Old 10-14-2003, 03:55 PM   #1
truckresq
truckresq's Avatar
Shorty Block Hugger Headers
Anybody have any Pros or Cons on using these style headers? My only thinking was that that are harder to get to when taking off the pipes for any reason.
John
Sacramento Area
1969 C10 Fleetside
truckresq is offline   Reply With Quote
Old 10-14-2003, 04:27 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
I have heard that block huggers won't clear the engine mounts in these trucks....maybe someone else will know for sure.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 10-14-2003, 04:44 PM   #3
RON WOODGEARD
Resident Young Old Dude !
They do make some that are made for our years,and a few of the guys here are running them, I have seen a few sets on E-bay that WILL NOT fit.
Ron
RON WOODGEARD is offline   Reply With Quote
Old 10-14-2003, 04:50 PM   #4
truckresq
truckresq's Avatar
Those Ebay sets were the ones I was looking at... I think mostly it was the price of these headers that attracted me.
John
Sacramento Area
1969 C10 Fleetside
Old 10-14-2003, 05:18 PM   #5
crazy longhorn
Fabricate till you "puke"
That set wont fit/clear the eng stands. Slammed 67 has a set on his truck(sandersens I think)....they fit nice, but are a little pricey. on the shortie headers, you will trade off a little low/mid range tork, for the extra ground clearance. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-14-2003, 05:36 PM   #6
truckresq
truckresq's Avatar
Im not looking for ground clearance, since Im not slamming it. Just looking for that price range. All the other headers around that price are used and WELL used. So it was just an option.
John
Sacramento Area
1969 C10 Fleetside
Old 10-14-2003, 05:51 PM   #7
RON WOODGEARD
John,
Check out Summit's own line of headers, They are pretty reasonably priced in comparison, and you know they are a brand name made for summit. Plus, you could drive up on a day off and pick them up.
Ron
Old 10-14-2003, 05:53 PM   #8
crazy longhorn
I dont know what you want to spend on headers, but there are severals full lenghts sets out there for a decent price. I am running a set of painted Hooker comps(around &140-150 through summit or jegs). The headmans are also a decent header, & a few less dollars. To get into coated headers, you will send a few bucks. if you were close to il , i have a good used set of headmans(cheap). my longhorn is a 3/5 drop, with more drop on the plans......the dr side collector hangs a little low for what I plan to do. Good luck,crazyL
Old 10-14-2003, 05:58 PM   #9
lotik
drag it like you stole it
i have summit block huggers.. $75 i believe
negative camber //LA\\
lotik is offline   Reply With Quote
Old 10-14-2003, 06:21 PM   #10
RON WOODGEARD
Block headers for our year of trucks?? I asked last time I was there, ( Summit 2 weeks ago) But the guy said they didn't have any block hugger headers that would fit, But that idiot, also said they didn't have any spark plug wire looms, ( you know the aftermarket fancy type) I looked around for a while, found a different kid, and he showed them to me. AMAZINGLY !! right behind the guy on the counter that I had asked before ! Did I have a few things sarcasticly to say to him.. Like Hey Bud,,,, You need to remove your sun glasses inside, you missed seeing the pieces I asked you about and they are right behind you ???!! OHHHH, You don't have sun glasses on do you? sorry my mistake !
I know, I can be a smart @SS...
Ron
Old 10-14-2003, 06:26 PM   #11
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
You wouldn't happen to have a picture of them installed would you? I need to get my full length headers off my truck before I smash them on a speed bump. Thanks, Billy
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 10-14-2003, 06:27 PM   #12
crazy longhorn
Lotik, did you have to trim the eng stands to fit the block huggers? crazyL
Old 10-14-2003, 06:55 PM   #13
lukecp
lukecp's Avatar
Can't you use 3/4 length Chevelle headers on these trucks to resolve the ground clearence issues?
Old 10-14-2003, 07:24 PM   #14
Bowtiefreak
Bowtiefreak's Avatar
Yes you can. Sanderson makes great headers. I have a set of their blockhuggers on my motor. Pricey but very nice. If I was to get them again, I would get the 3/4 length Chevelle headers.
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 10-14-2003, 08:22 PM   #15
lotik
i didn't have to trim anything, they bolted right up. someone told me that i have my motor in th v6 position, but i am not sure if that would make a difference. my motor is pretty close to the firewall.
Old 10-14-2003, 08:26 PM   #16
truckresq
truckresq's Avatar
lotik
anyway you can post pics?
John
Sacramento Area
1969 C10 Fleetside
Old 10-14-2003, 08:36 PM   #17
68 Suburban
68 Suburban's Avatar
Ok, here is what you do, get those block huggers and a couple of turbos off an late 80's T-Bird Turbo Coupe. Weld a the correct flange on the collector of the header. Flip the headers upside down and mount the turbos. Now run your exhaust
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 10-14-2003, 09:05 PM   #18
lotik
here you go
Old 10-14-2003, 09:10 PM   #19
jamis
F.A.S.T. president
jamis's Avatar
I think you guys are looking for "shortie headers" not "block huggers". They make shorties for are trucks they are swept back for the correct clearence. Huggers are used on early rods (20's 30's 40's) because of the narrow frame rails they need to "hug the block" and the collect is staight down the two center cyls because the staight axle or Mustang II suspension usally sits alot father forward then our trucks.
jamis is offline   Reply With Quote
Old 10-14-2003, 09:14 PM   #20
lotik
mine are definately block huggers
Old 10-15-2003, 08:30 AM   #21
jamis
F.A.S.T. president
jamis's Avatar
I saw that in the pic.....they look like the fit well. The shorties are a little longer and the collecter is swept back at an angle. Wish I could find a picture of them to post.
The one thing I like about the huggers is I think they are the only one I have seen come chrome from the factory and have also seen them in stainless.
Old 10-15-2003, 10:16 AM   #22
nightmare
nightmare's Avatar
i'm using the newer style mounts, the ones that are the clamshell type mounts, and the block hugger headers won't fit. the driver's side tube 1 hits the mount. i'm going to the mid-length to full-lenght headers
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 10-15-2003, 12:13 PM   #23
70short
I think for the best price for full length you can't beat Heddman (thick flange). A friend of mine was running the Summit brand and he was having problems with exhaust leaks (headers to block). When he called Summit to order another set for his car the salesman highly recommended HOOKERS (that is what I am running on my car:ceramic coated) For A lowered truck like ours I would get the Sanderson from someone like Early Classic. The worst thing about driving my car and the headers is SPEED BUMPS Points tp ponder
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 10-15-2003, 12:33 PM   #24
pat
pat's Avatar
V6 position?
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 10-15-2003, 12:52 PM   #25
mikej71
Unregistered User
mikej71's Avatar
Pat - the 6 cyl position is further back toward the firewall, which is also the 4x4 v8 position. I don't think he meant to say v6, but I'm only assuming.
Mike
71 SWB Stepside
SB400/TH350
mikej71 is offline   Reply With Quote
