#1 | |
Re: 1981 Chevrolet C50 Pick-up Conversion
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061 |
I agree. Even if I liked the big window better I would still keep the small window. You just don't see them everyday anymore. Besides UPNADM said it would take away his speaker locations up in the corner. These cabs are still a bit different from the standard pick up cabs.
#3 | |
As for the welding... your right I don't weld. This is the only class I never took in high school. I really wished I had. However, all my other friends (and two close cousins) took welding. They now work for large companies who build compactors, stackers etc. I can always get them to do any of my welding I need (Usually requires a few pints in the cooler). With all that in mind, my cousin did weld my subframe to my frame in addition to me bolting it. It is stitched in tight now. I still have to do the carrier, but I did not want to do that until I really get a feel on just how I have my pinion angle and driveshaft geometry. As for the back window debate it will be staying with me... I need to get my speakers up there... lol. So thanks for the kind words and thanks for getting me motivated. All the best to everyone in the new year.
1981 C50 Conversion http://67-72chevytrucks.com/vboard/s...d.php?t=503247 1962 Grumman Olson http://67-72chevytrucks.com/vboard/s...d.php?t=613242 |
damn...what are you sanding with? That is bare metal right?
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
The paint is so old and dull, I decided to take it down to bare metal.
I have been using paint stripper, followed by scraper/angle grinder with wire wheel, then paper to ideal smoothness.
Are you using any kind of rust preventer on the spots of surface rust?
http://67-72chevytrucks.com/vboard/s...d.php?t=355153 |
Its been a few days since I have posted. Its been a busy few weeks. None the less I have been doing some work on the truck.
Got the interior out and ready prep the inside of cab. The inside will be the same color as the exterior.
I need to finish prepping the outside of the cab. Primer is on order, it was on back order.
nice
sweet build
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s 1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater 1963 C10 reg cab long box 1970 Chevelle 1968 Biscayne 2dr post "...there is no excuse for what I am about to do, but dangit....it's gonna be fun!" |
Are you using paint stripper on the body/paint?
I am using a paint stripper on most of the metal. I started trying to sand it out, but years on the paint and multiple layers of dead paint had me opting to use paint stripper.
It can be messy, but it has worked to loosen up the paint. I usually put a heavy coat on then use a scraper. Or I have used my angle grinder with a wire wheel. I knock off most of the paint then hit it with my orbital and smooth everything out. Once done I cover the metal with a self etching primer. I worked on getting the roof stripped tonight. I will be glad when this process is over, and have the minor dents smoothed out and the cab is in primer. Here is a picture of my half stripped roof. Had enough for the night, will get the rest tomorrow.
The transmission dilemma has been solved........................................ Stick with what I had! Ha.
I feel I could spend a lot of time and money to get all of this working. If anything positive about the situation, I will be able to sandblast the original bell housing and degrease and and paint the gear box. Hopefully I can resell this... ha.
This is an awesome build!
1947 Chev 3600, 454,th350,9"ford tubbed (Pop's ride) 1965 GMC 1000 305E V6, Powerglide. GONE ![]() 1972 GMC K-2500 350, 4 speed, 229,000 miles 1988 Chevrolet Caprice 9C1 Ex cop car, 350, 700r4. 1997 Ford F-350 4x4 XLT (The Hauler) 7.3 diesel. RUST NEVER SLEEPS |
#15 |
showoff! lol keep it up
#16 |
sweet truck man is it a 427? not sure if it was already said
#17 | |
As per my previous posts, I have since found out that the 366 and I am presuming the 427, however never presume (LOL), have different bellhousings, larger clutches and input shafts for converting to a 5 speed.
#18 | |
did not know that i just assumed anything over 30 came with a big block haha and i know what you mean by the bellhousing its huge mine had an allison tranny behind it when i got it |
#19 |
I am looking at a 50 this weekend, low miles 350. missing the radiator ? will a 3/4 or 1 ton work ? Good tires, no rust good glass, but no bed ! What would you do ? Thanks for any suggestions....jack
#20 | |
I believe the C50 rad would be a little longer and taller. I will measure the rad that I took out of my truck when I get home and post the dimensions. Giver on the purchase.
#21 |
Just rereading this thread and noticed that the truck is powered by a 350. Is it just a standard SBC 350 like we see in the smaller trucks? I have a line on an older C50 that i can hopefully get my hands on and one of the ideas i had for it was to swap out the two barrel intake for a 4 barrel intake and run a throttle body fuel injection set up.
'84 Chevy Custom Deluxe 10 "Frankenstein" http://67-72chevytrucks.com/vboard/s...d.php?t=690587 '69 Chevy C10 |
#22 |
I think youe should chop the rear window out and put in a full sized slider
1978 GMC C25 LWB ![]() |
#23 | |
I would have to get rid of my factory speaker holes (see photo... ha)
#24 | |
1981 C50 Conversion http://67-72chevytrucks.com/vboard/s...d.php?t=503247 1962 Grumman Olson http://67-72chevytrucks.com/vboard/s...d.php?t=613242 Last edited by UPNADM; 03-19-2012 at 11:22 PM. Reason: Photos did not attach... |
#25 |
Great looking build so far ... !
