Old 12-13-2012, 11:29 PM   #1
cam-camaro
Exhaust recommendations? 305 K10
New rebuilt motor, don't care much for the stock exhaust I have on there. It's a chevy 305 with a 3/4 cam, .40 over bored sitting in a 86 K10 .Money isn't too much of an issue, but I'd like to keep it under $400. So what's the best set-up for a combination of sound/performance? I appreciate any advice. Thanks in advance.
cam-camaro is offline   Reply With Quote
Old 12-13-2012, 11:34 PM   #2
Pyrotechnic
Pyrotechnic's Avatar
Re: Exhaust recommendations? 305 K10
"Well, I got a 426 Hemi in her. Three-quarter cams, nitro boosters. I can get 'er up to 155. Never do though, of course, unless I'm chasing a cute chick in a Ferrari! Hahahahahahaha!"
On a more serious note, a dual setup with flowmasters or magnaflows, depending which sound you like. An X pipe is the latest fashion these days but it adds some to the cost and I don't know how hard/easy that is to do on a 4x4.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 12-13-2012, 11:41 PM   #3
cam-camaro
Sweet car dude, I like it, good luck with Ferrari chase haha. If you end not catching her, there's always room for a beer at the local joint.
What size pipes would you recommend? Right now they have 1 1/2 or 1 3/4, not sure but whatever they are they sound terrible. You can hear the truck from a half a mile away, even in a low gear going slow.
Old 12-13-2012, 11:47 PM   #4
Pyrotechnic
For a warmed up 305, 2.25 pipe should be fine. If you are planning an engine upgrade later, you can go with 2.5 though it's a bit overkill for what you have now.
Old 12-13-2012, 11:50 PM   #5
cam-camaro
I appreciate the advice. By "overkill", do you mean it's more than I'll need, or will it have a negative effect on my exhaust flow.
I doubt I'll do an engine upgrade, I just re-built this motor from top to bottom, I plan on getting many many miles outta her.
Old 12-13-2012, 11:53 PM   #6
Pyrotechnic
The idea is to keep the exhaust velocity up to help low end torque, the 2.5 pipe won't help with that and it will cost more. 2.25 is good choice if that engine is permanent.
Old 12-13-2012, 11:56 PM   #7
cam-camaro
Thanks, 2.25 it is then. What about headers? I have stock exhaust manifolds, they aren't in too good shape but it's all I had at the time. I plan on replacing them, not sure if I"m going to go with more manifolds or headers.
Old 12-13-2012, 11:58 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
i went 2.25 ,true duals,from almost stock manifolds,to flowmasters 40s,one with H pipe,out before rear wheels
other one walker pipes ,cherry bombs,no H out the back sides
love em both
you can buy duals/kits from walker
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 12-13-2012, 11:59 PM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
to you have to test/smog it?
John
Old 12-14-2012, 12:03 AM   #10
cam-camaro
Nope, pretty rural county.
Old 12-14-2012, 12:27 AM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
Well the manifolds seem less work,headers can leak more
Take out what smog stuff you can
Heat riser?cat?
Some think my 305 is souped 350 lol now
Have a look at my 79 below I did exhaust this summer
John
Old 12-14-2012, 01:15 AM   #12
INSIDIOUS '86
INSIDIOUS '86's Avatar
Dyno max has a dual system for our trucks for about 132 dolla. What kind of sound you looking for? Quiet cruze? Kill your neighbors or wake up the dead?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-14-2012, 11:29 AM   #13
OutlawDrifter
get on youtube and find a sound you like.
exhaust is generally my favorite part of a project. i've had everything from quiet to pissing off the neighbors 4 miles from home. flowmasters drone in the cab, but i'm past the loud because its loud stage. i had spintech sportsmans on my el camino, they were ok, i really liked the sound on those. i'm a big fan of hooker aerochambers. loud when you need them to be, and mellow when you're cruising.
it's all about preference, and what you can stand for noise level in the cab. i run a hooker aerochamber on my lsx swapped camaro, but it also has a cutout in the i-pipe when i need to announce my presence.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 12-14-2012, 11:42 AM   #14
kalbert
I've got one of the Dynomax DIY kits with the cheapo Super Turbo mufflers. They were pretty quiet at first but after the packing gets settled they have a great tone. Noisy when you get into it, quiet when you're cruising. Not loud loud, but a good sound. It's lasted going on 12 years, starting to get a little thin around the clamps. Mufflers are also starting to come apart at the seams but by and large I've been very happy with it. Had I mounted the mufflers with the drain holes down they'd probably last longer...
kalbert is offline   Reply With Quote
Old 12-14-2012, 11:46 AM   #15
kalbert
...It's a chevy 305 with a 3/4 cam...
Was that Black Sheep or Tommy Boy? And what the heck is a 3/4 cam anyway
Old 12-14-2012, 12:01 PM   #16
Pyrotechnic
Black Sheep lol. I was waiting for someone to get the reference. I can't help but think of that movie everytime someone says 3/4 cam.
Old 12-15-2012, 01:49 PM   #17
Squareforceone
Squareforceone's Avatar
Got any pictures of the truck?
Rust is better than rice.
Squareforceone is offline   Reply With Quote
Old 02-13-2013, 01:38 PM   #18
cam-camaro
Heres a picture of the truck. By the way, I want to refrain from starting a new thread so hopefully you guys can help me. There is slight knocking/ticking sound coming from the engine bay and underneath the truck. I highly doubt it's a rod bearing( I replaced them ). The truck is a 1986 K10 305.
I'm thinking it may be a knock sensor( I don't know if this truck is suppose to have one or not)
Valve leash( I set it before I started the motor after the rebuilt, and it doesn't sound like a lifter, but then again, I'm an amateur).
Or possibly a loose bolt on the flywheel or flexplate.
Any ideas on how to diagnose this sound?
Old 02-14-2013, 11:10 AM   #19
motornut
78K & 79C Jimmys
motornut's Avatar
check your manifold doughnuts,see if they are loose or falling apart
John
Old 02-14-2013, 04:23 PM   #20
cam-camaro
If that will make a ticking sound then I'm pretty sure that's my problem. Each side of the exhaust/manifold hook up is missing a bolt because the stud on the manifold broke off.
Old 02-14-2013, 05:12 PM   #21
motornut
78K & 79C Jimmys
motornut's Avatar
rust/heat is a pain for those
look into brass nuts, two each stud
no rust one locks the other
John
Old 02-14-2013, 05:13 PM   #22
motornut
78K & 79C Jimmys
motornut's Avatar
gona have to fix that tho
John
Old 02-15-2013, 09:34 AM   #23
cam-camaro
Thanks I appreciate the advice! I'll be sure to do that. On another note, do you happen to know where the vacumn hose for the 4x4 hubs goes? It's automatic hubs so I know they run off a vacumn, I'm just not sure where. The 4x4 differentials work, the hubs just won't lock. I'm 90% sure it's a vacumn hose I left off when I rebuilt the motor I just don't know where.
Old 02-15-2013, 10:41 AM   #24
motornut
78K & 79C Jimmys
motornut's Avatar
vac line would be from the manifold ,usally behind the carb, to the tranny only
no vacuum needed for 4X4
auto hubs just engage
manuals have a twist dial
and full time has a solid plug
John
Old 02-15-2013, 10:55 AM   #25
cam-camaro
I thought they ran off a vacumn, possibly to the canister in the engine compartment. There is a line( VAC I'm assuming) that runs from the front differential to right above the canister, but it plugged off ( and always has been, even when the 4x4 previously worked). Maybe I'm missing a wire connection somewhere for the Auto-hubs. Any Ideas? The 4x4 worked before I rebuilt the motor, so I'm sure something is unplugged somewhere. The truck will still pull through the differential the hubs just won't lock.
