Old 09-20-2020, 01:33 PM   #1
Jesse49chevy
Jesse49chevy's Avatar
Re: Jesses' 48 PU
Originally Posted by 8man View Post
Jesse, I had to do some grinding in the hinge holes that go into the door to give me enough "slop" to adjust the door, and these are original doors, hinges and cab. After getting the belt all lined up, I still have a little gap at the bottom, similar to what you have, just not quite as much now that the rest of the door is fitting better. Hope that helps.
So I find myself doing things twice, I think I could have built two trucks by now. My intention was to use the original hinges, I bought the pin/bushing kit and the face plates. But I simply could not drive out the old pins. I tried all I could think of, heat, hammer, even my 20 ton press couldnt drive out the pin. So I resorted to new hinges. Well apparently these Taiwan made hinges are not the answer. The doors just will not line up. So I took the originals to the machine shop to have the pins milled out. I didnt trust myself with my wobbly drill press set up and felt I would ruin them. I should get them back next week and we will see if they line up.
Meanwhile, im working on running the Wilwood universal emergency brake kit. Wish I had a lift like yours, im to old to be crawling in and out from under the truck.. LOL..
Semper Fi
Check out my project:
http://67-72chevytrucks.com/vboard/s...d.php?t=559086
Jesse49chevy is offline   Reply With Quote
Old 09-21-2020, 08:55 AM   #2
8man
Re: Jesses' 48 PU
Good for you. I had to rebuild all the door hinges. However, that may not fix all the door fitment issues.
I crawled under mine over and over, it hasn't been on the lift yet, and I'm way older!
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 09-14-2020, 01:18 PM   #3
Jesse49chevy
Re: Jesses' 48 PU
I also used an emergency brake set up from a modern S10. I wanted a push/release assembly. Simple install, used the hinge hole for the top so that bolt will sinch down on the hinge and the brake assembly, welded two bolts to the kick panel and whaalaa... done. Routed the cable through the original ebrake pedal hole.
Semper Fi
Old 09-14-2020, 01:27 PM   #4
Jesse49chevy
Re: Jesses' 48 PU
Okay need advise... I quickly threw on the passenger door and know it needs adjusting. But this kept me up all night. I noticed the gap on the bottom. Obviously not the original doors to this cab. I am using new hinges from Classic Industries.
As we all know the hinge holes to the cab are slotted for up/down adjustment. How in the world can I adjust the bottom of the door to move in? Should I slot the holes for side adjustment? Has anyone faced this dilema?
Semper Fi
Old 09-14-2020, 01:48 PM   #5
gigamanx
Re: Jesses' 48 PU
Got a picture? My first thought is that the hinge or hinge plate in the door are bent if the door is sticking out at the bottom. Not a lot of adjustment other than a shim or two inside the door. That might move it 1/8" or so
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 09-14-2020, 02:07 PM   #6
Jesse49chevy
Re: Jesses' 48 PU
Yes her is some pics... will try to load up a short video as well.
Semper Fi
Old 09-14-2020, 02:16 PM   #7
Jesse49chevy
Re: Jesses' 48 PU
I couldnt load up my video. But I noticed the top front of the door makes contact. So obviously it needs to drop down an 8th or so, but it also needs to come out from the top and in from the bottom. So maybe I shim the top out and the bottom in...
Semper Fi
Old 11-01-2020, 03:38 PM   #8
Jesse49chevy
Re: Jesses' 48 PU
Been MIA for a bit.. have been traveling due to business and less time spent at home, I got the hinges back from the machine shop, installed the new pins and doors fit much better. The passenger side door went on with no issues, the driver side door still has a small gap at the bottom, I enlarged the holes to give it sideways adjustment and the gap is much smaller now. Still not happy with it, but stepped away from it for a bit.
Semper Fi
Old 11-09-2020, 02:44 AM   #9
MiraclePieCo
MiraclePieCo's Avatar
Re: Jesses' 48 PU
Huge improvement, I'd be thrilled if mine fit that good.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 11-09-2020, 07:30 PM   #10
jweb
jweb's Avatar
Re: Jesses' 48 PU
I had a similar problem with my doors. You may need to bend the hinges slightly.
Take a look at post #17 here http://67-72chevytrucks.com/vboard/s...d.php?t=578310
You may want to wait until you have the seals on your doors to get them set up just right.
1951 Truck, LS1/4L60
1964 Suburban, current project
jweb is offline   Reply With Quote
Old 05-02-2021, 07:53 PM   #11
Jesse49chevy
Re: Jesses' 48 PU
Well its been a minute since I post an update. Between fighting Covid, work (so grateful to have still have a job) and the daily hustle its been challenging to keep up. I have been working on my truck here and there. I finally got to the trans cooler, wasnt sure where to put it and decided to go with where the battery used to live. Ran AN-6 lines and made some brackets to hold it in place.
Semper Fi
Old 05-02-2021, 08:02 PM   #12
Jesse49chevy
Re: Jesses' 48 PU
I was undecided on the window regulators as I have the originals, but after taking a close look at them. It seems as if someone tried some backwoods engineering repairs and the plastic roller thingys gone as well. I opted to buy new ones. So this weekend I decided to work on the doors. I layed down some Eastwood Thermo Coustic Barrier. It lays down easy, but obviously clening the inside and working the sheets inside the door is challenging... getting my fat hands and arms in and out of the inspection holes was... well lets just say it tested my patience... after numerous choice words, my arm getting stuck a few times... I finally got the job done. The doors sound solid now, no more empty can noise... but one thing I did not consider was the weight... the doors seem heavy now... so scratching my head... wish I would have done a little more research...
Semper Fi
Old 05-02-2021, 08:05 PM   #13
Jesse49chevy
Re: Jesses' 48 PU
My hands and arms look as if I got in a fight with a cat...
Semper Fi
Old 05-02-2021, 08:10 PM   #14
Jesse49chevy
Re: Jesses' 48 PU
After fighting that cat, I installed the window regulator, door latch and the door seal... I was dreading it as I was afraid to screw it up. After watching Jerry Kassis with Dr. J's Restoration on YouTube about 100 times... I built up the courage to go for it... a little messy but glad I watched his detailed video... so left door done and installed.
Semper Fi
Old 05-02-2021, 08:25 PM   #15
Jesse49chevy
Re: Jesses' 48 PU
Radiator is on for good as well...
Semper Fi
Old 05-04-2021, 08:34 AM   #16
8man
Re: Jesses' 48 PU
You're getting there. Looks good.
8man-aka Robert
Old 05-13-2021, 10:20 PM   #17
Jesse49chevy
Re: Jesses' 48 PU
Continued the sound/heat barrier project. Glad to finally have the cab floor, firewall and rear panel done.
Semper Fi
Old 05-14-2021, 08:29 AM   #18
8man
Re: Jesses' 48 PU
That should work!
8man-aka Robert
Old 05-14-2021, 09:32 AM   #19
57FleetsideC4
Re: Jesses' 48 PU
That should dampen and insulate great. Looks awesome. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 06-03-2021, 11:27 PM   #20
Jesse49chevy
Re: Jesses' 48 PU
Took advantage of the long weekend, set up my garage as a paint booth and sprayed the matte finish clear on the cab and fenders...here is my home made filter system.
Built a screen with A/C filters and box fans. I guess it worked. Neighbors didnt complain.
Semper Fi
Old 06-03-2021, 11:33 PM   #21
Jesse49chevy
Re: Jesses' 48 PU
Clear was still wet, but it dried to a satin finish. No lines or overspray. So guess my dad taught me well..
Semper Fi
Old 06-03-2021, 11:37 PM   #22
Jesse49chevy
Re: Jesses' 48 PU
Finally installed the grille and front bumper... I had to redo my front bumper brackets
Semper Fi
Old 06-04-2021, 12:08 AM   #23
dsraven
Re: Jesses' 48 PU
Um, I think you forgot to put the color coat on....haha
Looks good. Nice to get to that stage eh?
Old 06-04-2021, 12:51 AM   #24
Jesse49chevy
Re: Jesses' 48 PU
I get that a lot... people always ask "so what color are you going to paint it?"
So that tells me that my custom "patina" paint job is good enough that it actually looks old.
Lol...
Semper Fi
Old 06-04-2021, 12:59 AM   #25
dsraven
Re: Jesses' 48 PU
Patina isn't my thing but I get it. I spent too many years driving patina to want that anymore if I can afford a paint job. I get it but it's not me. I have had guys tell me they would be happy to buy my old doors etc because of the awesome patina. Nope, just gonna paint it, thanks.
Dont take it the wrong way, it's just my history. When other guys could afford a nice paint job I was driving patina. Now I would rather have the nice paint job.
