Old 10-13-2012, 07:13 PM   #1
thelonerife
thelonerife's Avatar
Chucks 72 Cheyenne Custom Camper
I recently got a 72 Cheyenne Custom Camper. It has a big block, power steering, power brakes, air conditioning but it missing components, turbo 400 trans, tilt column, side tool box,
it has some rust issues like inner and outer rockers, mostly inner damage, cab corners, some floor and supports need replaced. That will have to wait for now. It doesn't have exhaust on it right now and its super loud. It is still on the trailer and when I get the paper work in my name I'll pull it to a muffler shop.
Things that I want to do to it to make it my work truck/hauler-
new exhaustDONE!
replace water neck gasket DONE!
get spark plug heat shields
put a class III hitch on itDONE!
get the wiring right for the trailer to be hooked upDONE!
get a brake controller for ithave but not installed
redo the tranny cooling -currently has an external cooler where the a/c condenser should beDONE!
replace bumper -DONE!
install underdash lightsDONE!
install glovebox lightDONE!
redo or rework the spare tire holderDONE!
repair leaks-ps gearbox, tranny pan etc.DONE!
Later down the road things I would like to do
add A/C vintage air
put on 4 matching tires
change dist. to electronic ignition
take off the extra gas tank
replace the mirrors with a stainless pairDONE!
repair the rust
replace the front bumper and grilleDONE!
put trim on the top of the tailgate thats missinghave but not installed
replace shocks
heres some pics
thelonerife is offline   Reply With Quote
Old 10-13-2012, 07:33 PM   #2
thelonerife
Re: Chucks 72 Cheyenne Custom Camper
I took the old home made bumper off. I had to cut the outer part off since it was bolted and welded on. I couldn't get to the welds with my grinder with the outer section on.
I got the bumper and truck from Tim (ozark tim). I painted the rear of the bumper and bolted it on. Then painted the outside of it. Its a heavy duty bumper but I still want a class III hitch that attaches to the frame.
Old 10-13-2012, 07:38 PM   #3
thelonerife
I painted the black on the 400 emblems too. and the black around the marker lights.
I also cleaned the rust off of the super long lug nuts and the center caps. It looks okay. I have two matching tires on the rear and two different ones on the front. I like the tire on the pass. side front. Its a BF Goodrich. They're all the same size but they look like their not. Go figure.
Old 10-13-2012, 07:41 PM   #4
thelonerife
i put some wood grain on some of the lower molding. I will have to do the drivers side as it is a lot worse than the passenger side.
Old 10-13-2012, 08:57 PM   #5
Rusbuilt
Rusbuilt's Avatar
Man Chuck that bumper looks a ton better!!! I like all the little details you are working on!
Rusbuilt is offline   Reply With Quote
Old 10-13-2012, 10:16 PM   #6
thelonerife
Thanks Rus, I didn't get to do anything on the 68. I took some stuff to the shed and cleaned up a little downstairs and yard work so maybe I can do a little on it tomorrow. I do need to change the gasket on the water neck soon though. Its leaking. I'll get one of those that I put on the 68.
Now that I have the bumper on, I will have the exhaust dumped on both sides so I have room to put the hitch on the frame. I wish I had one and could get it on before I take it to the muffler shop but oh well.
Old 10-13-2012, 10:43 PM   #7
Rusbuilt
Rusbuilt's Avatar
Have you checked on craigslist for one?
Old 10-13-2012, 10:52 PM   #8
thelonerife
No I haven't. I'll try that.
Old 10-14-2012, 06:55 AM   #9
XxCHEVYMANxX
XxCHEVYMANxX's Avatar
Nice Score Chuck ! I always liked the custom campers, they are heavy duty workhorses.
John
Mild Custom 68' Work Truck Build
Facebook LoL
1977 Trans Am (Project)
1965 Chevelle (Project)
XxCHEVYMANxX is offline   Reply With Quote
Old 10-14-2012, 12:47 PM   #10
Rusbuilt
Rusbuilt's Avatar
Hey Chuck $119 at walmart!!
http://www.walmart.com/ip/Reese-Towp...-Hitch/1957059
Old 10-14-2012, 06:40 PM   #11
thelonerife
Thanks Rus. After reading that I may need a class 4 or 5. Class 3 is 5000lb.towing and 500lb tongue wt.
Old 10-14-2012, 06:54 PM   #12
thelonerife
I like this one
http://www.reese-hitches.com/product...er_Hitch,41940
Old 10-14-2012, 07:13 PM   #13
Rusbuilt
Rusbuilt's Avatar
Yeah. lol I'd say that would be a little better!
Old 10-14-2012, 07:15 PM   #14
thelonerife
I found it for 240 shipped on ebay
Old 10-14-2012, 07:26 PM   #15
Rusbuilt
Rusbuilt's Avatar
There is one made by Curt for $207 at the hitch store, with FREE shipping!!
http://www.thehitchstore.com/class-i...82-p-1079.html
Old 10-14-2012, 07:32 PM   #16
thelonerife
I like that one too. thx.
Old 10-14-2012, 07:32 PM   #17
Rusbuilt
Rusbuilt's Avatar
Anytime sir!
Old 10-18-2012, 09:59 PM   #18
Rusbuilt
Rusbuilt's Avatar
Did you order a hitch yet?
Old 10-18-2012, 11:53 PM   #19
thelonerife
Nah, waiting on my title. trying to buy some little trim pcs for it tho.
Old 10-19-2012, 09:39 AM   #20
duallyjams
duallyjams's Avatar
Nice truck hope it doesn't distract you to much from the GMC.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 10-19-2012, 10:19 AM   #21
Low Elco
TOW PIG! That's a cool old truck! To heck with Vintage I bet that ac could be runnin' no prob!
Low Elco is offline   Reply With Quote
Old 10-19-2012, 07:51 PM   #22
thelonerife
dually, I don't think I could go much slower on either. I'm going slow on both. I did pick up a waterneck gasket for it. I may get it off the trailer and clean a little on it.
low Elco, thats right its going to be my tow pig mule or whatever lol. And Thanks! the a/c, It's missing the evap, lines, compressor, brackets, and condenser. Ive put money into the old systems and it was always disappointing. Not again.
Old 10-19-2012, 08:46 PM   #23
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
This is a super nice truck you have here. Nice work cleaning it back up too!
Ryan
1969 Chevy milk truck
Old 10-19-2012, 10:14 PM   #24
Low Elco
BTW, Hopkins mfg (hoppy) makes a plug-in setup for the trailer wiring. Works great, have one on both our old trucks.
Old 10-19-2012, 10:18 PM   #25
Todd68Chevy
Todd68Chevy's Avatar
Good looking project, Chuck
Note: All parts I have for sale are also for sale locally.
I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts.
Todd68Chevy is offline   Reply With Quote
