View Poll Results: If you had the option, which of these grills would you use?
Original 66 painted grill 1 20.00%
64-66 C60 painted grill 2 40.00%
an original aluminum grill that needs to be restored 2 40.00%
the repo aluminum grill that is now available 0 0%
Voters: 5. You may not vote on this poll
Old 10-28-2021, 10:40 AM   #1
88Stanger
88Stanger's Avatar
Re: pdx-sanity66
This is and a few others are getting me excited to get back at mine, been a while, life happens..... anyways, thanks for the motivation!! Looking good sir!
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 11-11-2021, 11:20 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: pdx-sanity66
It already looks good now, I can't wait to see it in final color
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 11-12-2021, 05:41 AM   #3
jmarkha1
Re: pdx-sanity66
looking very sharp - nice to get everything lined up and squared away before paint - that light timber will look great in the bed...
1965 c10 project - how does all this stuff go back together...
jmarkha1 is offline   Reply With Quote
Old 11-21-2021, 12:08 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: pdx-sanity66
Yep I like the white oak the best.
Old 11-23-2021, 11:20 AM   #5
88Stanger
88Stanger's Avatar
Re: pdx-sanity66
Looking Sexy there sir!! I hope to be back on the "66 soon. The "69 is almost wired up and ready to fire up. Then, on to the "66. But damn nice work here sir!
Old 12-05-2021, 08:21 PM   #6
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Thanks Christian, I can't wait either. I, at least, need to get the roof painted white and the windshield and rear glass installed, then I can actually drive the truck more than just around the yard and get a front end alignment.
Thanks, I would have had a real problem if I didn't. I think the wood will work out nice down here in southern AZ.
I wanted something light and I fell in love with it. I hope it all works out. I have very little experience with wood finishing and I'm trying to decide on finish. Any recommendations are welcome.
I'm looking forward to you getting back on your 66.
I've got the alignment of the doors, cowl, cowl extensions, fenders and hood all aligned pretty good for now and I'm ready to spray some high build in the hood sides and front. I got my seam sealer delivered so I will prepping and spreading seam sealer on the roof channels today.
Then starts the bed wood install so I can measure and mark the holes I need to drill.
Oh, and I have been working on restoring my window crank assemblies. They had a lot of surface rust and some very light pitting on one of them. I soaked them in CLR and water
for about 3 days They came out great. I've got new rollers ordered fir them.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 12-05-2021, 11:02 PM   #7
cwcarpenter98
Re: pdx-sanity66
On the wood, I made the mistake of not using a good sealer when I put new wood in. After about a year, the color dulled and just overall looked sad compared to what it was when fresh. I finally decided to pull the wood back out, sanded it down, and reapplied the same stain/sealer combo I had used before. The second time around, with about 2 years or so of sun damage, led to the color of the wood being darker. I actually like the darker color in my application. The stain I used was a pecan color.
To finish it off the second time, I used a generous helping of Spar Urethane. That sealed the wood up nicely, and after a year of sitting in GA weather, I haven't noticed any change in the color of the wood
Christian Carpenter
Old 12-13-2021, 01:09 PM   #8
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
I am planning on spar urethane on mine. I've been researching on brands and quality of products but I haven't really decided which one yet. It will be a clear. I want to keep it as naturally colored as possible. I'm hoping this will help with our southern Arizona sun. What brand spar did you use?
Sanity'66
Old 12-13-2021, 01:12 PM   #9
cwcarpenter98
Re: pdx-sanity66
I don't remember, but I had some leftover. The can is in the basement, so I'll check later today and edit this reply with the answer
Christian Carpenter
Old 01-07-2022, 01:34 PM   #10
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
It's been about 3 weeks since I last posted but things have been moving along. ai have been working on aligning all the gaps to a reasonable point that I know now that it's all working together. A couple of very slight adjustments to the driver door but I just don't want to remove the fender and cowl extension at this point. I have also seam sealed the roof channels which is something I had almost forgot about. My thinking the roof was ready for paint was incorrect. Now it's ready for paint. The hood and cowl were the most difficult to get aligned. The center couple of feet of the hood to cowl was too close when I got everything else aligned. I finally decided that the cowl was twisted and just kind of off. I vaguely remember when I was taking the truck apart that the cowl seemed a little tweaked. I just couldn't get it right, so I took the one off of the C60. It is in very good shape so a last minute change is to get it stripped, primered, and installed. It fits way better than the old one.
I've also been working on the tailgate and getting the bed aligned. I'll try to post a little more frequently and show more of my progress.
Sanity'66
Old 01-07-2022, 06:07 PM   #11
The Rocknrod
Moderator
Re: pdx-sanity66
I used Epiphanes (epifanis) on my wood, a Dutch marine finish. It's not cheap and much work. But I expect it will be worth it?
Old 01-08-2022, 12:33 PM   #12
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
I've looked at the Epiphanes and it's on the list. It's great to see someone that has used it. Question: How many coats did you apply and does it change the color of the wood?
I'm going to try and get Sanity cleaned up a bit before proceeding and then it's time to work on the bed and get the holes marked for drilling.
Sanity'66
Old 01-08-2022, 01:05 PM   #13
clemdaddy
clemdaddy's Avatar
Re: pdx-sanity66
Looking good. Getting very close now.
I use the Minwax Helmsman Spar Urethane mainly because its available at the local hardware store. 6 coats on top 4 on bottom, with 180 sanding in between.
The thing that got the best results was to apply with a foam brush.
clemdaddy is offline   Reply With Quote
Old 01-08-2022, 02:39 PM   #14
The Rocknrod
Moderator
Re: pdx-sanity66
I think it was eight coats at least. It makes the wood slightly darker. I got the wood from Mar-K though. Cab reflections in this pic.
Old 01-10-2022, 01:09 PM   #15
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Your bed looks fantastic. The min-wax gets pretty high ratings so I might try it. I was thinking about 6-8 coats so that id good to here. I bought the complete bed kit with the optional white oak.
I've been putting off doing some media blasting. I enjoy the blasting, but I hate setting up and cleaning up afterwards. I have a few parts that I accumulated and I'm needing a few of them now. I have the cowl and front grill from my C60 done. Today I hope to finish up the inside door panels and a bit more on the rear inner fenders. I was busy cleaning up last night, so I'll post up some pics later.
Sanity'66
Old 01-11-2022, 12:29 PM   #16
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Here's the cowl and C60 bumper all clean and pretty. I still can't believe how nice these are. just 2 small dings on the grill. I'm running low on media so I'm going to get some more today. I've got the 2 inner fenders about half done and I haven't started on the 2 inside door panels. I hope to get done shopping and do more blasting this afternoon. The last is my tailgate that I'm working on.
Sanity'66
Old 01-24-2022, 04:08 PM   #17
The Rocknrod
Moderator
Re: pdx-sanity66
PM'd you on Tucson painters.
Old 01-25-2022, 12:23 AM   #18
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Thanks for the leads, I'll check them out
Sanity'66
Old 01-26-2022, 01:10 PM   #19
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
I decided it was time to put my gear shift knob back on. I set it up earlier but it wasn't working good and the nut I glued in came off. I had drilled a hole in the bottom and then filed it out to the size of nut I needed. This time I used a flare nut and epoxied it in. I also added some green eyes out of a couple of faceted beads. Wicked!
Sanity'66
Old 01-30-2022, 12:11 PM   #20
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Here are a few pics on what's been going on around here.
dash with gear shift installed
rear inner fenders temporarily installed for marking bolt holes in the bed wood.
I got the windshield wiper motor ready to install.
I'm also working on the restoration of my steering wheel. It has been completely stripped and the cracks have been ground out and is ready for filling the cracks today.
Sanity'66
Old 01-30-2022, 07:10 PM   #21
The Rocknrod
Moderator
Re: pdx-sanity66
Nice looking gauge panel on that dash.
Old 02-01-2022, 01:24 PM   #22
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Thanks. I'm very happy with the results, so far. I can't wait until I finish the deluxe wheel restoration and get it on the truck.
Here are a few pics of the steering wheel work. These show the two main cracks on both arms of the wheel that have been opened up and ready for filling and a few of the smaller cracks. I removed the 4 chrome goodies on the wheel end there are small cracks on the back side of the wheel that will need attention. I have opened up the cracks and started filling with JB epoxy putty.
Sanity'66
Old 02-06-2022, 12:51 PM   #23
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
I've got all of the cracks opened up, filled, and sanded on the wheel. Today I plan on spraying with plastic adhesion promotor and epoxy primed. I am also going to test the wiper motor and install it if it tests out ok.
Sanity'66
Old 03-13-2022, 02:44 PM   #24
The Rocknrod
Moderator
Re: pdx-sanity66
Nice work.
Old 03-18-2022, 12:28 PM   #25
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Nice work.
Thanks, I don't have much left that I can do before paint. If I can get the roof painted (white) then I can get the glass installed. Then I can actually drive the truck and get to testing the drivetrain and get the front end aligned. Right now my driving has been limited to around my yard and in and out of the garage.
Yesterday I decided to finish cleaning up the wiring under the dash, finish the install of the cig lighter, and clean up the wiring on the trans temp gauge. I have been having some trouble with the driver's seat adjustment so I decided to remove the seat and repair the slider. This also allowed me to work under the dash without trying to squeeze into places that this old body has no business being. I'm still creaking from the wiper motor install. I've got all the wiring tucked in and routed where it needs to be so today will be to put the temp gauge back in,repair the seat slider, and put the seat back in.
Sanity'66
