Old 12-17-2012, 11:24 PM   #1
Todd68Chevy
Todd68Chevy's Avatar
Parts from parting a 1972 Chevy C20
I disassembled a 72 Chevy C20 that I have had. The chassis is sold, cab and doghouse is very rusty and it did not have a bed. Here are most of the parts I saved from parting it out. The cab and left front fender are available for patch panel cuts but there is more bad than good. The truck was a running and driving truck until the engine stated knocking. All parts are used. Just ask if you want more pictures. Post to thread before PM as per rules.
All prices are plus shipping unless stated different
1. Cab patch panels $20.00 and up
2. Right front fender needs front inner cup repair $30.00 NO SHIPPING
3. Automatic brake pedal SOLD
4. Heater box- inside and has floor vent attached to it $18.00
5. Ashtray and bracket $10.00
6. Cig. lighter - element is not original $5.00
7. Coat hook $4.00
8. Sunvisors SOLD
9. Sunvisor clips SOLD
10. Cab vent $5.00
11. Door latch- body side $15.00 pair
12. Clutch delete plate $10.00
13. Washer tank bracket $4.00
14. Ignition switch with key SOLD
15. Kick panel vents with handles SOLD
16. Parking brake pedal $10.00
17. Dash harness with fuse box. truck had gauge cluster and no a/c, only issue I see is the brake light switch connector has 1 lock tab broken $25.00
18. Gas pedal, cable, bracket and the stud that attaches to the carb. SOLD
19. Small block oil dipstick & tube $5.00
20. Oil gauge metal line from engine to gauge SOLD
21. Modulator vacuum tube for th350 SOLD
22. Automatic shift linkage set up- rod from column down, pivot bracket, frame bracket, bracket attached to transmission SOLD
23. Steering column trim $5.00
24. Detent cable bracket SOLD
25. Heater box that attaches to the inside of the firewall- plastic with rubber seal $20.00
26. Wiper arms $10.00 pair
27. Wiper linkage $5.00 pair
28. Defrost vents- aftermarket black, installed a short time $10.00 pair
29. Glove box door - was blue but painted flat black but taped off the tag $15.00
30. Pair of 1972 doors - good over all condition- left side cracked at upped hinge, right side has hole on the inside bottom. some dents/ holes, with aftermarket outer mirrors SOLD
--Extra--72 door screw from another truck and 69 roller ashtray from another truck are also SOLD
Thanks for looking and ask any questions you might have and let me know if you want better pictures. Thanks
Note: All parts I have for sale are also for sale locally.
I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts.
Todd68Chevy is offline   Reply With Quote
Old 12-17-2012, 11:29 PM   #2
Todd68Chevy
Re: Parts from parting a 1972 Chevy C20
More pictures
Old 12-17-2012, 11:32 PM   #3
mo
Ill take the door screws if available and any chance you have the alternator brackets available. Shipped to 93013
mo is offline   Reply With Quote
Old 12-17-2012, 11:35 PM   #4
Todd68Chevy
door pictures
Old 12-17-2012, 11:39 PM   #5
Todd68Chevy
I might have a pair of screws in another truck but this one I am keeping the doors complete. I should be able to check the other truck tomorrow night. No engine so I do not have any bracket at this time. Sorry
More door pictures
Old 12-17-2012, 11:53 PM   #6
specialtyretail
So,, what else you got???
specialtyretail's Avatar
Some real good deals there Todd...
specialtyretail is offline   Reply With Quote
Old 12-19-2012, 09:10 PM   #7
Todd68Chevy
I have this pair of screws and spacers out of another 72. I wire wheeled them off and they look pretty good but one spacer has a small hole at the base that would be in the door (seen in picture 2). $15.00 shipped USPS Priority Mail or $12.29 shipped USPS First Class Mail. Let me know. Thanks
Old 12-19-2012, 09:12 PM   #8
Todd68Chevy
Thanks, I am hoping they are. LOL
Old 12-19-2012, 10:09 PM   #9
Olive1970
Olive1970's Avatar
Does the gas pedal parts come with the bracket that would go on the carb with kickdown?
Olive1970 is offline   Reply With Quote
Old 12-19-2012, 10:30 PM   #10
Todd68Chevy
The bracket that I am including is just for the throttle cable bracket I think. I do have a detent cable bracket that bolts to the intake I will include if you want it. I can get better pictures but here are the ones I have. Thanks
Old 12-19-2012, 10:41 PM   #11
Olive1970
Olive1970's Avatar
Those pictures work great for me, were you looking for $45 shipped for the ride up to MI for all pieces? If so, I will take it
Its been a few years since I had a 72, does the throttle bracket go under the carb stud?
Old 12-19-2012, 10:52 PM   #12
Todd68Chevy
Prices were all plus shipping. If you give me your zip code then I will figure shipping tomorrow and see what we can work out on a final price.
I did not remove either bracket so I am not sure where they were mounted. I might be able to find out.
Old 12-19-2012, 10:55 PM   #13
Olive1970
Olive1970's Avatar
Sounds good, my zip is 49323. Let me know what you come up with, thanks again
Old 12-19-2012, 11:01 PM   #14
budnikguy
budnikguy's Avatar
"Ignition switch with key $10.00"
Could you throw in the matching door locks and go $15.00 shipped?
budnikguy is offline   Reply With Quote
Old 12-19-2012, 11:56 PM   #15
Todd68Chevy
I was planning on keeping the doors together but I guess it would make more since to include the locks with the ignition. I would pull the door locks out and go $20.00 plus shipping for the ignition, both door locks and the keys if you are interested but I can not go 15.00 shipped. Sorry but let me know if you are still interested. Thanks
Old 12-20-2012, 12:36 AM   #16
budnikguy
budnikguy's Avatar
Would go $20 shipped if they all function as they should.
Old 12-20-2012, 12:47 AM   #17
Rickey
Rickey's Avatar
I need the jack handle price + shipping to 75142
Thanks Rickey
Rickey is offline   Reply With Quote
Old 12-20-2012, 02:45 AM   #18
thelonerife
thelonerife's Avatar
Todd If you still have the doors I'll look at those when we get the frame.
thelonerife is offline   Reply With Quote
Old 12-20-2012, 09:13 AM   #19
Todd68Chevy
I have a meeting after work but should be able to figure it when I get home tonight. Thanks
I need a zip code to figure shipping and after I figure the shipping cost I will give you my bottom dollar shipped price. Are you wanting the entire ignition switch or just the lock cylinder part of it? It will make a difference in the shipping and price. Thanks
Thanks Rickey
I have a meeting after work tonight but should be able to figure it when I get home. Thanks
Sounds good Chuck
Old 12-20-2012, 11:30 AM   #20
budnikguy
budnikguy's Avatar
just the lock cylinder part for the ignition...should all fir in a small flat rate box, my zip is 92557.
Old 12-20-2012, 07:12 PM   #21
asolde
asolde's Avatar
Is the Modulator vacuum tube in good shape, any kinks, and dose it have the tab on it where it bolt to the bell housing? Can you post a better picture of it?
I am interested in the ash tray and bracket. Would you separate the door panels with arm rest? If so how much shipped to 77339 for all?
asolde is offline   Reply With Quote
Old 12-20-2012, 07:18 PM   #22
projectjimmie68
Cool Re: Parts from parting a 1972 Chevy C20
Is the ashtray still available? If so I will take it.... Thanks Projectjimmie
projectjimmie68 is offline   Reply With Quote
Old 12-20-2012, 11:02 PM   #23
Todd68Chevy
Throttle pedal, cable, throttle cable bracket, detent cable bracket and stud for carb. that the carb hooks to. $50.00 shipped I will get better pictures tomorrow Thanks
Thanks Rickey
$5.00 plus shipping but it will be tomorrow night before I can figure that and get better pictures, Thanks
If you just want the 3 lock cylinders and not the ignition spacer and switch, I will take $20.00 shipped if paid with out PayPal fees, so either PayPal gift or Money order. I should be able to get the doors apart and get pictures/ check operation tomorrow night or Saturday. Thanks
I believe it is good and has the bracket but I can get better pictures tomorrow night. I will also get better pictures of the ashtray. I might seperate the door panels but I have several other panels. Are you looking for this color/ style? Thanks
This one might be sold but I have other ones. Do you need blue or just an ashtray? I think I have another blue one. I will check tomorrow night or Saturday. Thanks
Old 12-21-2012, 03:13 AM   #24
projectjimmie68
Blue would be fine if you have one. Price shipped to zip 32136...Thanks Projectjimmie
Old 12-21-2012, 09:21 AM   #25
asolde
asolde's Avatar
I am looking for door panels that style and that color in very good shape,those looked pretty good. I will take the ashtray / bracket and the Modulator vacuum tube. PM me your payment information
