![]() Join Date: Jul 2010
No Limit Spy Photos
Spy Photos
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: No Limit Spy Photos
New "NoLimit Member" jig?
Very interesting.....
Kinda Chris Alston looking,... isn't it.
New Parts
You going to offer it coilover or air bags?
your choice, we'll have both.
How long before there's a product info/marketing release?
Hopefully in two weeks. - need to make sure there ready to go. Plus, No Limit dealers get first crack at a pre-release.
![]() Join Date: May 2007
Any spy photos for the rear ?
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
What gen is this for? 73-87?
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s 1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater 1963 C10 reg cab long box 1970 Chevelle 1968 Biscayne 2dr post "...there is no excuse for what I am about to do, but dangit....it's gonna be fun!" |
We are working on an updated version of our Wide-Ride 3 to fit as a bolt-in for 63-72, and 73-87
probably a stupid question, but would this work on the old square body 1 tons? or is the frame a different setup on them compared to the 1/2's?
#15 |
Is the spy still on special assignment ?
#16 |
any updates?
Doug Looking for a 67-72 short bed driver..... |
#17 |
The spy is wet sanding today. We are finalizing motor mount towers at this point. Complex forming is holding us up, have to make new forming dies.
#18 |
update ?
#19 |
Motor mount towers are done, and after a week, we're finally rested up from the Del Mar thrash. We are shooting an install this weekend, well saturday, I'll post up some on monday. Happy Easter.
#20 |
tomorrow is Monday.
#21 |
Will this work with the current rack & pinion set up you offer? Is there going to be control arms offered also?
#22 |
This crossmember is on a bit of a different track than most. We are moving away from the C-10 components. This will be a new version of our Wide-Ride IFS, a complete IFS package including the crosmember, A-arms, coil-overs, shockwaves, or bags/shocks, spindles, brakes, power rack, and sway bar. The spindle is based on a late model Impala, with 12" drilled/slotted rotors, your choice of any 5 lug pattern, sorry, no 5 lugs yet. The track width is 63" hub to hub. Groung clearance on the crossmember is raised 2" over stock, and ride hieght, without a dropped spindle is a 4" to 5" drop from stock, and 2" drop spindles are avail. Motor mounts are included, and will fit SBC, BBC, and LS.
#23 |
Looks good Rob!
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#24 |
Update
#25 |
Is the Impala spindle taller them the c10 spindle ?
