Pancaked Xmember Question
Hello Forum,
I have a 1965 C10. I'm converting to a 73' xmember, power steering, & disc brakes. I pancaked my xmember 1.5 and have 3 inch dropped spindles running 28 inch tires. I haven't installed the xmember yet and reading the forum I'm a little confused if I need to move the xmember 1 inch forward the rails to center the wheels in the wheel wells. I have read that this should be done when z'ing the frame but unsure if this is something I need to do with a pancaked xmember. Since I haven't installed the xmember and power steering unit yet, your comments and advise would be very helpful. Thank you. |
Re: Pancaked Xmember Question
I moved my homemade dropmember forward 1" as recommended by several, and am very pleased with the results.
I think all or most,of the aftermarket crossemebers do move forward. There are also some other steering/suspension geometry changes that I think they make to improve the drive quality,too. I made subtle changes to the caster angles to help improve mine, and to help the anti-dive while braking. In my opinion, if you're this far, I think you'll be pleased with the cosmetic appeal of centering the front wheels by moving the crossmember forward. it doesn't take alot to do it. |
#3 | |
![]() Join Date: Mar 2005
Question:
If you pancake a stock crossmember say, 1.5", are you automatically committed to raising the steering box the same amount? I see alot of threads about sectioning crossmembers, but I don't recall reading anything about adjusting the steering box to compensate. Steering geometry is a tricky thing, if you get it off by a small amount, you can have issues like bump steer.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
#5 | |
I did not mention in my post, but I installed rack and pinion steering, so I did not have to compensate for a steering box change. But that makes sense that some remounting would be necessary. I would think the same dimensions would apply- 1" forward and 1.5" up.
Not a great pic, but my crossmember installed with R & P steering
My crossmember raised the control arms 3" and moved forward 1" Last edited by tincan1966; 09-08-2012 at 05:54 PM. Reason: added text |
Hollister, CA.
![]() Join Date: Sep 2006
I am working on a Crossmember section HOW TO thread that'll be up soon, that will address the stock steering too.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
This is something I am wondering about myself I want to pancake mine 2 inches and didn't know rather to move it forward or not
![]() Posted via Mobile Device
1966 C10 short stepper KMHK ![]() |
#10 | ||
![]() I moved mine forward yesterday after Tincan1996's advise. It was pretty easy as he claims. I made a template, measured 10 times per side and drilled the holes. After installing the xmember, everything measured out correctly. I used a 1/2" Cobalt drill bit from ACE Hardware. Cost me $22.00 (ugh!) but I have to tell you, that is one of the best investments on a drill bit I have ever made. |
TY realnoisy! The first one is a bit rough and primitive, the second one is coming along smoother.
Thanks guys this info really helps me with my choices i have for the front of my truck and what needs to be done and looking foward to that thread on the pancakeing i have some how to photos but they are kinda skippy need a lil more detail than what i have thanks guys.
Cant wait to see the "How to" thread. Been looking at this as an option to the aftermarkets.
Betty : '63 Fleetside Longbed 350 w/ 4 speed CPP 3/5 drop with front sway bar. |
Here are some photos of my pancake/section xmember process. We used Cast 9/Super9 welding rods. I hope this will help someone as I have taken alot of ideas and advice from this site. Time to give back and hope I can give more in the future.
#15 |
Before running final bead and cleaning up.
#16 |
ok thats like what i have but you can see what needs to be done better in your pics than you can in this link http://www.captkaoscustoms.com/chopcross.htmland i have one for a raised x-member to but i think it will just open a big ol can of worms with clearance issues http://67-72chevytrucks.com/vboard/s...d.php?t=478965
#17 |
Great pics! So does this give you a couple inches more drop or is it mainly for those who bag their trucks and looking to lay frame?
#18 | |
#19 | |
Don't get me wrong, it's NOT a piece of cake. It's hard work and time if you want to do it right. You have to think about safety as well so it's important that you take your time and research everything. Go to Car shows, Swap Meets etc.. ask questions. |
#20 |
Hollister, CA.
Sectioning the crossmember is not only for bag use.
I plan on running a low static drop, but just wanted my crossmember to be up outta the way and level with the rest of the chassis....so in this case I went a FULL 2" and still plan on running the stock steering for the time being.
#21 |
this is good info. if you check out my pages you can see the clearance issues with a big static drop. i have 3in springs, 2.5in drop spindles, and another 3in in the control arms for a total of 8.5in of drop in the front. not much room for error while riding around. the rtear is only a 4in drop spring for now.
the Stealth Weapons 63 project, all comments, advice, and critiques welcome! http://67-72chevytrucks.com/vboard/s...d.php?t=438235 |
#22 |
No it's not just for bags basically what you are doing is sectioning the x-member to drop the frame down and from what I have learned about it so far is how much u section the steering must be raised just as much or you get killer bump steer correct me if I'm wrong with any of this as I have not done this yet but I am thinking it over really hard check out Dino's dually build that's where I learned about the steering needing to be lifted so you don't have to use a rack set up when mine is finished if I do this I'll have a 8X8 drop 3" spindle 3" spring and 2" pancake up front and a 5" spring and 3" block in the rear with a notch and adj trac-bar hope this is a lil help any way
#23 | |
#24 |
I agree that sectioned/pancake xmember is not just for bagged trucks but that is a lot of work for 2 inches on a static drop. Since I'm converting to a 73' xmember to gain disc brakes, power steering the time was right to section.
IMO, you could DROP CUP LCA's, drop LCA's 2 inches, Zframe or cut coils to gain 2 inches much easier than sectioning the xmember. |
#25 |
DROP LCA's 2 inches - http://www.jalopyjournal.com/forum/s...d.php?t=570568
