Old 01-21-2013, 01:06 PM   #1
UATahoe
Need help on gears for my 87 R10 and new 383
I am about to install a 383 motor into my 87. It has a 700r4 tranny and the current rear is an open 2.73. I will never be racing the truck obviously and gas mileage is my min concern but I read a few posts here where people actually gained mpg going to a 3.42 or 3.73 gear ratio. Given the new motor and additional power should I change the gearing or am I going to get the best mileage out of the 2.73's? Thanks for the input!
UATahoe is offline   Reply With Quote
Old 01-21-2013, 01:15 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Need help on gears for my 87 R10 and new 383
3.73 gears will be perfect for that truck, with the overdrive trans.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-21-2013, 01:17 PM   #3
UATahoe
Will it actually drop my mpg or help it? I always thought going to a 3.43 or 3.72 would hurt gas mileage. I appreciate all of the help.
Old 01-21-2013, 02:27 PM   #4
UATahoe
Should also add I am running 31x10.5 tires and its a 2wd.
Old 01-21-2013, 02:41 PM   #5
kelsfine69
18 Till I Die
kelsfine69's Avatar
I would go 3:42 since you have the overdrive trans M2C
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 01-21-2013, 04:07 PM   #6
INSIDIOUS '86
INSIDIOUS '86's Avatar
Mileage in city may be better but you may lose some highway mileage.
Where does your engine feel strongest? Not fastest or anything but the happy spot where it cruises?
3:42-3:73 is your range. 3:42 aren't bad for that big first gear and racing. 3:73 gears may actually over gear you on the track and make you lose time.
So we need to know some engine specs too
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 01-21-2013, 04:12 PM   #7
Jonboy
Slots go on anything!
With the 31's, I would look at the 3.73's. If you will be sicking with that tall of a tire, 3.90's may not be out of the question, either.
Jonboy is offline   Reply With Quote
Old 01-21-2013, 04:29 PM   #8
UATahoe
Engine specs:
The crankshaft is by "EAGLE" products, with 5.7" long I-beam rods and SpeedPro pistons with moly rings, giving pump gas friendly (9.2to1) compression ratio. A custom ground hydraulic roller camshaft and lifters, spec's (210/220`@.050" with .500" lift on 112`LSA) with matching valve springs with a power range of 1500-5000 rpm's.
Expecting 360hp and 410 ft.lbs. torque.
Haven't installed the motor yet. Should receive it in about 2 weeks. The truck will never see the track but will be a daily driver with a mix if city and hwy driving hence the goal to maximize mpg. How will the stock gearing do as opposed to a different ratio?
Thanks again for all the info and help!
Old 01-21-2013, 05:28 PM   #9
Keith Seymore
Originally Posted by UATahoe View Post
Engine specs:
The stock gearing with those tires will kill it. You will need at least the 3.73's.
K
1979-1986
1986 - 2019
Old 01-21-2013, 05:44 PM   #10
UATahoe
That's what I was thinking on the 2.73. And I was hesitant to change thinking it would kill gas mileage. How do I figure out which gears I need? I think 3.73 are probably best but picking the right set in summits website is confusing. Don't really know the specs on my rear end.
Old 01-22-2013, 11:44 AM   #11
UATahoe
Keith, do i need to look into a posi as well?
Old 01-22-2013, 11:58 AM   #12
ont_guy_38
ont_guy_38's Avatar
Motor sounds similar to my setup, i have a turbo 400 with 4:10 gears. A 700 tranny with 373 gears would be about perfect. If you are getting new gears installed you might as well put a posi in at the same time instead of paying twice, as you will probably find you will need the posi.
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 01-22-2013, 12:07 PM   #13
UATahoe
373 definitely seem to be a popular vote. Now i just have to figure out the details of rear so i can get the right set.
Old 01-22-2013, 12:37 PM   #14
Keith Seymore
x2.
I always like to have a "non-open" diff.
K
1979-1986
1986 - 2019
Old 01-22-2013, 12:49 PM   #15
UATahoe
Suggestions on which diff to use and brand of gear? This is like rolling a snowball down hill. LOL. Never as easy as just swapping out the motor. LOL
Old 01-22-2013, 12:53 PM   #16
ont_guy_38
ont_guy_38's Avatar
I got a eaton from a 8.5 nova/camaro in mine, works awesome
1985 C10
2004 Avalanche
Old 01-22-2013, 12:55 PM   #17
Ziegelsteinfaust
Use this.
http://www.richmondgear.com/101032.html
I like to set my drive rpm at 75 at 2200 rpm. That way I can use a 2000 rpm converter, and that leaves me enough of a hole shot not to need the extra gearing.
So I would use a 3.90 gear which summit sells for the 8.5.
Ziegelsteinfaust is offline   Reply With Quote
Old 01-22-2013, 12:56 PM   #18
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I use engine torque curves to set the ratio. Do you know the projected curve? Put cruise speed RPM at max torque possible.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 01-22-2013, 12:56 PM   #19
Scotty-D
Scotty-D's Avatar
My 383 is very similar to yours and I also have a 2.73 rear gear in a LWB truck, although I swapped in a th350.
The 2.73 rear is horrible. Even as torquey as the motor is, it's a real yawner at low speeds...and I just have a 29" tire. Ill be going to 3.42's and a 28" tire shortly and I expect it to be a night and day difference.
With your taller tire, I'd say the guys above who suggested the 3.73's are spot on.
85 Scottsdale LWB
383 227/235 105 lsa Howards Roller
TH350 by Jakes Performance, Sanger TX
Scotty-D is offline   Reply With Quote
Old 01-22-2013, 12:58 PM   #20
UATahoe
What is the over drive ratio?? We are definitely moving into the way over my head category. My main concern is trying to balance mpg and performance and i would be willing to sacrifice a little performance to help on gas mileage.
Old 01-22-2013, 12:59 PM   #21
Scotty-D
Scotty-D's Avatar
.70 for a 700
85 Scottsdale LWB
Old 01-22-2013, 01:01 PM   #22
UATahoe
gchemist, i do not know the projected curve. i can try to find out what has been typical though.
Old 01-22-2013, 01:03 PM   #23
UATahoe
Got it. So with a 3.73 ratio,31" tire and a speed of 75mph, i would be turning at 2122rpms with the 700 tranny? I guess that goes back to finding the sweet spot of the motor at cruising speed. 2100 seems pretty goood though. Looks like right now with the 2.73's i am running at 1553 rpm at 75mph. That seems way low. I wonder how that will effect hwy mileage??
Old 01-22-2013, 02:42 PM   #24
UATahoe
3.42's totally out of the question? Found a brand new set here locally with a brand new posi unti as well for 350. They are Yukon brand never installed. Seemed like a really good deal.
Old 01-22-2013, 03:11 PM   #25
INSIDIOUS '86
3:42 will give you some better highway mileage but you may be a little low on rpm on the highway with them tall tires. City mileage will be about the Same. Add a posi if you want to get anywere anytime soon. Richmond and Yukon gears are god long lasting gears. Eaton posi is recomended as well
