"Junkyard Dog"
![]() Join Date: Jan 2008
Serpentine belt conversions
This a used serpentine belt conversion is for small block chevys. The pics are my demo set up. The kit includes RH AC bracket, AC R-4 pump R134 or R12, LH Alt-power steering bracket, 100A Alt, power steering pump, belt tensioner, fan clutch, fan blade, clutch mounting studs & nuts, water pump pulley, crankshaft pulley w/bolts, braces and nuts & bolts. The RH bracket originally used 2 mounting bolts to the cylinder head. If your cylinder head only has the traditional one hole it will still work fine. I have sold many of these that only used one mounting hole with no problems. These will come cleaned and ready for detailing. I can detail a kit for 100.00 extra which will include media blasting and painting in satin black. I have four of these conversions for 225.00 plus shipping. Big block conversions also available.
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
Just a Member
Re: Serpentine belt conversions
would you consider selling this setup minus the power steering pump, pulley fan,clutch, and crank pulley?
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
Put me down for one.
How do you want to be paid? |
"Junkyard Dog"
Sure, 165.00 plus.
![]() Join Date: Oct 2006
Will this fit 1970 4X4 radiator shroud, and the upper radiator hose. Do you have any with out A/C. What would shipping be to 30263. Any pics installed in trucks?
"Junkyard Dog"
PM sent
No, it will not work with the deep 4X4 shroud. I'm thinking it would work with a 2WD shroud on a 4X4 truck. I have a local freind putting one in a 72 4X4 and he just got the 2WD shroud to see if it would work. Also won't with the factory upper metal tube. A non ac set up uses a dummy pulley in place of the ac pump therefor it uses the same belt. Sorry no pics of any installed. Shipping would be 67.66 Thanks, Tom
PIMPING ON A BUDGET
![]() Join Date: Sep 2010
will this work with the regular water pump ordo i need a reverse flow?
"Junkyard Dog"
It will require a reverse flow water pump. These pumps are available with or w/o the heater return port. I can supply it with a used pump but I would highly recommend a new one.
I am also interested. I have a 67/70 "327" I used different heads with holes for accessories. Looks like the alt bracket bolts on to a later model exhaust manifolds. mine are ram horn style, will this still work. Will there be any issue with crank pulley. What is shipping to 21863 Snow Hill,Md and is Paypal ok. Thanks Ed.
![]() Join Date: Apr 2000
How much for a BB? Do you have any pics?
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
#11 | |
"Junkyard Dog"
Sorry, I sold the bbc kit local. Thanks
Hey does manifold bracket hold the PS pump, or is it to stabilize the back of the ALT. I am trying to figure what Mods I will need to get this right. Thanks....Ed
GM Addicted
so your selling basically jus the brackets and pullyes for 225 or does it come with the ac compressor, alternator, and power steering pump??
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
#14 | ||
"Junkyard Dog"
You will need a new water pump, belt, and pig tail for alt.
#15 | |
#16 |
I am interested, but do not have the budget right now. Please let me know if you have more available in the future. Thanks!
#17 |
"Junkyard Dog"
Shipping via UPS is 68.00, Thanks
#18 |
Hey Tom Let me know how to pay you or send me your paypal address.... Total was 293. is that correct......Thanks Ed
#19 |
Do you still have some available? This would pretty much bolt up to a 70 gmc with a 350 right?
#20 |
![]() Join Date: Sep 2005
Subscribing to this in case you have more in the future
#21 |
![]() Join Date: Apr 2011
I would also be interested, Can you run the kit without the fan? Or does the fan hold the pulley on? I have electric fan so would not need fan and clutch if it will work like that. Oh and 134 would be my choice. Thanks Tim
#22 |
"Junkyard Dog"
Tim, it would work fine without the fan and clutch. Just use short bolts with HD flat washers to prevent the pulley from cracking over time. Thanks, Tom
#23 |
"Junkyard Dog"
Sold two still have two left. TTT
#24 |
so how would I tell if this would fit on my 350?
build thread - 1972 C/10 "Ethyl" 1974 C/10 " Paw Paw" C/10 Club Louisiana ![]() instagram - @esso_c10 @projectpawpaw |
#25 |
![]() Join Date: Aug 2011
Will this fit a 1976 SB 400 factory motor(no mods) with out A.C.?
Thanks Joe Hester |
