they were. I do also have a door vent. I would take $55.00 for the belts, vent and shipping. Let me know. Thanks
12-08-2011, 10:02 PM | #16 |
More belt pictures.
12-08-2011, 10:05 PM | #17 |
Outer door handles condition and passenger side inner front fender price shipped to 07981
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
12-08-2011, 10:05 PM | #18 |
Would be interested in one bed wheel tub. Can u tell me shipping to 67401. Thank you
12-08-2011, 10:09 PM | #19 |
Carpe manana
I'll pass then. Thanks for checking. Pete
12-08-2011, 10:12 PM | #20 |
The heater control levers all move and not broken. 2 of the rivets holding the face to the back are getting loose and have some movement. Switch operation is unknown. I would take $25.00 for it. Shipping would be $8.00. Total of $40.00 for control head, lighter delete and shipping. Let me know. If you need more pictures just let me know. Thanks
12-08-2011, 10:22 PM | #21 | ||
Left outside handle might be ok but the right side has the button broken in it. All the sheet metal is very rusted and I am sure the inner fenders are junk. I will let you know when I get it apart.
12-08-2011, 10:27 PM | #22 |
The main part is nice but the bottom lip is rusted around where it bolts into the bed. I planned on cutting them out so I will see what they look like after removal and get you a price and shipping quote.
12-08-2011, 11:16 PM | #23 | |
Jess Posted via Mobile Device
12-09-2011, 12:17 AM | #24 |
Carpet available?
12-09-2011, 12:29 AM | #25 |
How rough is that steering wheel? Any more photos available?
Thanks, Collin |
