Old 11-10-2012, 10:35 AM   #1
Hart_Rod
Hart_Rod's Avatar
Project "Shifted"
1968 Chevrolet C-10 Porterbuilt Extreme Drop Member:
Rust free cab (original rockers, cab corners and kick panels), doors and front clip with all glass.
Bolt in high hump tranny cover.
New rubber cab mounts.
New Precision Gasket door seals.
Original factory Buddy buckets recovered with white vinyl and green Highlander plaid
Original steel front and rear painted sport bumpers and brackets.
Hills Rod & Custom fiberglass front tubs for dropped trucks.
Porterbuilt Hood hinges with gas struts
Custom Steel sectioned rear tubs
New stainless steel Flaming River tilt with column shift with Lokar shift linkage.
Custom wooden steering wheel.
Borgeson steering rod and u-joint steering
Custom gas pedal setup with Lokar cables.
New Tri-plus core support, bedsides, tailgate, front bed panel and inner wheel tubs and custom “Chevrolet” rear filler panel.
Complete Mar-K red oak wood bed kit with polished stainless steel strips and hidden fasteners
Bed, tailgate, tubs freshly painted 503 green to match the cab and front clip.
Factory short bed chassis with front and rear Porterbuilt Extreme dropmembers.
Porterbuilt tubular upper and lower A-arms with new larger ball joints.
Porterbuilt rear tubular trailing arms and crossmember.
Porterbuilt front radiator crossbar.
Porterbuilt transmission mount.
Complete Accuair e-level setup with level sensors, compressor, tank, manifold exo-mount, fused power wiring harness, IPOD controller.
Front and rear airbags, airline fittings and shocks.
New power rack and pinion with braided PS lines.
1.25" Adco sway bar.
CPP 2" dropped modular spindles (73-87) with aluminum hubs.
CPP front and rear big disc brake kit (13"/12") with black powder coated calipers, zinc coated slotted and drilled rotors, and braided stainless brake lines.
New 20x10 and 20x8.5 Billet Specialty Vintecs Fat Lips with TOYO Proxy II tires.
Custom two piece 3.5" driveshaft/slip joint and heavy duty carrier bearing.
Factory 1968 12 bolt rear with Eaton posi, 3.73 gear and new ECE 5 lug axles, bearings and seals.
Captain Fabs brake bracket with new 9" Power booster, new Wilwood master cylinder and proportioning valve.
The chassis and all components have been sand blasted and painted with POR 15.
New American Auto Wire complete body electrical harness
New Dakota Digital VHX gauges
All new Vintage Air Gen IV AC components
2002 Z28 330 HP LS1 (5.7 all aluminum)/4L60E with only 25K documented miles.
ECM/MAF/O2 sensors.
NEW BPAutomotive standalone “SHOW” EFI Harness (braided wrap) with fuse/relay panel.
Custom dual pass Entropy aluminum radiator with dual electric fans (with built in tranny cooler).
Hotrod Dynamics radiator cover.
Custom stainless cold air intake setup.
Optima battery.
New Holley LS accessories and brackets - ps, ps braided lines, high amp alternator, ac compressor (SD7) all new.
2010 Camaro manifolds with Custom aluminum fuel tank (Linexed) with in tank Walbro fuel pump and 90 ohm sending unit. (with braided fuel lines and Corvette fuel pressure regulator).
Custom ECM mount.
LOKAR shifter linkage, transmission filler tube, throttle brackets and cables.
New ACC rubber floormat
FATMAT throughout cab
I picked up this nice 68 project from a fellow boardmember Shifty for my son Jake a little less than 2 years ago (thanks for the great deal Jason, ). Our plans were/are for a father and son project. One of the main reasons I got it is that Jason had already done a ton of work to it, so most of the hard work and planning had already been done. Here's a link to his thread that shows all of his progress:
http://ls1tech.com/forums/conversion...-stepside.html
Our plans are to keep close to what Jason had orginally planned for the truck, but with a few small "variations". He had bought a fairly orginal 68 short stepper that had an older restoration (the cab on this truck is nicer than the on on my brown/white 68!). He installed a nice low mile LS1/T56 and had planned on bagging the truck with a basic air ride suspension.
We plan on sticking with the drivetrain (the T56 should be fun!). Our variations are as follows:
Switching the stepper bed for a fleetside
A complete Porterbuilt front and rear dropmember setup (thanks Mike Baker!).
Swapped Autometer gauge setup for a set of Dokata Digital VHX gauges
A set of buddy buckets (of course, )
A set of 20's (probably Coys?)
Jake likes the patina look, so we're leaving the paint as is for right now. Plans are to get it running and driving for his 16th birthday (we've got a year and a half). Eventually we may tear it back down and repaint it. I'll try to keep you updated as we go.
Here's some original pictures of when Shifty first got it.
Hart_Rod is offline   Reply With Quote
Old 11-10-2012, 10:43 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Project "Shifted"
Here's a couple of pictures of the engine install.
Old 11-10-2012, 10:51 AM   #3
n2billet
Village Idiot....
n2billet's Avatar
That's a good looking truck!
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 11-10-2012, 10:51 AM   #4
Hart_Rod
Hart_Rod's Avatar
And here's a couple pictures of the parts we've been gathering....
Old 11-10-2012, 10:59 AM   #5
Hart_Rod
Hart_Rod's Avatar
Thanks Keith. I think it will be a perfect "starter" truck. Sorry I missed you at CTC, I was in Dallas at the time (go figure). Here's some more pictures of the chassis. We still have some welding to finish up and I need to test fit the motor and tranny, then we can blast and paint it. Hopefully things will speed up after that......
Old 11-10-2012, 11:17 AM   #6
n2billet
Village Idiot....
n2billet's Avatar
CTC was fun, I'm going back next year. Have you thought about mounting the tank on the top of the rails? With it that low if he lifts the front more than the rear it will hit.......ask me how I know.
Old 11-10-2012, 11:20 AM   #7
Hart_Rod
Hart_Rod's Avatar
, some lessons are learned the hard way....We will definitely look into that once we start putting it back together.
Old 11-10-2012, 11:26 AM   #8
n2billet
Village Idiot....
n2billet's Avatar
It doesn't look out of place on top (to me).
Old 11-10-2012, 07:19 PM   #9
Zoomin
Man of Mini-Talents
Zoomin's Avatar
What a fun project. I wonder what insurance will be like on that? No matter, he'll be cool at school for a ton less than the new Camaro kids.
Zoomin is offline   Reply With Quote
Old 11-10-2012, 07:52 PM   #10
Rusbuilt
Rusbuilt's Avatar
Oh yes Rob!! I will follow!
Rusbuilt is offline   Reply With Quote
Old 11-10-2012, 11:50 PM   #11
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Subscribed.... this will be a great build.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-11-2012, 12:13 AM   #12
JRE
Sweet ride.
JRE is offline   Reply With Quote
Old 11-11-2012, 12:20 AM   #13
RocketKing
RocketKing's Avatar
I'm in for sure!
Rex
RocketKing is offline   Reply With Quote
Old 11-11-2012, 12:51 AM   #14
67c10rustbuket
67c10rustbuket's Avatar
Sweeeet ! I'm in.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 11-11-2012, 12:56 AM   #15
67ChevyRedneck
67ChevyRedneck's Avatar
NO WAY! I met Jason years ago. I sold him a set of 99-02 silverado seats, I take it he didn't throw those in with the truck? They were really nice too, charcoal and at the time low miles (I think around 70K on them.)
Two years ago? Man, I told him if he ever sold it to let me know! At least it's in really good hands now! I take it he never actaully got it running?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-11-2012, 01:35 AM   #16
msgross
msgross's Avatar
nice truck...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-11-2012, 01:35 AM   #17
jwalk
What was I thinking?
jwalk's Avatar
Rob that's a nice step side, I'm in!
Justin
'68 C/10 Custom Long wide bed
'78 GMC Sierra short wide
Project: Second time around...'68 short wide
http://67-72chevytrucks.com/vboard/s...d.php?t=423949
jwalk is offline   Reply With Quote
Old 11-11-2012, 10:41 AM   #18
darkhorse970
darkhorse970's Avatar
I'm in too, look forward to seeing this one go together!
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 11-12-2012, 10:31 PM   #19
Hart_Rod
Hart_Rod's Avatar
Thats probably what I'll end of doing.
Thanks, , I don't even want to think about insurance yet......
, thanks bro!
Thanks Nate!
Originally Posted by JRE View Post
Sweet ride.
Thanks!
Originally Posted by RocketKing View Post
I'm in for sure!
Thanks!
Originally Posted by 67c10rustbuket View Post
Sweeeet ! I'm in.
Thanks!
I guess I was in the right place at the right time and he gave me a deal I couldn't refuse. He did throw in the seats and a ton of other parts. I found a set of buddy buckets and sold the other ones. He did get it running and then tore it all apart to do the chassis and that's the way it sat until I bought it.
Originally Posted by msgross View Post
nice truck...
Thanks Mike!
It was, now it's going to be a fleet....
Thanks!
Well we made a little progress today. We almost got the front clip pulled off, so we can pull the motor/tranny out. Then we'll remove the old chassis so the cab will be ready to put back on the new frame once its blasted and painted. Speaking of drivetrain, since I'm going a different direction with my 68, my son mentioned putting the LS1 with the 4L60E in his truck. He likes the thought of paddle shifters (he got this from his XBOX or maybe TopGear????) and we found this cool setup online thanks to another boardmember:
http://www.tciauto.com/tc/shifters/paddle.html.
Has anyone tried this? Thoughts? He really likes the idea of a 6speed, but the paddle shifter is pretty cool. I gave him this week to think about it, because one of the engines has to go.
I also put one of the Coys wheels off of the suburban on his chassis. He really likes the way it looks, so we'll probably go that route. Here's some pics...
Old 11-12-2012, 10:42 PM   #20
gearys 5600
gearys 5600's Avatar
LOOKIN GOOD !!
with the LS / T56, this should be very fun to drive..
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 11-12-2012, 10:49 PM   #21
Rusbuilt
Rusbuilt's Avatar
That paddle shift would be awesome!!
Old 11-13-2012, 02:52 PM   #22
rwade
rwade's Avatar
Maybe I missed it, but what brand is your electric fan and shroud set up? Info on where to get it would be appreciated. Thanks
rwade is offline   Reply With Quote
Old 11-13-2012, 03:01 PM   #23
Graham57a
Graham57a's Avatar
I'm in, subscribed
Graham57a is offline   Reply With Quote
Old 11-13-2012, 04:23 PM   #24
Bennett68C10
Bennett68C10's Avatar
Nice build, I'm in to see how it turns out
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is online now   Reply With Quote
Old 11-13-2012, 05:12 PM   #25
big_al_71
big_al_71's Avatar
Looks like this one is going to be fun to watch!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
