Old 02-06-2012, 07:26 PM   #1
N2TRUX
Happy to be here
N2TRUX's Avatar
How about some pics of Static dropped 60-66
This is for static dropped 60-66 trucks only!
The Staff is trying to compile a thread that covers pics of static dropped 60-66 trucks. Post pics and details, or links of older threads that you have bookmarked.
Post Pics of your Static Drops!!
Need pics 60-66 (slammed not bagged)
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-06-2012, 08:34 PM   #2
1968ratrod
1968ratrod's Avatar
Re: How about some pics of Static dropped 60-66
dropped and c-notched......
1965 Chevy Suburban
2003 Chevrolet S10
2011 Harley Streetglide
1968ratrod is offline   Reply With Quote
Old 02-06-2012, 08:50 PM   #3
waspp
waspp's Avatar
How about details?
waspp is offline   Reply With Quote
Old 02-06-2012, 10:24 PM   #4
62 short step
62 short step's Avatar
My 64.
All from ECE...
2-1/2" drop spindles
6-lug disc brake conversion
2" drop front coils
1-1/4" sway bar with brackets for lowered trucks
KYB front shocks
6" drop rear springs
shock relocator brackets for rear
KYB rear shocks
Super Panhard bar
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 02-06-2012, 10:44 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Excellent write-up.
Posting all the "lowering stats" with your pic, helps a bunch.
Keep them coming!
Keith
Convert to disc brakes.
Old 02-06-2012, 10:45 PM   #6
lolife99
lolife99's Avatar
LOVE your 'burb!
Keith
Old 02-07-2012, 03:05 AM   #7
Corts60
Just here to tinker
Corts60's Avatar
The poor man's drop:
Torsion bars backed off in the front
TJ springs with pneumatic shocks in the rear.
Old 02-07-2012, 07:29 AM   #8
bondo510
1968ratrod , what size rims and tires? That looks nice!
bondo510 is offline   Reply With Quote
Old 02-07-2012, 08:58 AM   #9
greg65
greg65's Avatar
Almost the same as 62 Short Step
Five lug disc brakes
ECE 2 1/2 spindles
CCP 2" front springs
ECE 1 1/4 sway bar
ECE 6" rear springs
ECE super trac bar
ECE shock relocator kit
KYB shocks front and rear
Centerline Telstar 15x7 with p235/70r15 on front
Centerline Telstar 15x8 with p275/60r15 on rear
The wheels will be changed later.
1965 c-10 swb
1997 c-1500 extended cab
2004 tahoe
1993 mustang gt
BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653
greg65 is offline   Reply With Quote
Old 02-07-2012, 10:11 AM   #10
T Smith
T Smith's Avatar
Sweet ride Greg, the stance is perfect with the big and little tires. Just read through your build thread, nice work!
T Smith is offline   Reply With Quote
Old 02-07-2012, 10:23 AM   #11
greg65
greg65's Avatar
Thanks, I was hoping it sat a little lower in front but it should make a good driver.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 02-07-2012, 10:26 AM   #12
T Smith
T Smith's Avatar
I think once you get the bumper on and get it all trimmed out and it settles a bit she'll be just right...
Old 02-07-2012, 10:46 AM   #13
greg65
greg65's Avatar
I agree.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 02-07-2012, 02:31 PM   #14
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Here is my 61.
Front tortion bars turned down a little. Bump stops removed and there is about an inch gap there.
Rear springs: cut coils. Not sure now much was cut off. PO did it. Its on bags in the rear now, but the pic is with the coils in.
Tires: 215/70/15
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 02-07-2012, 06:26 PM   #15
1968ratrod
1968ratrod's Avatar
Originally Posted by waspp View Post
How about details?
sorry- 4 inch drop springs in front and 6 inch drop springs in rear with drop shocks to match
1965 Chevy Suburban
2003 Chevrolet S10
Old 02-07-2012, 06:27 PM   #16
1968ratrod
1968ratrod's Avatar
front rims are 15x7 with 215/75/15 tires
rear rims are 15x8 with 235/75/15 tires
1965 Chevy Suburban
2003 Chevrolet S10
Old 02-07-2012, 08:41 PM   #17
waspp
waspp's Avatar
This is excellent info and the trucks look great! Greg65 would you know the backset on those wheels? 4" maybe?
Old 02-07-2012, 08:54 PM   #18
Turkey
Turkey's Avatar
3" rear 2" front. All CPP shocks and coils.
Turkey is offline   Reply With Quote
Old 02-07-2012, 09:21 PM   #19
stealth_weapons
Here's mine,
Front- CPP 3" drop srpings, POL 2.5" drop spindles, POL Tubular UCA/LCA 3"
Rear- CPP 4" drop springs
all this equates into hella rake!
Ground Clearance.... i has none;
the Stealth Weapons 63 project, all comments, advice, and critiques welcome!
http://67-72chevytrucks.com/vboard/s...d.php?t=438235
stealth_weapons is offline   Reply With Quote
Old 02-10-2012, 12:06 AM   #20
1enick72
1enick72's Avatar
62 short step, you listed sway bar brackets for lowered trucks. I have 2" springs and 2.5" drop spindles and a sway bar that I have not installed yet. Will I need special brackets for the sway bar?
What size tires are you running?
1enick72 is offline   Reply With Quote
Old 02-10-2012, 12:23 AM   #21
greg65
greg65's Avatar
Not right off hand but i will check for you.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 02-13-2012, 01:35 AM   #22
willyp
willyp's Avatar
early classic enterprises 4/6 drop. power steering kit, power disk brakes, front sway bar, 235/70/16 front 255/70/16 rear.
The price of cool aint cheap.
willyp is offline   Reply With Quote
Old 02-13-2012, 02:33 AM   #23
losthope
losthope's Avatar
Here's the only two pictures of the new static drop i did,have no clue how much drop? its all stock with cut springs front and back, waiting for my basic bolt in c-notch to arrive and the back will be lowered a little more, the rear camero sway bar bolts to the top of axle so its losing a couple inchs of potential drop with that setup.....
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 02-13-2012, 11:37 AM   #24
greg65
greg65's Avatar
The rear wheels are 4" back spacing and the fronts are 3 1/2".
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 02-14-2012, 08:39 AM   #25
beefshreadder116
beefshreadder116's Avatar
im wondering, u guys with the 6" rear drop, does you rearend pumpkin sit underneath the bed floor
Projects:
66 gmc, SWB ,BBW,76 disc brakes/PS and rearend, pancaked crossmember 2 1/2" drop spindles 1 cut coil, 6" drop coils 2 " blocks c-notch with a 350.
beefshreadder116 is offline   Reply With Quote
