Old 03-23-2012, 07:58 AM   #1
naphtali5725
naphtali5725's Avatar
Smile My new project 86 Silverado
Here is my find, was sitting in a field 13 years, had a few trees growing around it. scored it for 1200.00.
it is a 86 Silverado, cruise, tilt, power windows/locks, ac. It has a 305 4bbl, with a swapped in TH400. It currently is sitting with only the cab on it, as I am in the process of doing a frame off. It will have all trim removed, has surface rust only, all panels straight, and will be flat black once it is done. I hope to start a build thread once real warm weather starts here in the mountains
Kind regards,
naphtali5725 is offline   Reply With Quote
Old 03-23-2012, 08:20 AM   #2
Big Blue
Big Blue's Avatar
Re: My new project 86 Silverado
Welcome naphtali5725, Great looking 86. I like the style truck.
Keep us informed on you progress.
John
Big Blue ( John )
79 Chevy Pick up.....My Dailey
STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in.
Big Blue is offline   Reply With Quote
Old 03-23-2012, 08:53 AM   #3
bbbc10
Diggin The SquareLife
nice start!!!
bbbc10 is offline   Reply With Quote
Old 03-23-2012, 12:12 PM   #4
Lost 40
Lost 40's Avatar
Welcome. I have an 86 Silverado as well, and look forward to hearing more about your build.
1986 Chevy C10
2" Drop
350 SB
350 Turbo Trans
"Keep it rubber side down, in between the ditches"
Lost 40 is offline   Reply With Quote
Old 03-23-2012, 12:37 PM   #5
bigsj
bigsj's Avatar
Thats a good starter truck .
bigsj is offline   Reply With Quote
Old 03-23-2012, 12:48 PM   #6
Pop's C-10
Pop's C-10's Avatar
welcome
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 03-23-2012, 06:16 PM   #7
SBTork
Garage wrench
SBTork's Avatar
make sure to take plenty of pictures for the build thread, it looks like a nice start!
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 03-24-2012, 04:57 AM   #8
bayou boy
bayou boy's Avatar
Nice start im in the same boat with ya good luck
all i know is that its going to be orange
bayou boy is offline   Reply With Quote
Old 03-24-2012, 07:44 AM   #9
naphtali5725
that's the route i'm going, all smooth, no aluminum trim, or any moldings.
good luck with your build, start a thread if you haven't already!
kind regards,
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
Old 02-10-2013, 04:39 AM   #10
naphtali5725
Well, i have decided to keep the 86 Silverado. I have an Oldsmobile 455 that I got from X-cabsquarebody on c10forum. I was also given a complete engine rebuild kit for it, pistons rings, etc. etc.
I have an engine builder in SC. that donated their machine shop services, and their time to put it together for me. The engine will be a torque monster.
Truck is down to the rolling frame now, and pressure washed, and cleaned as much as possible. I'll attach pics to this thread as soon as I can. I am probably going with the budget build route, and probably will not paint a lot of stuff...that's just how it goes, function over form.
I'm going to follow my buddy X-cabsquarebody's recommendation of leaving the body alone, and keeping the patina finish, and not priming/painting it.
I just got a new cab bushing/bed mount kit from LMC, so I can get the cab/bed back on here in the next few weeks.
I'll be taking apart the front suspension in a few days, and will replace all upper/lower control arm bushings/ball joints etc. I should have those in a couple of weeks as well.
stay tuned...
My build thread...
Disabled Veteran
Old 02-10-2013, 04:51 AM   #11
naphtali5725
Body pics - as you can see, this truck's panels are very straight
My build thread...
Disabled Veteran
Old 02-10-2013, 04:53 AM   #12
naphtali5725
more body pics
My build thread...
Disabled Veteran
Old 02-10-2013, 04:56 AM   #13
naphtali5725
rolling frame
My build thread...
Disabled Veteran
Old 02-10-2013, 04:59 AM   #14
naphtali5725
truck has some really nice options... here's the original build sheet...
My build thread...
Disabled Veteran
Old 02-10-2013, 05:20 AM   #15
INSIDIOUS '86
INSIDIOUS '86's Avatar
Man I actually kinda like the patina. It's straight as hell. I would lower it and tint the windows and make the inside comfy as hell and a newer style or injected engine underneath
But that's me
Loom forward to seing how it turns out. Make it yours!
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 02-10-2013, 05:43 AM   #16
naphtali5725
Thanks insidious for the comments
I'll need to have tinted windows anyway, because I am sensitive to the light and it gives me migraines.
As far as the engine, the Olds 455 big block makes tremendous torque with minimal modifications. A bone stock 455 with 10:1 compression and stock camshaft makes 350HP and up close to 450 ft lbs of torque at low rpm, so it's the perfect engine for a heavy truck (plus it was all free)
I want to lower it too, but I do not want to cut the frame for a C notch or anything like that, because I want to keep the frame intact. I'd like a nice coil over suspension front/rear though
My build thread...
Disabled Veteran
Last edited by naphtali5725; 02-10-2013 at 05:46 AM. Reason: added info, corrected dumba$$ grammar
Old 02-14-2013, 12:07 PM   #17
naphtali5725
new project 86 Silverado build
Talked to my buddy X-cabsquarebody yesterday from c10forum... he gave me lots of advice regarding the procedures for Z'ing the frame, and the steps for lowering the rear of the truck... that guy knows his stuff, and is a good friend because he offered to assist me in any way I needed, and I appreciate it big time.
I don't know which way i'll go yet, so i'm just going to concentrate on rebuilding the front suspension since all of it is worn out or rotten because it sat for 13 years (all ball joints, upper/lower control arm bushings, tie rods, idler arm, pitman arm) have perished.
I have a 12 bolt rear I got from X-cab with 2 inch drop shackles.. not sure if i'll swap out the 10 until i pull the cover and check the gear ratio to determine what would be best for my engine/tranny (TH 400) combo
March 5th i'll be taking the engine to have it machined and assembled. Once complete should put out 450+ HP, and gobs of torque which the Olds 455's are known for.
So that's it for now... stay tuned.
My build thread...
Disabled Veteran
Old 02-14-2013, 12:25 PM   #18
Keith Seymore
Keith Seymore's Avatar
1st - nice find; congrats on the "new" truck
2nd - good job coming up with the original invoice. That's a good document to have.
3rd - I was just checking out the VIN and the build timing...Flint built 1986 truck - I may have built your truck. Depends on if it came through on first shift or on second shift.
Hopefully none of those fender bolts were crossthreaded...
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 02-14-2013, 12:50 PM   #19
69GWC
I had a 79 square with a 455 olds in it and man that thing would fry a tire..lol. I would have to show people the motor most would not believe it had a olds motor in it.
69GWC is offline   Reply With Quote
Old 02-14-2013, 01:53 PM   #20
Gigem
Gigem's Avatar
nice project, and thanks for your service...
1972 GMC Sierra Grande (current truck)
1980 Chevy Stepside (gone)
1987 Chevy Blazer (gone)
1972 Chevelle SS Convertible (gone)
1973 Chevy Corvette (gone)
1967 Chevy Camaro (STOLEN!)
Gigem is offline   Reply With Quote
Old 02-14-2013, 02:33 PM   #21
rs74
rs74's Avatar
Good job on the find. It is nice to see others going through the same process as I go through mine. I will be watching your build. Here is how mine sits today. Putting on a lowering kit and all new steering and suspension parts then its off with the cab and everything to the body shop. Good luck.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 02-14-2013, 02:34 PM   #22
naphtali5725
K
it's alright man, they are all out now anyway If you did build on it, that kicks ass, thanks man!
My build thread...
Disabled Veteran
Old 02-19-2013, 08:11 AM   #23
naphtali5725
Re: My project 86 Silverado
Well, looks like i'm going to have to wait a bit longer to start on my truck
My build thread...
Disabled Veteran
Old 02-19-2013, 01:16 PM   #24
jrblanke
Where in NC are you located? I am in Raleigh.
jrblanke is offline   Reply With Quote
Old 02-19-2013, 01:34 PM   #25
naphtali5725
i lived in Raleigh for a while, worked for IBM in RTP... damn, i hated the beltline and 540
moved to the mountains near asheville
My build thread...
Disabled Veteran
