Happy to be here
![]() Join Date: Mar 2000
How about some pics of Static dropped 60-66
This is for static dropped 60-66 trucks only!
The Staff is trying to compile a thread that covers pics of static dropped 60-66 trucks. Post pics and details, or links of older threads that you have bookmarked. Post Pics of your Static Drops!! Need pics 60-66 (slammed not bagged)
Re: How about some pics of Static dropped 60-66
dropped and c-notched......
1965 Chevy Suburban 2003 Chevrolet S10 2011 Harley Streetglide |
How about details?
My 64.
All from ECE... 2-1/2" drop spindles 6-lug disc brake conversion 2" drop front coils 1-1/4" sway bar with brackets for lowered trucks KYB front shocks 6" drop rear springs shock relocator brackets for rear KYB rear shocks Super Panhard bar ![]() ![]() |
67-72 parts collector,…
![]() Join Date: Nov 2002
Excellent write-up.
Posting all the "lowering stats" with your pic, helps a bunch. Keep them coming!
Just here to tinker
![]() Join Date: Jun 2008
The poor man's drop:
Torsion bars backed off in the front TJ springs with pneumatic shocks in the rear. ![]()
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
1968ratrod , what size rims and tires? That looks nice!
Almost the same as 62 Short Step
Five lug disc brakes ECE 2 1/2 spindles CCP 2" front springs ECE 1 1/4 sway bar ECE 6" rear springs ECE super trac bar ECE shock relocator kit KYB shocks front and rear Centerline Telstar 15x7 with p235/70r15 on front Centerline Telstar 15x8 with p275/60r15 on rear The wheels will be changed later.
1965 c-10 swb 1997 c-1500 extended cab 2004 tahoe 1993 mustang gt BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653 |
![]() Join Date: Jan 2011
Sweet ride Greg, the stance is perfect with the big and little tires. Just read through your build thread, nice work!
Thanks, I was hoping it sat a little lower in front but it should make a good driver.
I agree.
Who Me?
Here is my 61.
Front tortion bars turned down a little. Bump stops removed and there is about an inch gap there. Rear springs: cut coils. Not sure now much was cut off. PO did it. Its on bags in the rear now, but the pic is with the coils in. Tires: 215/70/15 ![]() ![]()
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#15 |
sorry- 4 inch drop springs in front and 6 inch drop springs in rear with drop shocks to match
#16 |
front rims are 15x7 with 215/75/15 tires
rear rims are 15x8 with 235/75/15 tires
#17 |
This is excellent info and the trucks look great! Greg65 would you know the backset on those wheels? 4" maybe?
#18 |
3" rear 2" front. All CPP shocks and coils.
#19 |
Here's mine,
Front- CPP 3" drop srpings, POL 2.5" drop spindles, POL Tubular UCA/LCA 3" Rear- CPP 4" drop springs all this equates into hella rake! ![]() ![]() Ground Clearance.... i has none; ![]() ![]()
the Stealth Weapons 63 project, all comments, advice, and critiques welcome! http://67-72chevytrucks.com/vboard/s...d.php?t=438235 |
#20 |
62 short step, you listed sway bar brackets for lowered trucks. I have 2" springs and 2.5" drop spindles and a sway bar that I have not installed yet. Will I need special brackets for the sway bar?
What size tires are you running? |
#21 |
Not right off hand but i will check for you.
#22 |
early classic enterprises 4/6 drop. power steering kit, power disk brakes, front sway bar, 235/70/16 front 255/70/16 rear.
The price of cool aint cheap. |
#23 |
Here's the only two pictures of the new static drop i did,have no clue how much drop? its all stock with cut springs front and back, waiting for my basic bolt in c-notch to arrive and the back will be lowered a little more, the rear camero sway bar bolts to the top of axle so its losing a couple inchs of potential drop with that setup.....
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 Last edited by losthope; 02-13-2012 at 02:38 AM. |
#24 |
The rear wheels are 4" back spacing and the fronts are 3 1/2".
#25 |
im wondering, u guys with the 6" rear drop, does you rearend pumpkin sit underneath the bed floor
Projects: 66 gmc, SWB ,BBW,76 disc brakes/PS and rearend, pancaked crossmember 2 1/2" drop spindles 1 cut coil, 6" drop coils 2 " blocks c-notch with a 350. |
