Old 11-23-2012, 12:24 PM   #1
armybyrd
How Many Miles Per Tank?
Ive got a '83 stepside thats 2wd and has a 305 engine and 350 trans.
Im barely getting 200 miles per tank. I realize these trucks arent that efficient but is this average or is something wrong with my setup? Everythings stock besides an Edelbrock carb btw.
armybyrd is offline   Reply With Quote
Old 11-23-2012, 12:24 PM   #2
armybyrd
Re: How Many Miles Per Tank?
Also how much would a 700r4 help gas mileage?
Old 11-23-2012, 01:01 PM   #3
86c20
86c20's Avatar
in my c20 i get 200 to the last 1/4 of the tank that is not highway. highway is more closer to 250. that is with 18 gall tank at speed
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 11-23-2012, 02:30 PM   #4
J Knight
J Knight's Avatar
If you got a 16 gallon(14 useable) tank at 15mpg, that will only get you 210 miles. An OD tranny might get you to 18 mpg if your keep your foot out of it.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 11-23-2012, 03:07 PM   #5
wilkin250r
wilkin250r's Avatar
200 miles sounds about right, actually, if you've got the smaller tank. I've got dual 20 gallon tanks, I can drive 600 miles. But it costs me about $150 to fill up!!!
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 11-23-2012, 03:12 PM   #6
INSIDIOUS '86
INSIDIOUS '86's Avatar
About ten miles per tank. All sideways haha
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-23-2012, 04:16 PM   #7
GM-power
GM-power's Avatar
I never took the time to figure my mpg (kinda scared). 200 miles sounds like a good number. Me and my 357 probably don't get that.
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 11-23-2012, 04:52 PM   #8
Axle
Axle's Avatar
Sounds about right for ethanol spoiled fuel. My injected vehicle doesn't care what goes in the tank, but the carb'd vehicles have a very noticable drop in mileage per tank when using a 10% blend.
Alex.
Axle is offline   Reply With Quote
Old 11-23-2012, 05:22 PM   #9
ont_guy_38
ont_guy_38's Avatar
Yup that's about right. I probably only get half that .
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 11-23-2012, 05:55 PM   #10
dieseldawg142
dieseldawg142's Avatar
my crew can manage about 220-240 miles on a fill up (dual 20 gal. tanks). a little less around town. 454, t400
dieseldawg142 is offline   Reply With Quote
Old 11-23-2012, 06:57 PM   #11
Firebirdjones
Yikes, I hope you didn't mean you are filling both of those tanks to go just 220-240 miles...
My 79 454/400 turbo has dual 20 gal tanks. I go 200 miles on one tank before switching and still have 1/4 tank left in it before I switch.
Accross country I could stretch it and average about 450-470 miles before a fillup and still leave just under a 1/4 tank in each one.
Around town driving is less obviously, but I can still fill both tanks and go for 2 weeks without a fillup around town averaging about 350 miles and using 30 gallons (again switching the tank at about 1/4 tank left).
Armbyrd, if your speedo is correct, fillup and keep track of mileage, and fillup again recording the gallons. That will tell you the exact mpg you are getting. 200 miles per 20 gallon tank is in the ballpark, but how far towards empty are you going, or more importantly how much do you have to put back in at fillup time?
Firebirdjones is offline   Reply With Quote
Old 11-23-2012, 08:52 PM   #12
C-10 simplex
Not good. i get about 294-302 per tank.
As far as the 700r, it depends on what your rear axle ratio is.
i think the only way to get over 20 in trucks like these are, in order or preference:
1) move down on cubes----4.3 v-6. This may reduce towing/hauling ability.
2) 6.2 diesel
3) A new LS with cylinder deactivation. A regular LS should do it too.
C-10 simplex is offline   Reply With Quote
Old 11-23-2012, 11:26 PM   #13
frog210
my 74 with a 305 v8 and 350 get around 10-11mpg
San Antonio, TEXAS
-Frog
-I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it.
frog210 is offline   Reply With Quote
Old 11-23-2012, 11:31 PM   #14
Firebirdjones
2) 6.2 diesel
I've done it with carbed 350's, (over 20 mpg) with an overdrive and sharply tuned. So it's doable but most people won't or can't spend the time to dial one in properly. Shucks I get 17 mpg out of my 70 formula with a 434 cubed pontiac, a carb, 400 turbo, and 3.31 gears. An overdrive in that would put it right at 20 mpg piece of cake.
I get 22 mpg with the 6.0 LQ4 (LS engine basically) swapped into my 72 4x4 blazer, 4L60 and 3.73's on 33" tires, and no cylinder deactivation (that's cheating ). Alot of people told me mileage wasn't going to be it's strong suit either, but it holds it's own against any new V8 SUV. A 6.0 is just 364 cubes, it's not a big engine by any means.
There is so much more to mileage than the engine choice. It's really best to concentrate on the little things before spending money changing the total package. So many things that rob power and MPG. Tires, wheels, the weight of the tires and wheels, tread patterns, the tune, the weight of the vehicle, driveshaft, engine driven fans, oil viscosity, gas quality, correct gear choices, transmission choices. You can go on and on, and find at least 2-3 mpg if you are willing to spend the time and money on simple things first.
If I can get 14 mpg out of my 79 1 ton with a 502/400 turbo and 3.73's then anyone can at least do it with a 350. I'm expecting to pick up another 2-3 mpg with the gearvendor install.
Old 11-24-2012, 12:23 AM   #15
Rubble
Thumbs up Re: How Many Miles Per Tank?
I just got the 82 back on the road about a month now:6.2/A833/208/3.73 on 35s 6" lift.It's been cool out,so it's pretty well running from when I leave in the morning til home around 4-5.Put between 80-100 miles a day on it and it's been 16-18 mpg.Once summer is back & very little idling should be close to 20
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 11-24-2012, 01:07 AM   #16
kalbert
I don't know exactly but I'd guess 120 or so miles on a small tank, maybe less trying to keep up on the highway. I wish it were 200!
kalbert is offline   Reply With Quote
Old 11-24-2012, 01:55 AM   #17
dieseldawg142
i wish i could get 200 on one tank, but sadly that's my range on both tanks (full 40 gals., new tanks). my 38.5 swampers don't help, nor do the 4:56's behind a t400, then throw the camper & trailer on & i can barely crack 5mpg's, plus i live in bc, land of mountains- forget about feather throttle driving
Old 11-24-2012, 10:41 AM   #18
Firebirdjones
Yikes!
When I pulled the 28 ft. enclosed trailer loaded my mileage dropped from 14 (empty, truck only) to an average of 10 mpg accross country. It would dip as low as 9 mpg occasionally depending on the terrain. 10mpg was a big drop from it's normal 14 but the trailer weighed a good 10,000 lbs. too so it wasn't too bad for a gas powered BBC. Overall I'm pretty happy about mpg with this old pig.
But I'm running stock 9.5x16.5 tires (30" tall) and a 400 turbo with 3.73's. I keep rpm just under 3,000 (about 65ish) and it does pretty well.
Old 11-24-2012, 02:00 PM   #19
dieseldawg142
ya, i've been seriously thinking 'bout swapping in a 700r4. 3 things killing me right now, gears, at 55-60 my tach is hovering around 3300-3500,when i hit the freeway off-ramps, i just let off the throttle & truck slows itself with NO brakes-usally i have to give it gas to make it to top of off-ramp, weight, rolled it over the hiway scales, empty just under 7700lbs, & aerodynamics, w/out camper, just over 9ft tall, w/camper 12 ft tall. got the aerodynamics of a laundry truck. with the price of fuel in bc it costs me $200 to fill & i can go around 200 miles(+ or-)-works out to about buck a mile to drive, which is why it's not my daily driver. i would be ecstatic if i could get 10mpg while hauling our junk!
Old 11-24-2012, 08:06 PM   #20
csdineley
csdineley's Avatar
200 - 210 is what I get from a single tank as well. 1987 R20 350 TBI, th400, 4.10, dual 20 gal tanks.
csdineley is offline   Reply With Quote
Old 11-25-2012, 05:04 AM   #21
Number21
Number21's Avatar
That's right about where I'm at - 10mpg. I've tried and tried to get better but it just ain't happening.
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's.
You can set my truck on fire and roll it down a hill,
and I still wouldn't trade it for a Coupe de Ville.
Number21 is offline   Reply With Quote
Old 11-25-2012, 01:51 PM   #22
Skunksmash
Skunksmash's Avatar
My 87 with a tbi 350 gets about 205 miles per tank. I hear that's bad. Its about 14 MPG and other people say the same truck gets 17 to 20.
I used to have a 1 owner 2bbl '81 305 and it got around 18-19 MPG. Motor was gutless though.
Skunksmash is offline   Reply With Quote
Old 11-25-2012, 05:30 PM   #23
piecesparts
Parts and more parts
piecesparts's Avatar
I have a SWB that has two 16 gallon tanks. I run a 383 stroker engine with a 700 R4 tranny W/O the lockup converter. I have 3.73 gears in the rear end and with all of this, I get just over 200 Mile per tank on the truck. I do have a lower profile tire and the cruise RPMs are around 2400, due to me wanting to keep the stall converter in it's range and not overheat the tranny components..
Frank
Old 11-25-2012, 05:39 PM   #24
Skunksmash
Skunksmash's Avatar
how many RPM's do you run with those 3:73's at about 70Mph?
Old 11-25-2012, 07:28 PM   #25
Firebirdjones
Depends on your tire height. With a 1:1 final (no overdrive) and a 28" tire that's exactly 3,000 rpms. I generally cruise at 2800 which is 65 mph.
On a truck where you can easily fit a 30" tire or more, it makes the 3.73's very street friendly.
