Old 05-02-2012, 03:33 PM   #1
Pro Performance
Pro Performance's Avatar
New!: Wilwood D154 Rear Brake Kit
Wilwood just released a brand new rear disc brake kit that uses the D154 caliper. This caliper resembles the D52 very closely. I wanted to share this new kit with everyone and let you know it is available:
$770 for slotted / drilled rotors
$670 for plain rotors
We offer Free Shipping on this item as always.
Features:
12" Rotor
Integrated Parking Brake
2-Piston Caliper
Red or Black Powdercoated Caliper
D154 Rear Disc Brake Kit
Pro Performance is offline   Reply With Quote
Old 05-02-2012, 04:31 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: New!: Wilwood D154 Rear Brake Kit
What about dimpled rotors? And what woul the cost of replacement rotors be? Both plain and fancy
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 05-02-2012, 06:39 PM   #3
Pro Performance
Wilwood just has the drilled / slotted rotors available. Replacement rotor pricing is below, but keep in mind, that rotors aren't replaced very often. But, I do agree, good to know what they cost if it is needed.
Plain Rotor: $158 ea.
Drilled/Slotted Rotor: $215 ea.
I was glad to hear they finally came out with a more affordable rear disc kit. I think for the price, it is a nice system with the integrated parking brake.
Old 05-02-2012, 08:04 PM   #4
INSIDIOUS '86
Some spendy rotors. But glad to see the kit is very affordable indeed.
Now are the calipers upgradable or is that a whole other kit entirely?
Would have liked seeing a 13" rotor option
Old 05-02-2012, 08:43 PM   #5
Pro Performance
Calipers aren't upgradeable, as it would require a new bracket. By the time you get the new bracket and bigger caliper, you would probably be at the cost of the next kit up.
This is the nextstep up with a 13" rotor
13" Wilwood Kit
Baer 13" Rear Kit is a little more affordable considering the Wilwood 13" kit.
SS4 13" Baer Kit
Old 05-03-2012, 09:21 AM   #6
hartbraker
what kind of kits do you have available for k30's. I already have rear disc brakes on my corporate 14 bolt FF and they are the same calipers that are on the front of a k20. But my front calipers are quite different. They have the pin that drives in to hold the caliper in place... which I believe is specific to 1 tons... Not sure. Any information would be nice.
1986 Chevy Silverado k30: factory air, tilt wheel, 454cu 7.4L, Turbo 400, NP205, Corporate 14 bolt, Dana 60 front, 4.10 gears, SRW, long bed, standard cab... MY TRUE LOVE
hartbraker is offline   Reply With Quote
Old 05-03-2012, 10:17 AM   #7
Jonboy
Slots go on anything!
Is there any chance these will clear 15" wheels?
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 05-03-2012, 04:59 PM   #8
Pro Performance
Wilwood claims a 16" is the smallest. I will have the actual digram of the brake soon, and I can let you know what the overall diameter of this brake kit. It may fit inside some 15" wheels, depending on the style and where the drop center is.
I will keep you posted.
Old 05-03-2012, 08:41 PM   #9
Pro Performance
The radius of this kit to the top of the caliper is 7.5" (15" diameter), so I don't think this is going to work inside a 15" wheel.
Old 05-03-2012, 08:45 PM   #10
Pro Performance
Don't have anything for the front of K30's, like you said, because they are a different caliper. Not quite the same.
If I come across anything, I will let you know. Just from my searching today, I couldn't come up with anything in a aluminum style aftermarket caliper.
Old 07-01-2015, 10:53 PM   #11
Karl's Kustoms
Karl's Kustoms's Avatar
PM sent on 6-29. Please let me know prices when you get a chance.
Thanks,
Karl
Karl's Kustoms is offline   Reply With Quote
Old 07-02-2015, 12:06 AM   #12
UKNOWME
UKNOWME's Avatar
Does this kit come with everything needed to convert? Has the price changed in the last few years? Do they offer a matching front kit? Thanks for any info!
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 07-02-2015, 08:28 AM   #13
Pro Performance
Thanks,
Karl
Sorry about that, and we overlooked that PM. I just replied back.
The price went up $25, and the kit does come with everything needed to convert to disc. It will use a different e-brake pull on the backing plate, so an adapter or new e-brake cables would be needed. If not concerned about the e-brake, then nothing will need to be done here. The adapter runs about $30.
The best matching front kit, would be the D52 swap calipers. We do have a front and rear kit, that uses the D52's up front, this kit in the rear, new rotors up front, SS hoses and e-brake cables.
http://www.azproperformance.com/Pro1...Brake-Kit.html
- Travis
Old 07-02-2015, 08:36 AM   #14
UKNOWME
UKNOWME's Avatar
Awesome thanks! I'll be saving up for that.
1964 Chevy c10
Old 07-03-2015, 08:25 AM   #15
bdiamond
What kind of parking brake does it use? Similar to the late 70's Cadillac/Camaro or the newer little drum in the rotor?
Nevermind.... I looked it up. small drum style
bdiamond is offline   Reply With Quote
Old 07-05-2015, 07:38 PM   #16
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
How's about a rear disc conversion for an 87 1 ton 2wd crew cab dually?
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 07-06-2015, 12:06 PM   #17
Pro Performance
Unfortunately I don't have anything for the 8-lug stuff, in regards to brakes.
Old 07-07-2015, 02:16 PM   #18
Robert8096
Robert8096's Avatar
Do they make a complete front and rear kit? 1974 c10 with 1.25 front rotors. DJM 3 in drop spindles.
Robert8096 is offline   Reply With Quote
Old 07-07-2015, 11:19 PM   #19
85/Silverado
85/Silverado's Avatar
$770.oo for one disc brake setup. So you have to buy another for the other side?
85/Silverado is offline   Reply With Quote
Old 07-07-2015, 11:36 PM   #20
UKNOWME
UKNOWME's Avatar
That's a pair
1964 Chevy c10
Old 01-05-2016, 01:38 PM   #21
csfields
csfields's Avatar
I am getting this rear kit for my C10. You said there is an adapter for 25 bucks? Do you have them available? or part number? Does that mean you can incorporate the stock cable with the adapter?
- Travis
Thanks,
Casey
71 Chevy C-10 SWB 350/400 PS, PB
The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045
The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699
csfields is offline   Reply With Quote
Old 01-05-2016, 05:16 PM   #22
Pro Performance
The adapter clevis is Lokar PN: EC-80WC
Old 01-07-2016, 09:18 PM   #23
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Question Re: New!: Wilwood D154 Rear Brake Kit
Is the parking brake a built in drum style in the rotor or the goofy mechanical lever on the caliper type?
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 01-08-2016, 10:20 AM   #24
Pro Performance
Yes, it is a parking brake assembly inside the rotor.
Old 01-08-2016, 11:20 AM   #25
N2TRUX
Happy to be here
N2TRUX's Avatar
Digging up bones. Travis, what about a proportioning valve? What will you need ?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
