Old 03-13-2012, 03:31 AM   #1
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Angry I hate some previous owners because.....
I got the idea for this thread because of our new member's post:
Originally Posted by gtcox View Post
Let's start with the reasons to hate the previous owners.
Ok, so there's really only one big one. They gouged holes on the upper rear interior of the cab for 6x9 speakers. The speakers were hooked to a newer stereo head. No audio worked. The radio has since been moved to my father's F**d to replace his busted cd player.
Look in the very top corner and you can see one of the holes. The bench seat is something I got from a late 80's early 90's 1500 out of a junkyard. There were mid 90's bucket seats in when I bought the truck.
In that picture you can also see my "custom" gas tank sitting in on the passenger side floorboard. The original tank was all rusted to hell, so when I purchased the truck, the owner had a 2 gal can with a fuel line running into it. I upgraded to a larger can for the ride home. It was a designated non-smoking drive for obvious reasons. I've since bought a replacement in-cab tank.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 03-13-2012, 03:33 AM   #2
LostMy65
LostMy65's Avatar
Re: I hate some previous owner because.....
For me:
They sold my buddy buckets.
Old 03-13-2012, 03:36 AM   #3
LostMy65
LostMy65's Avatar
because....
They hacked up the wiring to install some stupid toggle blinker.
Just buy the right part. It'd been a lot less work.
Oh, and they threw away the emergency flasher and installed this stupid toggle in the hole where it says 'Pull'
Old 03-13-2012, 05:51 AM   #4
dodgiesdad
dodgiesdad's Avatar
They cut a hole in the TOP of the dash for a speaker, and cut out most of the high hump tranny cover, which they siliconed a different one over the hole. And I think they used a ax to cut both. No problem I have since replaced both.
dodgiesdad is offline   Reply With Quote
Old 03-13-2012, 06:09 AM   #5
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Kinda makes you wonder what the new owner of the truck you created and sold is going to say! LOL
Old 03-13-2012, 07:03 AM   #6
kenmel
kenmel's Avatar
they put body filler over duct tape and I found it... now I am scared
kenmel is offline   Reply With Quote
Old 03-13-2012, 07:40 AM   #7
Shooters_7
Duct tape is better than aluminum foil.........things people do to "hide" rust.
Shooters_7 is offline   Reply With Quote
Old 03-13-2012, 08:14 AM   #8
awbrown
I could write a novel on my truck , begining with the brakes having the adjusters on the wrong sides so they actually would loosen instead of tighten... Or the floor shifter that had a 2 inch throw for all gears ...and the list would go on and on ....
awbrown is offline   Reply With Quote
Old 03-13-2012, 08:40 AM   #9
vin63
It's Better With Nitro
vin63's Avatar
...drilled more than 90 extra holes through the cab (firewall, floor pan, back panel, and dash), some larger than two inches in diameter, that I'm welding back up.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 03-13-2012, 09:24 AM   #10
jbgroby
jbgroby's Avatar
er... for extra ventalation?
jbgroby is offline   Reply With Quote
Old 03-13-2012, 09:35 AM   #11
srziemkowski
srziemkowski's Avatar
For tossing out the ignition switch and just using the touch the wires together to get it to start method,then to run the electric fans,touch that wire to the ignition wires,nice,then wire would get hot. Love it
MY ADDICTION
STAN THE MAN
srziemkowski is offline   Reply With Quote
Old 03-13-2012, 09:59 AM   #12
Rich 5150 69
Rich 5150 69's Avatar
Not only did they cut my doors for speakers but used the same hot wrench on the inside of the door to open it up more with a 6x4 hole to get the window mechanism out, I have picked up to xtra junk doors for free to repair with...
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 03-13-2012, 10:49 AM   #13
Bears63
...just another truck junkie..
Bears63's Avatar
My '63 I actually have no complaints on but that's mainly because I'm only the 4th owner. My '71 was another story though.... Lot's of headscratching on that one.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 03-13-2012, 10:50 AM   #14
chevyrestoguy
chevyrestoguy's Avatar
You too, huh?
What is it with guys who like to drill holes? My driver's door has 9 drilled holes in it for all of the rear view mirrors the previous owner had.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 03-13-2012, 11:43 AM   #15
Rich 5150 69
They all wanted thru cab ventilation...
Old 03-13-2012, 12:04 PM   #16
chevyrestoguy
Was that the precursor to Astro Ventilation?
My build threads:
Old 03-13-2012, 12:26 PM   #17
Corts60
Just here to tinker
Corts60's Avatar
. . .they screwed a piece of plywood down over the space saver so I was "screwed" on the side of the road (old Corolla).
Old 03-13-2012, 12:30 PM   #18
vin63
vin63's Avatar
Originally Posted by chevyrestoguy View Post
You too, huh?
Ugh...the PO mounted everything to the firewall (front and back), had at least two different sets of seats (other than the original bench) and seat belts - apparently he had to drill a new set of holes in the floor for each set of new seat belts, a gun rack and he used sheetmetal screws to mount his speaker boxes behind the seat.
Old 03-13-2012, 12:42 PM   #19
K98AL
K98AL's Avatar
PO had apparently had a huge camper on my '62...drill all kinds of holes in the cab and roof. I like this big one, though.....
Put lots of dents in odd places, and the rust is unbelievable! I went to Wichita to get this truck, I can't believe how much more rust a truck up there has than an Oklahoma truck!
PO also rigged some "helper" leaf springs on the back, not quite as nice as the factory ones.
K98AL is offline   Reply With Quote
Old 03-13-2012, 02:16 PM   #20
MisterC
MisterC's Avatar
...for primering over what was probably a pretty nice patina of the original paint. Like others, I have the speaker hole cutouts in the doors to complain about and a crapload of toggle switches I've had to trace down. I think they were jerry rigged kill switches a.k.a. anti-theft.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 03-13-2012, 02:49 PM   #21
Rich 5150 69
You`re one of the lucky ones, post CB antennae holes...10-4 good buddy another convoy....
Old 03-13-2012, 05:41 PM   #22
62 mark
62 mark's Avatar
Ah yes...I think i have welded shut like 20 drill holes in various places,SO FAR. I really loved the hackmaster clutch setup,somebody apparently didn't want to fix the hydraulic clutch on my 62,so they cut a hole in the floor and rigged up the z bar clutch linkage.
62 mark is offline   Reply With Quote
Old 03-13-2012, 06:24 PM   #23
FreakyMalo
FreakyMalo's Avatar
...they didn't keep the rear seats!
66 Carryall
my photos
FreakyMalo is offline   Reply With Quote
Old 03-13-2012, 06:33 PM   #24
maxwoof
For throwing out the parking brake hardware from my 12 inch drum brakes.
maxwoof is offline   Reply With Quote
Old 03-13-2012, 06:47 PM   #25
suzq044
Resident Photoshop Nerd
suzq044's Avatar
Hmm.. List:
- Rattle-Can-o-flage paintjob + fish sticker (you can still see some of it in the sig pic) It was originally a white truck; 2nd owner got it in the lime green with astroturf roof.. (base coat in the can-o-flage); then let his kids go wild with a set of rattle-cans.. and an apparent sticker of a large-mouth-bass. lol
- 6 holes in either side of the body for what we assume would've been ladder racks
- 6 holes per driver-door for various mirrors over the years.. only 1 was on the truck when we got it.
- taking out stock seat to bolt wood and car-seats there instead.
- astro-turf roof - still needs to be removed for new rattle-can paintjob. (lol, i know)
It's not exactly a rust inhibitor either. <_<
- puttng a 283 intake on a 400 block. We thought it was the original block, because we couldn't see the numbers on the block itself; so, until we started the rebuild, we had no clue. So yes, we have a 400sbc with a 283 intake. Hopefully we'll fix that.. time & budget allowing).
- apparently driving by braille . There is a major dent/damage/attempted repair on every corner of this truck. Both front fenders, both rear fenders.. not to mention the hood. At least you can say, it survived.. we haven't really been down to the body-work so there's probably more 'fun' there.
unfortunately i can't blame the p/o for the rusted floor panels <_< lol
PJ - 1966 C10 Panel --
Max˛ - 1964 Jeep Wagoneer Panel-delivery -- Waiting his turn
suzq044 is offline   Reply With Quote
