Old 11-10-2012, 10:35 AM   #1
Hart_Rod
Hart_Rod's Avatar
Project "Shifted"
1968 Chevrolet C-10 Porterbuilt Extreme Drop Member:
Rust free cab (original rockers, cab corners and kick panels), doors and front clip with all glass.
Bolt in high hump tranny cover.
New rubber cab mounts.
New Precision Gasket door seals.
Original factory Buddy buckets recovered with white vinyl and green Highlander plaid
Original steel front and rear painted sport bumpers and brackets.
Hills Rod & Custom fiberglass front tubs for dropped trucks.
Porterbuilt Hood hinges with gas struts
Custom Steel sectioned rear tubs
New stainless steel Flaming River tilt with column shift with Lokar shift linkage.
Custom wooden steering wheel.
Borgeson steering rod and u-joint steering
Custom gas pedal setup with Lokar cables.
New Tri-plus core support, bedsides, tailgate, front bed panel and inner wheel tubs and custom “Chevrolet” rear filler panel.
Complete Mar-K red oak wood bed kit with polished stainless steel strips and hidden fasteners
Bed, tailgate, tubs freshly painted 503 green to match the cab and front clip.
Factory short bed chassis with front and rear Porterbuilt Extreme dropmembers.
Porterbuilt tubular upper and lower A-arms with new larger ball joints.
Porterbuilt rear tubular trailing arms and crossmember.
Porterbuilt front radiator crossbar.
Porterbuilt transmission mount.
Complete Accuair e-level setup with level sensors, compressor, tank, manifold exo-mount, fused power wiring harness, IPOD controller.
Front and rear airbags, airline fittings and shocks.
New power rack and pinion with braided PS lines.
1.25" Adco sway bar.
CPP 2" dropped modular spindles (73-87) with aluminum hubs.
CPP front and rear big disc brake kit (13"/12") with black powder coated calipers, zinc coated slotted and drilled rotors, and braided stainless brake lines.
New 20x10 and 20x8.5 Billet Specialty Vintecs Fat Lips with TOYO Proxy II tires.
Custom two piece 3.5" driveshaft/slip joint and heavy duty carrier bearing.
Factory 1968 12 bolt rear with Eaton posi, 3.73 gear and new ECE 5 lug axles, bearings and seals.
Captain Fabs brake bracket with new 9" Power booster, new Wilwood master cylinder and proportioning valve.
The chassis and all components have been sand blasted and painted with POR 15.
New American Auto Wire complete body electrical harness
New Dakota Digital VHX gauges
All new Vintage Air Gen IV AC components
2002 Z28 330 HP LS1 (5.7 all aluminum)/4L60E with only 25K documented miles.
ECM/MAF/O2 sensors.
NEW BPAutomotive standalone “SHOW” EFI Harness (braided wrap) with fuse/relay panel.
Custom dual pass Entropy aluminum radiator with dual electric fans (with built in tranny cooler).
Hotrod Dynamics radiator cover.
Custom stainless cold air intake setup.
Optima battery.
New Holley LS accessories and brackets - ps, ps braided lines, high amp alternator, ac compressor (SD7) all new.
2010 Camaro manifolds with Custom aluminum fuel tank (Linexed) with in tank Walbro fuel pump and 90 ohm sending unit. (with braided fuel lines and Corvette fuel pressure regulator).
Custom ECM mount.
LOKAR shifter linkage, transmission filler tube, throttle brackets and cables.
New ACC rubber floormat
FATMAT throughout cab
I picked up this nice 68 project from a fellow boardmember Shifty for my son Jake a little less than 2 years ago (thanks for the great deal Jason, ). Our plans were/are for a father and son project. One of the main reasons I got it is that Jason had already done a ton of work to it, so most of the hard work and planning had already been done. Here's a link to his thread that shows all of his progress:
http://ls1tech.com/forums/conversion...-stepside.html
Our plans are to keep close to what Jason had orginally planned for the truck, but with a few small "variations". He had bought a fairly orginal 68 short stepper that had an older restoration (the cab on this truck is nicer than the on on my brown/white 68!). He installed a nice low mile LS1/T56 and had planned on bagging the truck with a basic air ride suspension.
We plan on sticking with the drivetrain (the T56 should be fun!). Our variations are as follows:
Switching the stepper bed for a fleetside
A complete Porterbuilt front and rear dropmember setup (thanks Mike Baker!).
Swapped Autometer gauge setup for a set of Dokata Digital VHX gauges
A set of buddy buckets (of course, )
A set of 20's (probably Coys?)
Jake likes the patina look, so we're leaving the paint as is for right now. Plans are to get it running and driving for his 16th birthday (we've got a year and a half). Eventually we may tear it back down and repaint it. I'll try to keep you updated as we go.
Here's some original pictures of when Shifty first got it.
Hart_Rod is offline   Reply With Quote
