07-18-2014, 11:06 AM | #1 |
Vintage Evil
Re: Crown Vic front end on a 67-72?
They have done it on Gas Monkey a couple times... but its usually to Fords...
Current Rides: Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread EvilK5 - 71 K5 Blazer Evil Twin - 2006 Suzuki M109R EvilDmax- 2018 GMC 2500 Denali Duramax |
07-19-2014, 12:27 AM | #2 |
Thank you. I'm in Morgan Hill now. Also I know That they have done it on the Ass Monkey show. Keep in mind I set this up two years ago, before the show and the f100 frame is the same width as the crown vic alum cross member. On a f100 all you have to do is reinforce the c channel for the four factory bolts. and mount the arm bushings. The hardest part of the swap is ensuring the suspension is square to a frame that tappers and rises unlike the ford. Good luck and let me know if I can help. I also do Fab at my House shop so if you are in the bay area come and check it out. The truck should be at the next Good Guys show in Pleasanton this summer
07-19-2014, 12:32 AM | #3 |
I'm in West San Jose. I'd like to check it out sometime. I can cruse my truck down in like 3 years when it's running again lol
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
07-19-2014, 12:36 AM | #4 |
Haha trailer it down I can do some work on it for you
10-20-2014, 06:05 PM | #5 |
FMCustomz - I have a few f100s and a couple crown vics, Im hoping to find somebody that can do the swap on the running gear and motor/transmissions. Is this something you would be interested in? Im just outside of Modesto, so Morgan Hill isnt too far for me.
10-21-2014, 08:16 AM | #6 |
Just FYI you can cut 5" out of the center of the crown vic K member and a 79 mustang rack will bolt right back up so you dont have to cut the crown vic rack, this is one my friend in Alabama done
66 C10 79 GMC Sierra 64,000 original miles 81 C10 Keep changing my mind about what to do with |
10-21-2014, 12:36 PM | #7 |
FM Custom, how mush fabrication was involved? Did you have to cut a lot of the frame? Make any brackets?
10-27-2014, 10:23 AM | #8 |
Happy to be here
Once again I am curious as why anyone would use the C/V IFS when the 73-87 IFS is a bolt in.
12-07-2014, 08:59 AM | #9 | |
archie
1972 C10 LWB factory buckets 350/350 PS,PB Factory Leaf springs with overloads (The Dog Riding Truck) |
10-27-2014, 01:37 PM | #10 |
Well for me seemed more inexpensive to get the IRS rack and pinion in one shot. After market for the same is in the $2000 range. Also I have a ford wheel in mind that I want to run, (it is not available in a chevy pattern).
12-18-2014, 10:20 AM | #11 | |
There are so many options for these trucks and even if you couldn't find what you liked, I would have to think that you could get custom wheels for not much more than what it would cost you for the conversion. Sometimes spending a few dollars more in the beginning, is cheaper in the longrun
______________________ www.northeastrodrun.com |
12-07-2014, 12:11 PM | #12 |
I do not feel the suspension geometry is better then a modified cross member having riden in both. The brakes are taller and thinner vs the heavier 1/2 ton. So better is likely negligible. Big brake kits with SRT8 parts are easy which is only really plus. Converting drum spindles gets complicated on alignment.
The rack is a plus but factory setting suck. So a rebuild is in order. For a Ford I wouldn't hesitate to do one, bit on a Chevy I would like use Jag parts. Forgive me Ireland. The jag handles awesome takes junkyard big brake kits just as easy, an is steel so fabrication is easier. Forgot to mention the rear A-arm mount sits pretty far back causing issues with a frame section, and the cross member hangs low. The jag has better after market support. Forgive me Ireland. Plus a whole car is easier to get for less then a 1000, an you can. Have IRS too. |
12-15-2014, 04:42 PM | #13 |
Hi guys, check this out. http://stockton.craigslist.org/pts/4781441509.html Not trying to step on anyone's toes. I've thought about this too but in the end I'm a 6 lug type of guy.
What I really want to do is set my 70 SWB on a 2000 + chassis. Has anyone on here done this ? If so please share a link if you have one : ) My OG chassis is done in por-15, cross member is powder coated and CPP tubular control arms are ready to be installed. Ohh and some ece dropped spindles and springs. I'm doing a poor mans build, at the rate I'm going it would be best to just get a rolled over truck with everything on it. |
12-15-2014, 08:06 PM | #14 |
The frames are to different and the body almost has to be chanelled over the frame. Which is a lot of work.
Maybe for a lifted truck a slight body lift wouldn't be noticeable, but for a dropped truck it would be to much. Guys have done it with the gmt-400 trucks which are closer to our trucks bit still way different. |
12-15-2014, 08:37 PM | #15 |
Thank you Ziegelsteinfaust, 3 or 4 years ago I seen a guy do it on a "forum" not sure if it was here. I've searched foogle long and wide for his post and nothing. I would like to use that guys swap as a guide. If I remember correctly he was somewhat detailed about how he did the swap. PLEASE if anyone out there knows about that truck (it was yellow) please let me know. It was also a 2 wheel drive Ziegelsteinfaust, the money shot lies here, I don't remember if it looked funny or not If anyone else has done it please share the link : ) Thx
12-16-2014, 12:03 PM | #16 |
I have seen the gmt400 swap and it looked awesome, but for the amount of work I could of done 2 square body's laying frame. It is all how you do the sheet metal and you better have the skills.
12-17-2014, 03:18 PM | #17 |
Doesnt that option require the light duty brake option or spindles/rotors
12-17-2014, 06:03 PM | #18 |
From what i read in the thread i linked i took it as only the 1" rotors.
12-17-2014, 07:55 PM | #19 |
Or use 1.25" HD spindles/rotors/brakes & re-drill the rotors to the car pattern.
12-18-2014, 11:12 AM | #20 |
You can do the CV swap for about the $500 if there is nothing that needs to be replaced. Doing the work yourself.
If you find one at pick a part your south of $300, but the effort may not be worth it. Still my preference is for mods to the stock cross member or jag swap. I have a CV under my F100 project, and I wish I did jag. It would of been easier to go lower, and easier to fab in the cross member. |
12-21-2014, 01:44 PM | #21 |
To comment on a couple things reading through the thread,
The crown vic/grand marquis weighs just as much as your truck if you put somebody in all the seats, so strength isn't going to be an issue. My grand marquis crosses the scales at 4150 pounds with me in it and my usual trunk load. The rack and pinion steering is 2003MY and up. Brakes are virtually the same size as the stock truck brakes, ~12" diameter. 4 piston calipers. The pre '95/watts link cvgm is rated to tow 5000 pounds with smaller brakes. I wouldn't be concerned about stopping ability. Front springs: if it comes from a cop car, you have 1050lb/in springs--inline with the truck extra HD front coil springs. Passenger cars are significantly more forgiving. Can dig out the numbers if anybody wants. Alex. |
02-04-2015, 12:30 AM | #22 |
after the did the conversion I had to swap out the p71 coils for the standard crown vic coils. I think they are 700lb springs if I remember right and also I made adapter mounting plates so the system is bolt on to stock uncut frame
