Old 02-03-2012, 04:20 PM   #1
CJ_Chevy
CJ_Chevy's Avatar
Installing Clock in a truck that didnt come with one
i was just wondering if you can just buy the clock that fit in the lower left corner of the bezel and install it in to my current cluster. My truck did not come with one from the factory.
CJ_Chevy is offline   Reply With Quote
Old 02-03-2012, 04:49 PM   #2
xrcr
Re: Installing Clock in a truck that didnt come with one
Chances are the printed circut on the back of your cluster won't have the leads for a clock. If you get a printed circut with clock leads your harness might not have anything to power it with. I'd think you could wire your clock independently to an "always" hot point. However, there are much wiser people on here than me so hang loose and we'll both learn something.
xrcr
xrcr is offline   Reply With Quote
Old 02-03-2012, 05:11 PM   #3
bigwheel15
bigwheel15's Avatar
xrcr
Correct me if I'm wrong but I believe the clock doesn't run off the printed circuit, it has an independent plug on the back of it.
bigwheel15 is offline   Reply With Quote
Old 02-03-2012, 05:32 PM   #4
Telecasterjoey
You are correct clock is independent of the cluster
Telecasterjoey is offline   Reply With Quote
Old 02-03-2012, 06:01 PM   #5
ramz
ramz's Avatar
xrcr
If its always on a hot point wouldn't that eventually run down the battery???
I was thinking about buying one for mine.
Thanks!
ramz is offline   Reply With Quote
Old 02-03-2012, 06:25 PM   #6
Cheapster
Thanks!
It would eventually run down the battery, but then so would a car stereo if it sat long enough. Direct power for memory and time on them newer radios. Doubt the clock draws that much. Probably take a couple weeks to over a month for the clock to kill the battery.
Cheapster is offline   Reply With Quote
Old 02-03-2012, 07:39 PM   #7
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
The clock does not have leads on the cluster. You will need to cut a hole in the cluster to run power to the prongs on the back of the clock. It will eventually run down the battery but unless you are sitting for months it won't matter.
The older 79- clock harness will work the same as the newer 80+ models.
When I bought a new clock for mine on eBay I was sent a harness for it but I already had a clock and the harness. I MIGHT still have the harness I never used. I doubt I do but I will look for it tomorrow when I go to my shop for it and if I can find it I can send it to you free.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 02-03-2012, 07:44 PM   #8
SBTork
Garage wrench
SBTork's Avatar
Don't be at all concerned about running the battery down. I've let my suburban sit all of last winter with the battery hooked up and it fired right up in the spring. The clock even held perfect time!
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 02-03-2012, 07:48 PM   #9
madcow75
madcow75's Avatar
If the bezel just has a blank area then it doesn't have the correct screw holes to mount the clock. I tried to mount one in my 76 bezel and it didn't have the 2 screw holes for it.
madcow75 is offline   Reply With Quote
Old 02-03-2012, 08:26 PM   #10
wilkin250r
wilkin250r's Avatar
If the clock WASN'T connected to power 100% of the time, then it wouldn't be moving during those times it wasn't powered, and thus it wouldn't keep time. What would be the point of having a clock if you needed to set it every time you fired up your truck?
As for the complexity of adding a clock, I believe the front bezel is all the same, but the clear lens is different, as is the molded plastic housing that mounts all the gauges. I don't think the lens can be modified, but it's not difficult to find and replace. I'm not sure on the housing, it might be possible to modify it to mount the clock, especially since it could be as ugly as you want it won't show in the final product.
Heck, you could take a dremel to it and cut everything out, then epoxy in a hunk of wood to mount the clock, it will look just as good as factory when it's all in place. But it might be just as easy to replace the housing, they're still fairly common in junkyards and ebay (although LMC only lists a housing without the clock)
wilkin250r is offline   Reply With Quote
Old 02-03-2012, 08:26 PM   #11
hatzie
Moderator
hatzie's Avatar
Were the plastic towers there?
Old 02-03-2012, 08:52 PM   #12
madcow75
madcow75's Avatar
Yes mine didn't have the plastic towers
Old 02-03-2012, 08:54 PM   #13
parrisc19844x4_468
parrisc19844x4_468's Avatar
You will need the cover with the hole in it, I guess you could drill it.
2017 Silverado LTZ 6.2
1984 Scottsdale K10 - 468 700r 4x4 lwb
1978 GMC Sierra Grande K15 350 Soond to be 406 th350 4x4 swb
1968 GMC 20 305 V6 good ole wood hauler.
Good Fences make good neighbors
parrisc19844x4_468 is offline   Reply With Quote
Old 02-06-2012, 05:10 PM   #14
xrcr
See what I mean I learned something. I sure thought it was part of the circut, however my 76 does not have a clock but the 84 cluster did. I went with the 76 circut. I've never been that into time.
xrcr
Old 05-18-2012, 05:03 PM   #15
carboncrew
carboncrew's Avatar
This is for my 1991 ccsb.
I bought a new lense and had to drill the hole for the trip odometer...could've bought a new lense without clock hole and drilled that too. I also had to fab up the area for clock to mount properly.
The needles on the clock vs tach vs factory did not match so I painted them with this:
It's an almost perfect factory color orange.
carboncrew is offline   Reply With Quote
Old 05-18-2012, 08:55 PM   #16
texastruckjunky
texastruckjunky's Avatar
What year did they start putting clocks into the trucks? I've never seen a 76 year model with a clock.
Life is to short to drive anything else
texastruckjunky is offline   Reply With Quote
Old 05-18-2012, 11:29 PM   #17
DubDubU
DubDubU's Avatar
be very careful and most importantly take your time
'79' shortbed
DubDubU is offline   Reply With Quote
Old 06-17-2012, 10:49 PM   #18
x ReAcT x
I really really want to have a tach in my 86 Pickup if at all possible. Is that tach originally from your 1991? and what does ccsb mean? Im new to this forum as you can tell haha
1986 GMC K15 4.3V6/SM465/NP205
will be converting to
5.3LS E-ROD/AA adapter/SM465/NP205
10 Bolt Axle Rebuild Tutorial:
http://67-72chevytrucks.com/vboard/s...d.php?t=536415
x ReAcT x is offline   Reply With Quote
Old 06-18-2012, 09:54 AM   #19
carboncrew
carboncrew's Avatar
React,
The tach came from here: http://www.gmsportssalvage.com/?q=node/1316
It's plug and play
CCSB: Crew Cab Short Bed
No problems...I'm new here too!
Old 06-18-2012, 11:57 PM   #20
x ReAcT x
React,
It's plug and play
Do those gauges have a plastic backing or are they a metal backing??
Old 08-20-2015, 03:31 PM   #21
slimneverdies
slimneverdies's Avatar
I wonder does anyone have pics of what you did here now that the pics aren't showing here anymore. I'm trying to install a Quartz clock in the blank space on my gauge cluster also.
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 08-20-2015, 04:11 PM   #22
carboncrew
carboncrew's Avatar
Hmm...seem to have lost the pics I had. This is the completed cluster. Wiring was just plug and play if I recall correctly.
________________
My very own build
My tailgating ambulance
Old 08-20-2015, 04:18 PM   #23
carboncrew
carboncrew's Avatar
Mine was metal (again, if I recall correctly). I know some didn't like the 'sticker' face, but you really can't see it at all.
________________
My very own build
Old 08-20-2015, 04:53 PM   #24
slimneverdies
Thanks. Do you have any pics of how you mounted the clock? The plastic towers are way off and the column it sits in looks like it's a bit small for the case of the clock ...
Long live SLIM
Old 08-20-2015, 06:46 PM   #25
truckin 79
I just put a clock in my 79 because I was tired of looking at the blank space on dash. I used a quartz clock and the lower mounting hole fit into the plastic tower by the temperature gauge but the top mounting hole on clock did not mount to anything but stays put just fine with just lower mounting hole. Don't forget hole in plastic lens also supports clock as well. I drilled some holes in back of plastic cluster for wires to fit through, I made sure I held circuit board out of the way when drilling. I also didn't use factory plug since it is so bulky, just spliced some wires with female connectors on them to slide over terminals.
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
