Old 10-25-2012, 12:56 AM   #1
AusTx68
AusTx68's Avatar
Quick Ratio Power Steering Gear Box
I would like to swap out the power steering gearbox on my 68' for a quick ratio box. I believe the 73' gear box is quick ratio and a direct fit. I would need to use a 68' pitman arm.
Do I have this right? Is there anything else I should know?
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 10-25-2012, 01:08 AM   #2
Mikes_70
Re: Quick Ratio Power Steering Gear Box
Hey what's up ,
Think I talked to you and your buddy with the blue c10 at good guys in ft worth
I was with my brother in law behind you guys with the dark blue
C10. I was want to know who did your interior ? I just got all new glass in and now looking
For a trim guy .
Thanks mike
Mikes_70 is offline   Reply With Quote
Old 10-25-2012, 01:58 AM   #3
AusTx68
AusTx68's Avatar
Originally Posted by Mikes_70 View Post
Hey what's up ,
For a trim guy .
Thanks mike
Yea that was me. Glad to see you on the forum! I'm moving up to Dallas on the 1st. We should try to get together. My interior guy is Ralph of Ralph's Upholstery in Elgin (20 miles east of Austin).
Old 10-25-2012, 02:29 AM   #4
oldspowered67C10
Not absolutely sure but I dont think any truck box is quick ratio, you have to put quick ratio car box guts in a truck box to get quick ratio.
oldspowered67C10 is offline   Reply With Quote
Old 10-25-2012, 02:48 AM   #5
mcmlxix
Collector of Projects
mcmlxix's Avatar
I went with a 76 4x4 box on the K5. I believe it was variable ratio and less turns lock to lock... check with Red Head at www.redheadsteeringgears.com
Rich
1972 K5 Blazer CST Click HERE
Old 10-25-2012, 08:41 AM   #6
Mikes_70
Hey AusTx68
Where at around Dallas are you moving to ? We are actually south of Dallas ,
Probably 10-15 miles . Yea I'm still trying to figure this board out . Hit me with your trim guys number . Let me know when you get in town .
Old 10-25-2012, 08:58 AM   #7
AusTx68
AusTx68's Avatar
I guess technically it's not QR but I do believe 73'+ are quicker than the 67-72. That's what I'm trying to confirm.
Thanks for the info
Hey AusTx68
Will do. Here's the info:
Ralph's Upholstery
105 West Brenham Street Elgin, TX 78621
(512) 285-2669
Old 10-25-2012, 09:20 AM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
Member gringoloco just installed a Redhead box.
You might give him a shout.
http://redheadsteeringgears.com/index.html
Keith
Convert to disc brakes.
Old 10-25-2012, 12:36 PM   #9
AusTx68
AusTx68's Avatar
I've seen a few aftermarket boxes available. I was hoping to grab a stock box from the local parts store. That's why I was asking about the 73' gear box. I think it's a faster ratio but no one has confirmed.
Old 10-25-2012, 12:39 PM   #10
ubtripn
ubtripn's Avatar
Mine was a 76 I believe and it is 1.5 turns to lock from center.
ubtripn is offline   Reply With Quote
Old 10-25-2012, 12:52 PM   #11
AusTx68
AusTx68's Avatar
Did the 76' steering box bolt right up?
Old 10-25-2012, 01:02 PM   #12
Secret Squirrel
Secret Squirrel's Avatar
I just installed a box from a 77 c-10. It is not quick ratio 3 turns to lock from center. It bolted right up and looked exactly the same as my 70 original gear box.
Ebay has a New GM overstock gear box for $190 no core charge, that I found after I bought the 77.
http://www.ebay.com/itm/77-78-79-80-...30482035194%26
Says it fits 67-84 two wheel drives
________________________
72 Olds Cutlass w/442 option
69 C-10 Short Bed Fleet
1960 Biscayne Wagon/El Camino
1995 YJ 4.0 SOA SYE on 35s
01 Excursion Limited 7.3 PSD
06 Suzuki DRZ 400S
Secret Squirrel is offline   Reply With Quote
Old 10-25-2012, 01:12 PM   #13
Fitz
GM made two boxes for 67-72 trucks. One was 15:1 and a 12:1 quickratio box. ECE has that quick ratio box for $299.00 and if you send in your old one they refund $75.00 for the core.
Mine bolted right up in my 67 and used the old pittman arm too!
Fitz is offline   Reply With Quote
Old 10-25-2012, 02:19 PM   #14
AusTx68
AusTx68's Avatar
The gearbox in the link is for a manual box.
Old 10-25-2012, 02:28 PM   #15
AusTx68
AusTx68's Avatar
Just got off the phone with Oreilly's. They have a gearbox for $125 with $50 core. That pretty good but it's standard ratio.
Old 10-25-2012, 04:20 PM   #16
Secret Squirrel
My Bad, missed that.
06 Suzuki DRZ 400S
Old 10-25-2012, 07:44 PM   #17
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
IIRC when I researched this,the standard PS box for a 68-72 was 4 1/2 turns lock to lock.The later boxes 73^ were 3 1/4 turns.The later box doesn't feel as "mushy" to me so that's what I went with.I did use a pitman arm to match my front suspension.
BTW I think the later box is VR.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-26-2012, 01:16 AM   #18
mcmlxix
mcmlxix's Avatar
All the boxes will bolt to the frame. It's the type of hose fitting that changed in the lates 70's and I'm not sure of the year. It went to the bubble flare type and your existing high pressure hose will not fit... I bought a set of -6 AN fitting adapters that fit the steering box but I am upgrading to hydroboost....
Rich
Old 10-26-2012, 04:39 AM   #19
long69
the ? is what year did they quicken the ratio. cant answer but '73 seems too early. don't think you'll need a another pitman arm. another thing as mentioned was what year did they change the fittings? can't answer that either. the years for a bolt in swap are narrow, i think maybe only 3 or 4 years. what ever my ebay box was it came with the pitman arm and it fit, for the line fittings i had to get adapters, different rag joint too. if you get the wrong year is no biggie just a little more scratch to make it work. everything is available.
long69 is offline   Reply With Quote
Old 10-27-2012, 03:59 PM   #20
rkn463
rkn463's Avatar
Regarding the fittings, you can swap out the part of the pump that the hose screws in to with the matching part from a newer pump and then use the new style hose. I did this on a 79 cutlass as well as the pump on my 67 pickup. On the cars the change came in 1980, I assume it was the same on the trucks.
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
Old 10-28-2012, 05:15 AM   #21
mcmlxix
mcmlxix's Avatar
OK. So today I got pulled my RedHead 4WD box to swap for a 2WD box from what was supposed to be an 88 3/4 ton truck. The RedHead invoice syas 69-76 GM 4X4, so I will ASSume that 77 and newer had different hose connections and at some point (maybe 77 also) the diameter of the splined input shaft was reduced.
I had rebuilt my steering shaft rag joint when I replaced the word out box for the new RedHead box, so I'll try and make a hybrid rag joint using the new rubber with late model female spline piece. If that doesn't work I'll drill/punch the pin out that connects the two shaft halves and try to make the connection there....
I'll try and take pics Sunday afternoon....
Rich
Old 10-28-2012, 08:39 PM   #22
Hutch
Hutch's Avatar
Here is another source
http://www.powersteering.com/
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 10-27-2013, 02:07 AM   #23
WIDESIDE72
WIDESIDE72's Avatar
I know this is an old thread, but does anyone have Any idea if early trans am/ z28 boxes will bolt up to our trucks? I have used 73+ boxes in the past, but im looking for a fast ratio box this time around.
I just remembered that the car box bolts inside the frame and the truck on the outside.
WIDESIDE72 is offline   Reply With Quote
Old 10-27-2013, 09:29 AM   #24
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Early Classic Enterprises has a drop in quick ratio boox. Thats what I am using.
Tom Vogel is offline   Reply With Quote
Old 10-27-2013, 09:47 AM   #25
Fitz
Yes, I use it too and it works GREAT on my 67!
