05-30-2012, 03:24 PM | #1 |
6>8 Plugless........
1989 Suburban "V Rig" Gets Cummins Power
This is a customer's of mine's truck. It used to be a City of LA Power and Water truck and is rust free. It has a 6" lift on 35's with custom diamond plate here and there. The NP205 in it let go and he had been wanting to upgrade this thing for a while. He mows lawns and is a full time fire fighter. He had a 02 F-350 7.3 DRW super duty, but sold it to get away from the Ia DOT regulations for commercial use. He sold the 350 and TH400 from this burb, and purchased a 92 Dodge for a donor. we're using the engine, transfer case, and axles from the dodge for this. We're using a 47RH and we're rebuilding it as well. Here's some pics.
Engine before pressure washing Engine in burb for mock up Right now I'm building the engine cross member and engine mounts. I will be using 1st gen dodge style, and using 2 per side. Let the fun begin!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 11-23-2012 at 03:04 PM. |
05-30-2012, 03:27 PM | #2 |
Re: 1988 Suburban "V Rig" Gets Cummins Power
The start of an engine mount
I have the intercooler out being widened and the new aluminum radiator needs to have bigger inlet and outlet installed in the tanks.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-30-2012, 09:13 PM | #3 |
Working fast on it man! Take pictures of the mounts. I want to see how you plan on doing thr two per side. That's what you told me to do so I'd like to see how you accomplishment that!
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
05-30-2012, 09:55 PM | #4 |
Have you tried using the chevy mounts? thats whats in mine, been working great for 6 years. I've busted the square older dodge ones in my scout with a 4bt!
what happened to the 205? looks like fun.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
05-30-2012, 10:48 PM | #5 |
man im digging that big yellow suburban.... i wish my garge would hold mine.
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
05-30-2012, 11:36 PM | #6 |
I doubt you'd break them if you get the poly ones. They're a lot stronger. The 205 input broke. It'll be fun when it's running again.
05-30-2012, 11:38 PM | #7 | |
05-31-2012, 10:50 AM | #8 |
Those mounts look pretty stout. Looking forward to your take on how you do it!
05-31-2012, 03:37 PM | #9 | |
Here is some cross member planning. I will build this out of 1/4" steel, and it will be a boxed in unit.
05-31-2012, 07:34 PM | #10 |
Looks like a good plan. Do you just have the motor setting on jack stands in there? It also looks like your going to have to do something with the water inlet? It looks like the frame is in the way.
05-31-2012, 07:58 PM | #11 |
Yes, the engine is sitting on stands, and the trans is sitting on the trans cross member. I haven't decided yet what i'm going to do for the water inlet, but yeah, it's not going to work right now.
05-31-2012, 09:36 PM | #12 |
must have it pretty low. I'm using that same water inlet on mine.
05-31-2012, 09:57 PM | #13 |
Yep, it's real low. Trying to keep u-joint angles and center of gravity lower. I might raise the engine up a little bit so I don't have to modify that inlet, but this truck has a weird firewall to floor flange. I had to cut 1.5" out of it and weld it back together to get the engine that far back. I've never seen one like it. I wish I would have taken pics before I cut it.
06-12-2012, 05:55 PM | #14 |
I brought the engine up a little bit, and have been working on the engine cross member. It shouldn't be long now.
This is what your work area will start to look like when you do one of these. The cross member will bolt in and will be fully boxed. It is made from 1/4" steel. The brackets in the frame are 1/4" as well. I doubt it will go any where.
06-12-2012, 07:00 PM | #15 |
sweet!!! I want a cummins powered chevy truck.. Seems you are ALWAYS swapping a cummins in something lol. I am gonna load up my 87 crew cab, a dodge for parts and drop off at your place... You should have it done in about 3 days seeing how fast you move lol.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
06-12-2012, 07:00 PM | #16 |
Looking good. How exactly are you bolting the cross member to the frame? It looks like you have ] shapes on the end of the cross member to go around the frame [?
PS: when are you bringing a trailer and picking up me and my truck and all its parts?
06-12-2012, 11:52 PM | #17 |
3 weeks, yeah, IDK about that. I tell you what, these chevys make me love the 86 up fords. The fords you don't have to build a cross member like this.
06-12-2012, 11:56 PM | #18 | |
On the PS, probably when you are on 2 feet and not back on a bucket behind things with 4 legs.
06-13-2012, 08:10 AM | #19 | |
... I dont even know how to respond to this.
06-13-2012, 03:30 PM | #20 | |
And
06-13-2012, 08:24 PM | #21 |
No I dont want to have to buy anything else for that motor! Seems like everything I am getting with it has to be changed for a dodge part!!!!
06-20-2012, 03:11 PM | #22 |
I've been working on this project, and making head way. I got the LH mount tacked together, and put the radiator support back on to make sure everthing still cleared. I removed the engine, and am now drilling holes in the cross member, and welding it up. I decided to go with a single mount on each side instead of two. I recently spoke with 2 old customers that I did conversions in 93-97 K30's, and they both wished their mounts weren't so rigid. They like that it's nearly solid, but don't like the entire truck shaking at idle. So, I decided to use one per side since this truck will more than likely see over 450hp, and the owner will daily drive it.
I ran out of wire, so I couldn't finish welding it up. Next thing is to get the axles out of the donor truck and get them ready for this.
06-22-2012, 07:45 AM | #23 |
Looks great buddy , you may want to add a little more support to the front steering box area while the engine is out . There is a a lot of stress on those thin C channel frames .
The push pull steering dose not work very well with GM's 4x4 design ... 2wd works fine . Looks like a nice conversion , I have the 1990 cummins build over in the Blazer / Sub section . |
06-24-2012, 02:08 PM | #24 |
Chevy Enthusiast
Nice project! Are you using the first gen intercooler, and what exactly are they widening on it?
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
06-25-2012, 01:49 AM | #25 | |
