Old 09-02-2003, 09:07 PM   #1
sakohntr
sakohntr's Avatar
blazer tops 101 ???
What exactly is the difference between the single and double wall tops. I am assuming the double would be for cold climate conditions. Did you have to order it special. Was the single wall the standard top. Are there any asthetic differences between the two. Is the rear hatch the same on both? thanks boys
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
Old 09-02-2003, 09:23 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
All the top's that I have seen have been double wall here in oregon.. I believe they have the same rear hatch and look a little more finished inside to me anyway's.. That;s all I got I have not been a blazer owner long so my knowledge is minimal..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 09-02-2003, 09:32 PM   #3
NuBomb
NuBomb's Avatar
As far as I know the biggest difference between the two types of tops is that the single wall top bolts in from the top down. A single wall top is preferred for its strength as well as the fact it can be removed without removing the side panels. The hatch is the same.
the double wall top is not as strong as the single wall top (I believe I am correct), And if you have rear side panels you would have to take them off to take the top off.
Jeremy (NUBOMB)
72K5 CST 350/350/205
1951 Chevy 1/2 ton
North Georgia Group
"... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman.
NuBomb is offline   Reply With Quote
Old 09-02-2003, 09:52 PM   #4
blazerholic
I am a Gov't Mule
blazerholic's Avatar
I've heard that the single walls are lighter as well(although I have no proof 'cause both of mine are single wall and heavy as h*ll!). I've seen both and know they look different on the inside too. The single walls have 'braces' that run side to side while the double walls have 'grooves' that run front to back. I've also heard somewhere that single walls were only available in 72, not sure if it's true or not. Hope my 2 braincells helped!
...to die in the saddle must be my destiny, to ride this rockin' horse I must be crazy...
blazerholic is offline   Reply With Quote
Old 09-02-2003, 09:53 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
Double wall top's are heavy as hell !!!!!
MEMBER #6377
Project "7DEUCE"
Old 09-02-2003, 10:04 PM   #6
NuBomb
NuBomb's Avatar
I have a 72 and it has a single wall top. I would imagine it is lighter than the double wall top. I haven't seen the inside of the double wall top but my guess is it does look better than the single wall.
Jeremy (NUBOMB)
1951 Chevy 1/2 ton
North Georgia Group
Old 09-02-2003, 10:19 PM   #7
1970blazin
Blazerless:-(
1970blazin's Avatar
Here is my singlewall. I have heard that they both have different bolt patterns too...Is that true? I took a doublewall top off mine and am going to put on this singlewall. I sure don't feel like having to drill new holes in my nicely painted blazer! Also the doublewall has a "seam" down the middle which seems to me to make it flex a little more. BOTH are heavy as heck!
1970blazin
1970 CST Blazer-Orig. Dark Blue-SOLD
Progress Pics of Blazer for sale
1970blazin is offline   Reply With Quote
Old 09-02-2003, 10:27 PM   #8
Gee_Emm
Anyone have a guesstimate on how much a single wall wieghs. In men or pounds :p
Gee_Emm is offline   Reply With Quote
Old 09-02-2003, 10:31 PM   #9
blazerholic
I am a Gov't Mule
Talking
In my experiences it has taken 2 men and near herniated testicles to remove a single wall!
Old 09-02-2003, 10:32 PM   #10
FRENCHBLUE72
PROJECT 7DEUCE
70 blazin the threaded hole's are for the single wall top. No new hole's to drill. happy-happy.
MEMBER #6377
Project "7DEUCE"
Old 09-02-2003, 10:34 PM   #11
raggedjim
raggedjim's Avatar
Gee Emm. the answer is me, my wife, one mother-in-law and an 82 year old greatgrandpa... I gotta make friends with some big guys so I can stop killing my wife's family...
P.S. during this little exercise I discovered most of my wife's relatives can cuss like sailors (not trying to offend the squids out there, I'm an old salt myself...)
raggedjim is offline   Reply With Quote
Old 09-02-2003, 10:41 PM   #12
FRENCHBLUE72
PROJECT 7DEUCE
I do not think double wall top's have light's in them????
MEMBER #6377
Project "7DEUCE"
Old 09-02-2003, 10:54 PM   #13
NuBomb
NuBomb's Avatar
I've taken the single wall top off by myself. I had a stack of lumber that was just about the same height as the tops of the bedsides. I unbolted it and then centered the top on my back and walked it back to set it on the wood pile. It can be done, but not without a situation like I had. You must have something the same height as your blazer. You could probably build a platform where this could be done.
Jeremy (NUBOMB)
1951 Chevy 1/2 ton
North Georgia Group
Old 09-02-2003, 10:55 PM   #14
Gee_Emm
So 2 guys and 2 girls would do it? I am assuming that the front is the light end?
Old 09-02-2003, 10:57 PM   #15
Phillip Johnson
Phillip Johnson's Avatar
Sounds like a trip to the chriopractor
Phillip Johnson is offline   Reply With Quote
Old 09-02-2003, 11:34 PM   #16
raggedjim
raggedjim's Avatar
The front is MY end! Rg
Old 09-03-2003, 01:24 AM   #17
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Here's a link to a previous post.
I posted pic's from the assembly manual.It shows the differences between the single and double walled tops.
Clickhere
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 09-03-2003, 03:26 AM   #18
RED72blazer
urban fourwheelin
RED72blazer's Avatar
I got my hatch from a single wall top. I think the hatch supports on the single wall top are longer than on a double wall, because the mounting bracket on mine doesn't line up with the old holes.does anyone have both types?
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 09-03-2003, 11:42 AM   #19
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
didn't know that about the hatch supports... I've seen a lot of double wall tops split on the seam down the middle and the seam across the front above the windshield.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 09-03-2003, 12:09 PM   #20
sakohntr
sakohntr's Avatar
q
So we have successfully unconfirmed that one top has lights and one does'nt. One has longer struts than the other, nobody knows if the hatches are the same, and both tops are too damn heavy???
Old 09-03-2003, 12:18 PM   #21
69girl
69girl's Avatar
**** it sounds like i'm going to get to work pulling that off next summer!!!! Better get to the gym now so I don't die carrying that thing off.
69girl is offline   Reply With Quote
Old 09-03-2003, 03:19 PM   #22
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
I built 2 saw horses slightly taller than the rear seat and as long as the bed. Put them on each side of the truck. Unbolt the top. Lift one end and put a 2x4 across the saw horses at that end (you can do 1 corner at a time). Lift the other end and do the same. Drive away.
BTW, the double wall weighs about 450#.
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 09-03-2003, 03:40 PM   #23
bouncytruck
SKINNY TIRES RULE!
Good idea 70 Jimmy. CK5.com has some ideas on building a pully system in a garage. http://coloradok5.com/topstorage.shtml
bouncytruck 1972 K5
Old 09-03-2003, 04:06 PM   #24
HatGuy
HatGuy's Avatar
Cool
I read somewhere on the internet that
the single wall is 300 pounds.
Joe Peters the HatGuy
72' K5 Highlander
My Daily Driver
http://www.pbhats.com/BLAZER/index.html
HatGuy is offline   Reply With Quote
Old 09-03-2003, 05:19 PM   #25
Leinie
I have swapped a rear hatch from a double wall to a single without any problem, so I believe they are the same.
Here's a cheap easy way to hang your top ! I can hang it myself
without any pullys
I stand up in the bed and lift it on my shoulders just enough to slip the 2x4 under,
then I hook the front 2x4 on one side, push up the other side and hook it, then I lift and hook each of the rear corners separately.
You don't need to lift it much (Maybe 2.5 " )so the thing doesn't get all tweaked out of shape.
Then just drive away !
Leinie is offline   Reply With Quote
