Re: original (not modified) truck pics
I still want that painted gas cap Joe. LoL
question about that: were painted gas caps stock? Mine had one when I got it, but figured it might be something a dealer did.
Figure out what you want--then figure out what you are willing to give up to get it. |
My 71 GMC, bought new at Lynch Motor Cars (Cadillac Pontiac GMC) in LaGrande Oregon. By Globe Furniture. Globe is located across the street from the dealership, which is still there except it is now a Aaron's rental store. It's all stock and will stay that way !
71 C-20 07 Magnum RT AWD |
![]() Join Date: May 2001
Painted gas caps were on Custom and Custom Deluxe trucks, Cheyenne had chrome. For 71 & 72 anyway
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
The Niner
![]() Join Date: Nov 2010
Awesome rides Joe!
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
There's some real nice trucks in here.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 Last edited by YBNORML; 12-29-2012 at 06:45 PM. |
![]() Join Date: Dec 2011
Joe- looks like that ochre one still has the original gas cap?
1972 Cheyenne Super 10 SWB,bucket seats,dealer cruise,tilt,tac,a/c,shoulder belts, 350/350 1971 K-10 Custom Deluxe 1971 K-10 Custom |
![]() Join Date: Mar 2010
joe, #42 shows the rear end with no aluminum trim around the tail lights and tail gate. Was that the way it came? just curious.
so many beautiful trucks! Special K, I have sliding rear window, I think I'll go check out the leaking water issue as soon as it warms up a bit, thanks 67 anthony, what color is your truck? I like it a lot Last edited by dads longhorn; 12-29-2012 at 05:32 PM. |
#9 | |
If you can pull the gasket back (going to be tough,if not impossible) to see if they used a caulk is the question. I think the problem was the caulk,it shouldn't be necessary. Once it dried and cracked it didn't seal and it causes separation to prevent the seal from doing it's job. I had one spot of surface rust peaking out about the window on the right,maybe 3/4" high and 1"-2" wide. When I removed the window and gasket it was all the way across top and bottom. The sides were fine,I guess,because they drained. Here are some that aren't mine:
Thanks for sharing guys, some very nice stuff here.
#11 | |
Wow,that truck is truly unique. I know rear trim only came with side trim,but Custom Deluxes cme with lower side trim. This truck was ordered lower molding delete,I guess. Does it mention that on the SPID? I've never seen a Custom Deluxe w/o trim. I realize it's possible because I had a solid Ochre BBC SWB Highlander with upper trim-only and a 3spd. Bought it in '73 from the OK Used Car lot...definitely was all original. I think it had about 3k on the odo.
You're right, it does. I bought it from the original owners back in 1997, and it had just turned 50k miles. They had extra gas tanks in the bed and had removed that original gas cap to make a special one that fed off the tanks in the bed. Anyway, several years later I stopped by to show the lady the truck (I had it all polished up and removed the camper and old split rim wheels) and she said, look what I found, the original gas cap!! She said it needed to be back on the truck, so there it is
![]() Join Date: May 2011
my 69
#15 |
#16 |
The Niner
^^You've driven it 21 miles since you got it?
What are your plans with it?
#17 |
Yes, thats all. It didnt run right when I got it, so I only took a few trips around the block in it. We rebuilt the carb and it seem to be running good now, but still havent taken it out on the road yet. The only plan for it is a really good detail, like the rubber floor mat, and cleaning the engine compartment. It also has some scuffs that need to be polished out. And BTW, you have an excellent looking truck!
#18 | |
The Niner
#19 |
Ok,well I guess all got the trim ordered that I've seen and that misled me.
#20 |
Most you see do have trim. I actually wish mine had lower trim. I have all nos lower black trim for it if I could bring myself to do it lol
#21 |
DO IT !!!!!! Just think of it as correcting a birth defect.
72 Cheyenne Super 80 Silverado Blazer 2wd |
#22 |
Yeah,you hate to change 'em when they're so cherry and original. I think I make this same mistake every couple of years,Someone corrects me,I go check out some literature,and see they didn't come with trim. Then I forget because trim is the only way I ever see them
![]() I agree with you guys,those Accu-Rides are the way to go. I have set but haven't gotten new tires,yet.
#23 |
![]() Join Date: May 2012
here is a few pic's of mine...
#24 |
Ill post a few of mine when i can, its original not as pretty as the others but its stock
Posted via Mobile Device |
#25 |
my DD 67 GMC custom 115k miles
