11-05-2012, 11:44 PM | #1 |
Mdo 69
Hi new to this, hope I can pull this off. I have a 69 gmc short fleet, bought it 4/2011, it had an 89 5.7 tbi with 700r4, PO couldn't get it to run, and neither could I, went to my local community college to talk to my old automotive instructor and he said, hey why dont you bring it here and work on it, take the continuing ed class at night. Good idea, I thought that was a year ago. It turned out to be a full blown resto.
11-05-2012, 11:54 PM | #2 |
Petroleum User
Re: Mdo 69
And its a GMC! YES!!!!! Great truck man
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto |
11-05-2012, 11:59 PM | #3 |
Re: Mdo 69
I had a neighbor growing up that had and still has about 15 67-72 trucks, and only one was a gmc, I walked past it everyday on my way to the bus stop, and when this one was offered to me by my cousin, I had to have it.
11-06-2012, 12:02 AM | #4 |
Re: Mdo 69
some pics of the frame, which im still working on, and the 5.3/4L60E I just got today.
11-06-2012, 12:03 AM | #5 |
Re: Mdo 69
Hey Rudy-g ...
to the forums and from Ohio on one GMC project. Keep the pics coming
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
11-06-2012, 12:05 AM | #6 |
Petroleum User
Re: Mdo 69
Nice! I think u will like that motor. My silverado has the 5.3. Its ALOT heavier and still gets 16mpg.
11-06-2012, 12:14 AM | #7 |
Re: Mdo 69
I had a 2000 2wd sierra and I loved the power of the 5.3 even with the 180K
11-06-2012, 09:58 AM | #8 |
Re: Mdo 69
Welcome to the board. 5.3 is a good choice, and becoming a fairly cheap buy anymore. When you go to get your computer reprogrammed/tuned, I suggest going thru www.nelsonperformance.com They do great work, but if you plan on doing additional tuning, I would recommend them because they lock there computers up so no one else can steal there software. Good luck, I look forward to seeing more of this GMC. I got one myself.
Joseph Joe's 69 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543253 1969 GMC SWB-350 SBC 700R4 2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust |
11-06-2012, 10:04 AM | #9 | |
Petroleum User
Re: Mdo 69
11-06-2012, 10:33 AM | #10 |
Re: Mdo 69
Yes we do... I am partial to the 4 eyed beasts.... But all will do. Thanks for the compliment, it's only to get better. I only wish I had pic's of it after I got the LT1 swap done and exhaust. I will get those taken and posted up after I get back to the states. I have many plans in the works.
Rudy-g... What all you got in mind for this 4 eyed machine? You got a nice start on it already.
11-06-2012, 10:40 AM | #11 | |
Petroleum User
Re: Mdo 69
11-06-2012, 11:27 AM | #12 |
Re: Mdo 69
Currently deployed to Afghanistan. Should be back around February.
11-06-2012, 11:36 AM | #13 |
Petroleum User
Re: Mdo 69
Thanks for bitin the bullet for us man. I was US Army 1st cav, 8th engr battalion, Ft Hood back in the day. We appreciate what u guys do. I see you
11-06-2012, 12:01 PM | #14 |
Re: Mdo 69
Thanks... It has made a better person out of me.
11-06-2012, 12:05 PM | #15 |
Petroleum User
Re: Mdo 69
Turned me into an ass rippin beast as well...way back in '86. Whatever life throws at you from here on out, youll just say "whatever".
11-06-2012, 02:49 PM | #16 |
Re: Mdo 69
plans for my 69, well since ive never had any experiance with body work as of right now i dont know what kind of paint i'll throw on it, if the body turns out straight i might go metallic.
as for the engine im going to try and use the stock truck manifolds right now im trying to find out which swap motor mounts i can use, i need to try and use my drive shaft since its brand new, i think i might use dirty dingo or cpp. Once the truck is put together im going to lower it i have cpp drop coils, if im happy with how it turns out i might go with a cpp disk brake drop kit conversion. |
11-06-2012, 03:38 PM | #17 |
Re: Mdo 69
I suggest on your drop using drop spindles in the front, and coils in the rear. I am not sure if you are running disc brakes or not, but if not is would be a good time to convert to them.
One of the main reason I recommend using spindles for lowering is because it keeps all your factory steering components in the same locations instead of changing the geometry of them. In other wards it keeps undo stress off the components allowing them to have a longer life. It also makes the alignment process easier, and tends to stay at proper alignment longer. When I was in Vo-Tech I spent a lot of time on the alignment machine dealing with lifted and lowered vehicles. Our instructor always harped on the effects of doing things properly when lowering and try to stay at stock specs. With lifts, he told us there isn't much you can do other than ensure your components are in good shape and get an alignment every time the tires are rotated. And believe me, I aligned a dudes truck about every 2 months for my 2 years there, always needed tuned back in. What I am really saying, spending a little more money in the beginning will save you money over time.
11-06-2012, 03:45 PM | #18 |
Florida Edition
Re: Mdo 69
Welcome from another 4 eye Vet!
Now would be the time to drop it while everything is easy to get to and yes...drop spindles are the way to go.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
11-06-2012, 04:01 PM | #19 |
Re: Mdo 69
Well here another GMC junkie welcome to the forum
11-06-2012, 05:23 PM | #20 |
Re: Mdo 69
thank you guys for making me feel welcome.
i would really like to lower it while its bare bones, but i just dont have the money for that just yet, maybe next summer, I will do the drop spindles and disk brake setup. right now im trying to figure out my engine swap, I think im going to go with dirty dingo's slider mount, and mid 80s bracket a couple of members have gone this route and i believe it works good and its the cheapest. i need to use my existing drive shaft and truck exhaust manifolds Posted via Mobile Device |
11-15-2012, 12:40 PM | #21 |
Re: Mdo 69
Just a thought, what if you could take a 67 chevy grille cut it and modify it so you can put it between the 4 gmc headlights. i've had that idea in my head for a while but i dont know if the final product would look good, and I'd hate to spend the money on the 67 grille then cut it and it not look good.
11-15-2012, 08:22 PM | #22 |
Petroleum User
Re: Mdo 69
Im all for mods, but not sure about that one...I think the bezels might be too different to make it look right. And the headlights are different sizes
11-15-2012, 08:50 PM | #23 |
Re: Mdo 69
welcome from Texas.....looks like you are having lots of fun with the truck. keep up the good work..it will be worth it.
11-15-2012, 10:43 PM | #24 |
Re: Mdo 69
11-15-2012, 10:46 PM | #25 |
Re: Mdo 69
I cut up an LMC catalog and came up with this probably wouldn't work
Posted via Mobile Device Last edited by Rudy-g; 11-29-2012 at 11:39 PM. |
