Old 09-19-2012, 03:12 AM   #1
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
HOW TO: Crossmember sectioning ...
As most of you know, I’ve been working on my 62 GMC Suburban.
I picked up a '78 Crossmember with PS and steering linkage off CL for cheap.
I decided for now I wanted to set up my suspension for a loooow Static drop, as I'm not concerned with Air-ride at the moment. (I'll save that for my customers )
I can’t afford one of PorterBuilts AWESOME creations, so I knew I was on my own.
To accomplish this, I knew the crossmember had to be raised. But how much ??
So, before making any cuts, I took some measurements.
I did this by first leveling the Burban to the ground, checking both the chassis and the body. Measurements could of been done with a complete vehicle, but in this case, it is on stands:
For future reference, temporarily installed the stock front suspension, and marked the spindle location to my garage floor:
Measurements were, First ground to crossmember, then ground to chassis:
As you can see, the difference was 2”.
Sectioning the crossmember this amount would raise it level with the remainder of chassis.
I viewed CapKaos’ great method and decided this is the way to go.
As many of you know, I love providing pics … so more detailed pics were used here.
I could of done all this in my shop with my nice big welding tables, plasma cutter, etc.
But this was done at my home garage….basically to illustrate anyone can do it.
In fact, all cuts were made using a cheap $14 HarborFreight grinder, and lots of wheels.
NOTE: I did not like the HF cut off wheels. They vibrate a lot, and do not like a little ‘side’ load. What I mean, is I use a cutoff wheel on its side to clean surfaces, which caused it to come apart quickly and violently . The grinding wheels suck too …
Instead, I chose the DeWalt cutoffs from Lowes, as they were priced just over a dollar.
If you have access to a Plasma…BY ALL MEANS USE IT !! It will cut your time down considerably !! Regardless of what method you choose, your still going to need a welder.
Another thing I should mention….As you can see I started with a ‘loose’ crossmember. In the past I have removed them with engine in place. (By supporting engine across the inner fenders). But, unfortunately, this is not shown here. If your doing this on a running truck, SAFELY remove crossmember !!
So….here we go !
Since they were right there like two arms, I used the frame rails of the Burban as a ‘table’ , and leveled the crossmember.
Once leveled, I scribed vertical alignment marks on the crossmember. These are used to align the upper section down to the lower once the side material is removed. All my fancy squares are outta town, so here is my creation….
Hard to see scribe marks here…but later used a Silver Sharpie…If you look closely you can see FOUR spotwelds just above the Ubolt bolt holes …
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 09-19-2012, 03:12 AM   #2
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: HOW TO: Crossmember sectioning ...
Back side as well. Scribes were made where crossmembers shape start to change anlges upwards, if you will.
Next I made this little device to help me scribe the line. It measures ˝” and 1”. I measured down from the top ˝”, then connect the vertical lines….
From the top line, I measured down the required amount…in this case 2”…
A quick trip to Staples scored me the cool Silver Sharpies ….
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 09-19-2012, 03:13 AM   #3
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Now that we are all marked up, the crossmember needs to be braced before we make major cuts. Since I need to fit a grinder, I made the top slices before adding the brace.
Rather than weld a brace to the towers, I uses an old junkyard steering arm and some angle. Now I have another ‘tool’…. for future chops
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 09-19-2012, 03:13 AM   #4
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
For lack of a welding table, I relocated to my red cart, which typically holds my Plasma. Leveled cart, then tacked the crossmember to cart…
Then … carefully begin cutting. If you notice, I did not weld a brace across the top plate because I am using cutoff wheels which do not generate much heat. Otherwise I would have. However, that piece of angle was tacked to top, before welding …
And, just like some oysters on the grill…we crack this thing open ….
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 09-19-2012, 03:14 AM   #5
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
These tabs are part of the formed bottom plate of the crossmember. They are on all four corners, and are held in place by the four large spot welds mentioned earlier.
Next, you remove the amount of your ‘section’ …. In my case 2”….
After removing the two inches, the top of tab was been removed, along with the upper two spot welds. I cleaned this area, and fully welded it on both sides.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 09-19-2012, 03:14 AM   #6
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Now is a good time to clean whatever grime is on the inside of the crossmember … especially the bottom …
Here you see where I welded the tabs:
Not needed, but what the heck:
You can see the importance of good, square measurments:
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 09-19-2012, 03:15 AM   #7
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
After making all my scribe marks line up, I set the level across the top half. A little grinding here and there was needed to get it perfectly level. Also, depending on how much you remove, the top and bottom portions will be a little ‘off’. This is because the crossmember tapers and gets wider at the bottom.
Shown here:
To solve this problem, some “relief” cuts were made, and the old BFH was brought out to help out …
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 09-19-2012, 03:16 AM   #8
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I even marked the location of the where I originally leveled it …
Once you have this thing LEVEL … tack in a few places, then start your welding. I started in the front and rear middle areas …
As needed, use your BFH and maybe a blunt punch to help you persuade the metal . I finished up all the seems, including the reliefs…
The back side came out pretty good, so I decide to leave the welds ‘as is’ with no clean up…
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 09-19-2012, 03:17 AM   #9
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
THIS IS WHERE ALL YOUR HARD WORK STARTS TO PAY OFF !!
After a little grinding (ok, a lot) and some sanding … It’s starts to look like nothing ever happened…
In certain places … You might need to go back and do some ‘fill in’ with your welder, and resand. As I will …
But overall, it’s coming along pretty nicely …
Again, the back side might be left as is … only attention to the nipples on the sides (they always get my attention) …
NOTE: Another option instead of the 'relief' cut would be to cut around the "nips", then weld them back onto the top half. I chose my method because I thought it made the crossmember look a little cleaner ...
** UPDATE **
Before calling it good, I performed a test fit. You may find areas that need attention, either triming, and/or more welding/fill in as shown in the last two pics. Other than that, look at the clearance we gained, not mention the 2" drop off the get go without touching any other suspension component...
You may also notice a driver side later 70's V8 motor mount. If it seems a little tall, that is because the '63 and later frames are taller. So this '62 chassis will require a little spacer. It will work out, as the spacer will be part of the upper bracing as well.
Also keep in mind this modification DOES NOT change the position of the engine.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 09-19-2012, 03:18 AM   #10
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
To complete crossmember, side templates then plates were made and welded up:
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 09-19-2012, 03:18 AM   #11
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Blank for more pics .....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 09-19-2012, 03:18 AM   #12
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Blank for more pics.......
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 09-19-2012, 03:20 AM   #13
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I will be updating chassis mods for stock steering.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 09-19-2012, 07:20 AM   #14
'65Burb
Beautiful work. Please post your mailing address in order that I can get my cross member in the mail to you.
'65Burb is offline   Reply With Quote
Old 09-19-2012, 07:31 AM   #15
tincan1966
tincan1966's Avatar
very well documented! Thanks for sharing!
tincan1966 is offline   Reply With Quote
Old 09-19-2012, 09:03 AM   #16
Pop's C-10
Pop's C-10's Avatar
nice write up
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 09-19-2012, 10:01 AM   #17
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Sure, send it down !! (or up, rather )
Originally Posted by Pop's C-10 View Post
nice write up
Thanks guys.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 09-19-2012, 11:34 AM   #18
63sbssbbw
UCA63
63sbssbbw's Avatar
Nice work Chief
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 09-19-2012, 11:40 AM   #19
Andyboy
Andyboy's Avatar
Very helpful how-to. Nice work.
Andyboy is offline   Reply With Quote
Old 09-19-2012, 12:33 PM   #20
ol_skool_chevy
ol_skool_chevy's Avatar
I"m keeping an eye on the post. I want to see what you do for your steering. Seem to me the crossmember is the easy part. Getting your steering geometry right in order to clear might be an issue.
Im guessing you will notch your frame or Rack ??
Very nice write up...I was lead to beleive 1 1/2" was all you could step..
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 09-19-2012, 07:08 PM   #21
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Very nice write up!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 09-19-2012, 09:22 PM   #22
RollinKaos
RollinKaos's Avatar
Very cool , I am going to be watching this close. Since I dont have the welding skills though I might have to send mine your way too.
Betty :
'63 Fleetside Longbed
350 w/ 4 speed
CPP 3/5 drop with front sway bar.
RollinKaos is offline   Reply With Quote
Old 09-19-2012, 10:05 PM   #23
CSoliz
Torn between 66 and 78
CSoliz's Avatar
Hey Chief,
This thread has been needed for a long time!! Thanks!!!
CSoliz is offline   Reply With Quote
Old 09-20-2012, 12:06 AM   #24
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Originally Posted by 63sbssbbw View Post
Nice work Chief
T
Thanks, coming along ...
I will be retaing the stock steering, well the '78 steering. Yes the frame will have a custom notch to allow perfect steering geometry. (unless a rack shows up for free ... )
The crossmember was simple, but to some it might be more challenging ... thus this write up
I believe the 1 1/2" was to ease the steering issue. By notching a FULL 2", one could easily taylor by adding a 1/2" block in between frame and xmember.
Originally Posted by 61_FL_Apache View Post
Very nice write up!
Originally Posted by CSoliz View Post
Hey Chief,
Thanks....
Feel free to come by, I'll hook you up !!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 09-20-2012, 12:42 AM   #25
doobiebro
doobiebro's Avatar
Nice work Chief...how many hrs did it take you to finish that bad boy?
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
