Old 04-17-2012, 06:13 PM   #1
SB'72
SB'72's Avatar
Rear Disc Brake Kit
I am still trying to decide on the best bolt on rear disc brake kit. I have a 1972 C/10 1/2 ton 12 Bolt. Any kits stand out that are better than others, or kits to avoid?
SB'72 is offline   Reply With Quote
Old 04-17-2012, 07:12 PM   #2
Scottshotrods
Re: Rear Disc Brake Kit
We have good deals on CPP rear brake kits and yes we have them in stock and yes they will ship out very quick.
We also have Wilwood rear brake kits in stock to and yes they are a little more money but not buy much.
If you are looking for something give us a call at
(805)485-0382
orders only (800)273-5195
e-mail
justin@scottshotrods.com
scotts@scottshotrods.com
jeff@scottshotrods.com
sales@scottshotrods.com
Scottshotrods is offline   Reply With Quote
Old 04-17-2012, 07:42 PM   #3
VA72C10
VA72C10
VA72C10's Avatar
Are you definitely wanting a "kit" or is budget a consideration? You can get rear brackets for the calipers and pick up some rotors and used calipers w/ or without e-brake for much less than the "kits"...you can even cross drill your own rotors...
Or are you looking for big brake performance? If so, consider mcGaughy's as well as Willwood and CPP
For basic or big brake kits, CPP does have good ones and buying from someone like Scottshotrods is good because CPP has many reported cust service/shipping issues but good product.
Another option is POL...they have some good products and are usually a little cheaper...
Old 04-17-2012, 08:02 PM   #4
jtp67-72
jtp67-72's Avatar
Tobin at Kore 3......sells this c6 setup...shown with inboard parking brake option....jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 04-17-2012, 08:02 PM   #5
jocko
jocko's Avatar
I believe (but don't quote me on it... ) that CaptainFab makes some adapters/brackets (or something) to facilitate use/adaptation, etc (?) of newer Impala SS rear disk brake components. Might be worth asking him about that.
Old 04-18-2012, 09:29 AM   #6
SB'72
SB'72's Avatar
I have looked at mostly the kits. I came across the mcGaughy's kit, and from what I read it said that the axles would need to be machined to work, maybe that's the case with all of them or maybe if brackets arent' used.
Thanks for all the feedback
Old 04-18-2012, 10:18 AM   #7
71 super
71 super's Avatar
I put rear disc on the 68. It was a kit I purchased from ebay from seller isanti lawnman. It Was $399 and was complete. Only things I had to purchase were a pair of axle seals (not necessary but since I was there) a rear cover gasket, 2 cans of brake clean to clean everything up and some rear end dope. The kit installed very easily and the rotors were cross drilled and slotted. The truck stops great, only small issue was the intermediate cable was too short for use with th400 trans, so that will have to be made as the e brake cables are shorter than the originals. For $ 450 shipped to my front door I was really pleased.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 04-18-2012, 04:43 PM   #8
VA72C10
VA72C10
VA72C10's Avatar
Do you have a link to that kit? Couldn't find that seller on ebay...
Old 04-19-2012, 10:29 PM   #9
weircc
weircc's Avatar
i like the cpp kit with willwoods and slotted rotors shipped for 600.00
1971 rs camaro under the knife ls3 6 speed swap
1970 396 big block shorty fleet 67 clone
2010 rs/ss camaro
weircc is offline   Reply With Quote
Old 04-20-2012, 10:02 AM   #10
turp mcspray
turp mcspray's Avatar
I bought a CCP kit for a truck a couple of years ago. It uses the seville caliper style setup. The kit from isanti lawnman (which is Auto City Classic, if you've ever read a Hemmings, you have seen their ads) uses the same application of parts. I just talked to Chris over there last week. Their kit is the same as the one I purchased from CCP, only $200 cheaper, plus it has drilled and slotted rotors. I priced out buying their brackets ($75), and piecing it together myself, and it will cost more than their kit does.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 04-20-2012, 01:19 PM   #11
Tmwoodall
Is that without emergency/parking brake? CPPs descriptions often suck.
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline   Reply With Quote
Old 04-20-2012, 01:59 PM   #12
Fldawg
Fldawg's Avatar
i purchased there brackets and put together my own kit and saved $100
by using 88-93 k1500 rotors and s-10 metric calipers, that allowed me to use my 15" rims,
Fldawg is offline   Reply With Quote
Old 04-20-2012, 03:53 PM   #13
Tmwoodall
Did you have to modify your axle/housing at all for this kit? Do you know which kit specifically you bought?
Old 04-20-2012, 08:15 PM   #14
jtp67-72
jtp67-72's Avatar
This was the big bearing ford kit..5 on 4 1/2...but he has it for stock 12 bolt I think...quick call to Tobin will tell the tale.....your axle will have to be cut down to their specs in the area outside of studs.....but Tobin will have specifics......great guy...fast shipping.......super knowledgeable ....won't steer u wrong.............jim
Old 04-20-2012, 11:05 PM   #15
71 super
71 super's Avatar
VA I will look back through my close auctions and get the info for you, Harold
Old 04-21-2012, 08:03 AM   #16
weircc
weircc's Avatar
without..... and its on sale right now 540.00 i think im not running a e/brake just for the simple fact i have an automatic but thats just me ordered min yesterday
2010 rs/ss camaro
Old 04-21-2012, 09:46 AM   #17
big_al_71
big_al_71's Avatar
(805)485-0382
e-mail
I can vouch for the kit mentioned above which I bought and installed in my truck....Well worth the money and there are zero issues..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 04-21-2012, 02:00 PM   #18
big d's red67
big d's red67's Avatar
Who did you buy your kit from?
1967 swb 454 cid 700R4 trans SOLD
2006 Chevy Trailblazer SS
2013 Camaro RS convertible the wife's
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248
big d's red67 is offline   Reply With Quote
Old 04-21-2012, 02:23 PM   #19
into69z
"brand new second-hand"
into69z's Avatar
........or you could open up the April issue of Car Craft magazine (page74) and see how to convert with some used part from your local junkyard-all the info needed for factory style disc brakes
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
Old 04-21-2012, 06:53 PM   #20
Tmwoodall
Al, I've seen your setup come up in several threads now. I keep going back and forth due to not having a parking brake. I only care due to state inspections. I'm done debating, going to weld up the holes tomorrow and move on. Surely I can find someone who won't check that.
Old 04-23-2012, 06:15 PM   #21
Scottshotrods
We have the Cpp rear disc brake kit with no parking brake going for $449.10 at this time and they are shipping out fast and we have some more coming in to the shop
Let us know
Justin
805 485-0382
Old 04-23-2012, 10:00 PM   #22
Tmwoodall
Let us know
Justin
805 485-0382
Justin how much more for the wilwood kit?
Old 04-24-2012, 10:20 AM   #23
Scottshotrods
p/m sent
Justin
Old 04-24-2012, 02:24 PM   #24
69sbchevy
Let us know
Justin
805 485-0382
Can you PM me a little more info on everything that is included in this kit for $449? Thanks.
69sbchevy is offline   Reply With Quote
Old 04-24-2012, 02:56 PM   #25
Scottshotrods
p/m sent
Justin
