06-19-2012, 05:09 PM | #1 |
1967 build laying bumper NO body drop!!
We are building a 1967 short box truck with as many 67-72 era parts as possible and modifiying what we need to, to get the air ride to lay the bumpers on the ground and ride height about 1"off the ground. You can check our progrees and shows we will be attending on Facebook at Kitsap Kustoms.
Other builds we are in the middle of are a 1969 suburban factory 3/4 ton 4x4 with many options and doing a 402 2 two wheel drive blazers one for SEMA and possibly Craig Jackson A 1972 super cheyenne mostly stock restore. and a custom crew cab longhorn 3/4 ton 4x4 402 with all original parts. |
06-19-2012, 05:35 PM | #2 |
Re: 1967 build laying bumper NO body drop!!
Fathers Day cruise ride height
06-19-2012, 05:37 PM | #3 |
short box frame and step side bed getting sand blasted
06-19-2012, 05:39 PM | #4 |
more bed and 3/4 1970 truck getting stripped for cab
06-19-2012, 05:44 PM | #5 |
original 402 getting rebuilt and used. Found two build sheets in the seat pretty cool
06-19-2012, 05:49 PM | #6 |
build sheets and blasting the frame and bed
06-19-2012, 05:50 PM | #7 |
sand blasting nothing fancy just getting it done
06-19-2012, 05:51 PM | #8 |
disk brake front 5 lug 3:73 posi axel factory 72 big block mounts
06-19-2012, 06:03 PM | #9 |
cnotch and 3' Z in the frame
06-19-2012, 06:04 PM | #10 |
got the back where we want it
06-19-2012, 06:07 PM | #11 |
cut sectioned and raised the center of the crossmember for ground clearance. New drop spindels, cut the front frame
06-19-2012, 06:09 PM | #12 |
3" Z in the front frame
06-19-2012, 06:11 PM | #13 |
got the height with frame we want with no motor or weight yet
06-19-2012, 06:11 PM | #14 |
Hmmmmmmmmmmmmmmmmmmm......
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
06-19-2012, 06:13 PM | #15 |
bed cab and nose on. also put a fleet side bed on. Not sure which one to go with yet
06-19-2012, 06:16 PM | #16 |
engine in
06-19-2012, 06:17 PM | #17 |
body work welding up holes and got stock steel wheels
06-19-2012, 06:19 PM | #18 |
C/10 junkie
I love the rear view mirror pic!!
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
06-19-2012, 06:20 PM | #19 |
motor tranny in tight but in and everything works. going for exhaust
06-19-2012, 06:23 PM | #20 |
06-19-2012, 06:24 PM | #21 |
rear suspension going to exhaust
06-19-2012, 06:52 PM | #22 |
custom watts link. first show did a 30 mile poker run didnt quite make it had to work some bugs out. I mean tighten the lug nuts
06-19-2012, 06:58 PM | #23 |
Kustom Kulture show
06-19-2012, 07:00 PM | #24 |
fathers day run 80 miles
06-19-2012, 08:17 PM | #25 |
Looks good.I like those rims.
