Old 01-24-2012, 02:33 PM   #1
motornut
78K & 79C Jimmys
motornut's Avatar
Steering coupler or Rag joint
I replaced mine last fall
when i ordered the part at first it seemed there was only one used
Dorman 31011
this puts my steering wheel out 180 or upside down
called and ordered the 31015.....wrong size
called dorman was told "they have never heard of this upside down before"
asked at a GM dealer "someone may have changed something"
before i turn my wheel around,is this normal?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 01-24-2012, 07:01 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: Steering coupler or Rag joint
When I swamped columns on my 79 it did the same thing. My solution was to drill out the plastic from the two holes on the steering shaft and pull the shaft apart. Once this was done I flipped the shaft over and reinstalled it.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 01-26-2012, 01:01 AM   #3
Gibson
Gibson's Avatar
I ran into this exact same problem. I happened to have discovered earlier during an ignition switch replacement that the PO had actually swapped the original '78 column for a '77 and I assumed that is what caused it. All I did was center the wheels, take the bottom of the column off the streering gearbox, and slid it up so the steering column could turn freely. Then I the centered the steering wheel and pushed the column back on the box. Took a couple of tries to get it centered correctly.
Gibson is offline   Reply With Quote
Old 01-26-2012, 08:14 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
mine won't turn like that it's keyed
John
Old 01-26-2012, 11:58 AM   #5
Gibson
Gibson's Avatar
If it is the same as mine, it is only keyed on the side that connects the coupler to the shaft: the other side of the coupler (the part that connects to the gearbox) just slips onto the splined shaft of the gearbox. In that first pic you have there you can see a big fat nut on the left side of the coupler right next to where it connects to the gearbox. I just loosened that, banged the crap out of the shaft to break loose the rust, slid it off and turned the wheel. So basically, the WHOLE joint is still connected to the shaft (the new shiny bit you just put on and the ugly old rust side too); you rotate the whole assembly and then join it back to the gearbox.
Old 01-26-2012, 06:36 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
my gearbox is keyd with a flat side that only fits one way
and then are the two different sized bolts
thought i took more pics...nope
John
Old 01-27-2012, 03:29 AM   #7
INSIDIOUS '86
INSIDIOUS '86's Avatar
Forgive my ignorance but what exactly is the rag joint for and why would it be a good idea to replace it?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 01-27-2012, 03:46 AM   #8
mongoose
mongoose's Avatar
it allows for flex between the steering shaft and box.. a really really low tech u joint really.
they become worn out and loose..
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 01-27-2012, 03:51 AM   #9
INSIDIOUS '86
Sounds like a useless vibration damper. I think I will try and remove the rubber and make myself a solid aluminum one on my lathe. Should kill some of my slop huh?
Old 01-27-2012, 04:08 AM   #10
mongoose
mongoose's Avatar
do you have actual slop? tighten up your box too.
Old 01-27-2012, 08:04 AM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
It sure helped to make mine feel better
driving along you could sorta wiggle the wheel left to right
looking under the hood the box didn't turn till the "pin " touched
the new one dosn't touch,i'd leave it rubber alumi don't flex
gee guess I could say don't 86 the rubber !lol
John
Old 01-27-2012, 08:42 AM   #12
str8axle55
You can also swap in the steering shaft out of a Jeep Cherokee, XJ shaft swap. These have U-joints at both ends, and pretty much bolt in.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 03-04-2012, 05:32 PM   #13
Zylone
Zylone's Avatar
Did ya figure this one out? I just swapped mine out, same exact part number and all. Had to flip my steering wheel upside down to get it back together. Now, it is pulling to the right some. Ugh.
84 SWB C10 Project
Zylone is offline   Reply With Quote
Old 03-04-2012, 05:59 PM   #14
motornut
78K & 79C Jimmys
motornut's Avatar
No it's still upside down ,but drives fine,
I'm living with it, cause I' m going tilt, deal with it then
Only prob is I get caught flashing sometimes lol
Havn't seen any complaints , so I duno what ,but see if the tilt fix , fixes it
John
Old 03-05-2012, 12:35 AM   #15
Zylone
Zylone's Avatar
Yeah, mine seems to work fine.. I have a tilt column stock too.. same problem as you! I tried tearing apart the old joint to just put a new pad in it. No such luck so far.
84 SWB C10 Project
Old 03-05-2012, 12:53 AM   #16
joe231
joe231's Avatar
Does your colapsable shaft unbolt from the column up by the firewall?
If so you can unbolt it there and spin the wheel 180 then bolt it back together.
It should fit either way...
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 03-05-2012, 01:46 AM   #17
Zylone
Zylone's Avatar
Joe, you are my hero! I went and took a look, and sure enough there was a bolt! It took some serious tugging to get it off, and putting back on, but my steering wheel is back to normal! No modifications to the backwards rag joint needed!
84 SWB C10 Project
Old 03-05-2012, 02:09 AM   #18
joe231
joe231's Avatar
Glad I could help
CHEVY ONLY
Old 03-05-2012, 03:03 AM   #19
INSIDIOUS '86
You guys think that the rag joint I necessary? I know they are a cheap kind of u-joint/ vibration dampner. It seems lik the column to the box is very straight. I may pull the rubber part on mine and mill a aluminum donut for a replacement
Old 03-05-2012, 07:33 AM   #20
Your41Plague12
Your41Plague12's Avatar
I would definitely keep the rubber. It allows for a little bit of flex when needed, where aluminum won't.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 03-05-2012, 11:22 AM   #21
undr8ed
Does the J**P steering shaft work for these trucks? I know it made a DEFINITE difference in my GN... And it's a LOT less espensive versus making your own (have one with pto outputs on another rig...)
riding... just riding.......
undr8ed is offline   Reply With Quote
Old 03-05-2012, 12:10 PM   #22
Desert1957
Desert1957's Avatar
Just a note, I have an 87 tilt column in my Street Rod with a "Flamming River" Double D coupler instead of the factory Rag-Joint. You will notice ALOT more vibration in the wheel. I don't care its a HotRod , But in my truck I wouldn't like it.
Desert
Desert1957 is offline   Reply With Quote
Old 03-05-2012, 02:24 PM   #23
INSIDIOUS '86
I took off the belt for the power steering pump.got tired of the butter steering. Some vibration ain't Gona hurt at all. Rather that then slop
Old 03-05-2012, 05:34 PM   #24
motornut
78K & 79C Jimmys
motornut's Avatar
thanks gona check that out
John
Old 03-05-2012, 07:38 PM   #25
hatzie
Moderator
hatzie's Avatar
You mean the XJ Cherokee column? Yes it fits. It cleans up a lot of slop.
