Old 01-24-2012, 08:25 PM   #1
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Airstream Shortification!
The Airstream I purchased for work will no longer need to be in service because the company let me go at Christmas.
So while I'm unemployed I've decided to go ahead with the modification process.
Step 1: The concept.
Convert this......
too......
Step 2: New shortened frame with new axle.
Relocating the battery to the section between the cab and rear bumper. Also installing a mount for a telescoping flagpole I had also purchased. There's a basket between the pole and battery box to house the extension cable for powering up the trailer. The thought is also to set up for a future modification of the removal of the rear window and rear lower panel to be replaced by a folding ramp that will allow rear access for my brothers Harley. I would like to install a 40" monitor to show a slideshow presentation of Chevrolet Dealer Communication Kits I have.
We have an old electro-hydraulic pipe bender so Dad ( 79 years old and loves to tinker ) made a die for bending 2x4 tubing. We bent up the 3/16 tube without much effort. Nice and clean look that no one will see unless they get down on all fours, but it's the fun of being able to bend it.
After all is said and done it should be a little less than 10ft. inside. About 14ft. overall.
I'll have it sprayed with foam to insulate the walls and floors. Thinking of Line-X on the floor inside, under the floor to protect the foam insulation and maybe on the walls as well. We'll see. I need a finish on the interior foam which will cover the aluminum ribs as to create a thermal break.
Old 01-25-2012, 12:17 AM   #2
broey
Square
broey's Avatar
Re: Airstream Shortification!
I really hate to see such a nice trailor cut up..... but if you must.. the frame looks good so far!
Squarebody Syndicate
broey is offline   Reply With Quote
Old 01-26-2012, 08:40 PM   #3
aerotruk63
aerotruk63's Avatar
There is very little original frame to hold this thing together and it leaks air and water from everywhere. It would end up falling apart on the road if it was pulled any further. A little more work done today.
The Angle Iron rim that the walls will bolt to, the inner halves of the inner fenders and some additional center support, to support the Harley LowBoy.
Old 01-27-2012, 12:40 PM   #4
Clyde65
Clyde65's Avatar
Nice!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-27-2012, 12:47 PM   #5
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Looking good!!
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 01-28-2012, 12:25 PM   #6
pickup67man
pickup67man's Avatar
I've always been curious how airstreams are assembled. Never looked up close.
Travis
2005 K2500 Duramax (hauls the junk home)
1967 Chev C10 (hauls a$$)
1970 Suburban (Yukon XL 4 door)
1968 GMC 3/4 ton (sheetmetal only, chassis gone)
2005 Malibu (wife's car, still a Chevy)
Project Family Hauler
New Home for Chevys (Moved in and working)
pickup67man is offline   Reply With Quote
Old 01-30-2012, 03:04 PM   #7
NONHOG
NONHOG's Avatar
This will be fun to watch! Subscribed!
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 01-30-2012, 05:08 PM   #8
Keith Seymore
Keith Seymore's Avatar
Subscribing - looks good.
I think the highlight for me is that you still have your 79 year old dad to putter around with. Enjoy this time together -
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-30-2012, 06:28 PM   #9
LEEVON
Moderator
LEEVON's Avatar
K
Well said! I like this thread...can't wait to see what's next.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 01-30-2012, 09:49 PM   #10
Frizzle Fry
Frizzle Fry's Avatar
This is going to be cool!
Frizzle Fry is offline   Reply With Quote
Old 02-07-2012, 09:49 PM   #11
aerotruk63
aerotruk63's Avatar
A little more progress with having to work outside in the cold and helping my buddy out but it's advancing.
Dad made up a trolley for moving it around. Those are No-Flat tires on the trolley.
Added a receiver for the back of the trailer through the bumper. I like the idea of adding a bicycle rack or someplace to install a portable winch, you know , the stuff I'd never use but since I'm there, why not!
Junction box mount for the trailer wiring and Break Away switch. I've been setting up the box, it will have a removable wire set between the trailer and truck. I'm running the wires through the trailer frame.
I installed the rear bumper and then re thought the location for the battery. I'm going to shift it more towards the exterior to allow full opening of the new rear door. The door will open towards the drivers side and will be removable via the hinge pins.
Old 03-14-2012, 06:49 PM   #12
daverod
SSN 706
daverod's Avatar
Cut it and gut it.
daverod is offline   Reply With Quote
Old 03-16-2012, 12:56 AM   #13
Warrens69GMC
Warrens69GMC's Avatar
Subbed for interest.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 03-18-2012, 08:12 PM   #14
68 SHORT-STEP'N
SLOW POKE
68 SHORT-STEP'N's Avatar
Man , this is going to look great !
68 SHORT-BED-STEP-SIDE
piece by piece ,
day by day ,
I will restore this truck ,
before the 100th anniversary !!!
68 SHORT-STEP'N is offline   Reply With Quote
Old 03-19-2012, 12:22 PM   #15
juanz1947
rusty 66
juanz1947's Avatar
1947 chevy fleetmaster
http://www.cbforum.net/forum/
1966 chevy c10 long bed
http://67-72chevytrucks.com/vboard/s...d.php?t=439219
1970 chevy impala custom
http://www.layitlow.com/forums/index...pic=349867&hl=
juanz1947 is offline   Reply With Quote
Old 03-19-2012, 10:03 PM   #16
BlueJeep
BlueJeep's Avatar
How did you bend the angle iron?
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 03-20-2012, 01:18 AM   #17
nuke1
nuke1's Avatar
This is really really cool, I would love to see more!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 03-25-2012, 02:21 PM   #18
Corts60
Just here to tinker
Corts60's Avatar
This is awesome man! I can't wait to see this baby finished.
Old 04-08-2012, 02:56 PM   #19
aerotruk63
aerotruk63's Avatar
Well yesterday I took the curved sections front and rear off the old trailer and placed them for fitting on the new frame. Have been removing the seam sealer and the rest of the rivet shanks that I sheared the heads off to seperate the sections. When I sheared the last of the rivets on the rear section, the trailer frame showed how rotten it was by flexing right behind the axle and opened the two sections like a clam shell.
Old 04-08-2012, 03:12 PM   #20
aerotruk63
aerotruk63's Avatar
Sorry for not answering your question before. I cut slits in the horizontal portion about every inch along the curve then welded them shut. I didn't go searching for someone with a Hossfeld bender which would have curved the angle by stretching the same surface I cut. I have the welder and time so I chose the welding route.
Old 04-08-2012, 04:14 PM   #21
aerotruk63
aerotruk63's Avatar
After removing the two complete ribs inside the old Airstream the walls collapsed.
Old 04-08-2012, 04:22 PM   #22
aerotruk63
aerotruk63's Avatar
Here are interior pictures to those interested to see how little framing goes into the construction of an Airstream. It's a combination of curved peices and a few struts. The inner skin apparently plays an important role in the structure, not only the outer skin.
Inner front section view
Inner rear section view
Old 04-08-2012, 04:24 PM   #23
aerotruk63
aerotruk63's Avatar
My Dad built this for moving my buddy's trailer in and out of the shop.
Old 04-13-2012, 09:41 AM   #24
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Gonna be a cool little camper
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 04-14-2012, 04:10 AM   #25
Torrey72
Rollin in my K5 toaster
Torrey72's Avatar
This is NICE!
P.S. Don't forget to nab the "Airstream" name plates off the scrap heep.
Torrey72 is offline   Reply With Quote
