Old 01-24-2013, 11:45 PM   #1
chev3600
chev3600's Avatar
49/54 LS driver
I figured after several years of lurking and learning, it may be time to at least start a thread on where my truck is NOW> So, there is a huge separation between what you "plan to do" and what you actually do.
My truck is a mutt. It was assembled by me using whatever I thought was cool or was handy at the time. Ive had to back track a few times and learned that the cheap or easy way isn't always an option.
For starters, its a 1949 3100 with a 54 cab and bed. Ive always preferred the one piece windshield. This is the day I dragged it home. The PO installed a camaro clip and rear end.
I initially started building it with a TBI 305 and 700r4 with a fuel cell mounted in the rear. It was all but drivable, It just couldnt seem to go all the way around the block on its own. Fed up, yanked it out and decided that I needed clarity. And a much newer fuel injection setup. Bought a 5.3 LS out of an 02 silverado and 4l60e trans.
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 01-24-2013, 11:55 PM   #2
chev3600
chev3600's Avatar
Re: 49/54 LS driver
Alot of this is out of order, sorry. I used the original engine harness and rewired it myself. Wow, what a daunting task! The rear end was swapped out for an explorer 8.8 because I liked the idea of limited slip and disc brakes in a strong and inexpensive package. Unfortunately, the rear of the frame wasn't in great shape and the PO had done some shoddy fab work on the spring mounts. So I bolted a set of s10 hangers under the frame and welded the rear shackle mounts onto the existing frame. The s10 frame was taller, so I had to section the frame stub.
Old 01-25-2013, 12:06 AM   #3
chev3600
chev3600's Avatar
Re: 49/54 LS driver
The body needed some attention too of course. someone had installed a new floor pan and done a great job. But the PO didnt follow the same level of craftmanship and botched the cab corners and the lower hinge pillars. I found out that he also welded the toeboard in and the Pillar between the door hinges about 3/4 of an inch too short. End result is that I had to split the firewall and raise the body 3/4" higher off the floor. Sounds terrible right? I hate body work, but i hate paying others to do it more. So new cab corners, new kick panels, new rockers, new lower door skins inner and outer, and we have something that you can actually assemble.
Old 01-25-2013, 12:20 AM   #4
chev3600
chev3600's Avatar
Re: 49/54 LS driver
This build was as much for my enjoyment as my two boys. The wife doesn't seem interested, but puts up with us. With the kids in mind, safety was key. I added three point seat belts from a 99 dakota and a second row seat from a durango. Very comfy and nice fit.
As long as we're inside the truck, I put autometer quad gauges into the factory gauge buckets and installed a new wiring harness.
Ive found the majority of a vintage air A/c and heater and am trying to get that assembled here soon. I attempted power windows but the motors were junk and couldnt lift the glass. So the manual stuff is fine for me. I did install a set of bear claw latches and AVS shaved handle kit. I am leaving the outer door handles because I like the look, but they are currently non functional.
Ive almost finished the windshield wiper setup using a surplus boat wiper motor found online (Thanks mknittle)
Old 01-25-2013, 12:31 AM   #5
chev3600
chev3600's Avatar
Re: 49/54 LS driver
I lost a bunch of pics but there are still some in the photobucket link in my sig. More are being put in as time allows. Here's the bed. Polished stainless strips and wood I got from home depot and cut, routed, sanded, stained and finished in the driveway.
I ended up using a Jeep wrangler gas tank out back with a modified BMW fuel pump mounted internally. I love the power and smoothness of the LS. So far I've got almost 500 miles on the truck since road worthy and havent had a major hiccup. The exhaust guy bent the tailpipes too close to the axle, and I still have so many parts to get it closer to done, but getting it on the road was the turning point for this dream of driving an AD truck. Ive been working toward this for 15 years with 3 different heaps of truck parts and rust. It will be painted some day but I have several other distractions.
Old 01-25-2013, 12:36 AM   #6
chev3600
chev3600's Avatar
Re: 49/54 LS driver
Today it looks like this.
Old 01-25-2013, 01:38 AM   #7
4544speed
4544speed's Avatar
Re: 49/54 LS driver
Great looking build you got going. I really like the seat choice and the seat belts.
AND the engine choice !!
4544speed is offline   Reply With Quote
Old 01-25-2013, 09:00 AM   #8
xpickup
xpickup's Avatar
Re: 49/54 LS driver
chev3600, Nice looking truck.
Shannon
xpickup is offline   Reply With Quote
Old 01-25-2013, 02:12 PM   #9
chev3600
chev3600's Avatar
Re: 49/54 LS driver
Thanks, I wish I would have just gone LS from the start. Would have been driving a long time ago.
XPickup, I really like the look of your panel. Been trying to find a suburban for a while, it's the only thing that would talk me out of this truck.
Old 01-25-2013, 02:43 PM   #10
oldman3
oldman3's Avatar
Re: 49/54 LS driver
Great story and the truck looks great, enjoy....Jim
oldman3 is offline   Reply With Quote
Old 01-25-2013, 05:40 PM   #11
BlueJeep
BlueJeep's Avatar
Re: 49/54 LS driver
Looks great! Enjoy driving it with your kids!
What did you use for a thermostat housing, did you use the original or did you get a straight one? How did you plumb the steam fitting coming from the throttle body? Where did you source the intake fittings from?
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 01-25-2013, 09:14 PM   #12
chev3600
chev3600's Avatar
Re: 49/54 LS driver
Bluejeep- for the thermostat housing I used a 90 degree swiveling one for a regular small block chevy. It had an o-ring seal so I trimmed down a camaro thermostat just a little to fit the inner dimension. Slotted the holes ever so slightly and made offset bushing to go in the mounting holes.
The steam port I drilled and tapped the top of the water pump.
The air intake was a kit from ebay for a tahoe. 50 bucks worth of pieces to make something better later. Pics tommorrow if I don't forget.
Old 01-25-2013, 09:33 PM   #13
chev3600
chev3600's Avatar
Re: 49/54 LS driver
Thermostat was just like this one- http://www.ebay.com/itm/SBC-Swivel-T...-/400291038466
Intake like this- http://www.ebay.com/itm/00-06-Suburb...d64320&vxp=mtr
and thermostat pics with steam port
Old 01-26-2013, 10:30 AM   #14
72ArizonaBurb
Re: 49/54 LS driver
Looking good!
72ArizonaBurb is offline   Reply With Quote
Old 06-26-2013, 09:19 AM   #15
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: 49/54 LS driver
I cant believe I didnt see this build earlier. Truck looks killer Matt.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 06-26-2013, 10:15 AM   #16
oldman3
oldman3's Avatar
Re: 49/54 LS driver
Matt, what's the latest with your build, any updates...Jim
Old 06-26-2013, 02:47 PM   #17
chev3600
chev3600's Avatar
Re: 49/54 LS driver
Wish I had real updates. I've been assembling various parts to attempt air conditioning. Really just been enjoying it, I've put about 1200 miles thus far. Also put some cool buttons in the door handle to actuate the poppers. I hated having to push a button on a key fob everytime to open the door.
Old 06-26-2013, 03:47 PM   #18
69CST-V
69CST-V's Avatar
Re: 49/54 LS driver
Great project. Would like to see more of the build that has already taken place.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 07-02-2013, 04:47 PM   #19
panelrodder81
Doin' it live!
panelrodder81's Avatar
Re: 49/54 LS driver
Are these buttons water tight??! I LOVE this idea if they are!
-Panelrodder
-Panelrodder
1953 GMC Panel truck - 'Curly'
1961 Chevy Suburban - 'Larry' - Sold
2005 Harley Sportster - 'Shemp'
panelrodder81 is offline   Reply With Quote
Old 07-02-2013, 05:51 PM   #20
Bubba54
Re: 49/54 LS driver
Trucks looking nice.
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=582647
Bubba54 is offline   Reply With Quote
Old 07-02-2013, 06:24 PM   #21
chev3600
chev3600's Avatar
Re: 49/54 LS driver
I'm working on getting a photo album together with more pics. I've got another project or two in the works, so... Slow going.
I appreciate the comments. It's a blast to play with these old trucks.
Panel- supposedly the buttons are waterproof/resistant. It doesn't say in the ebay ad, but I asked them and they said they were. I'm still skeptical but this truck doesn't get very wet.
Seller is "11linjian123". But lots of sellers have them (hong kong). I even have a pair as inside openers too.
Old 07-02-2013, 11:48 PM   #22
av8tr33337
av8tr33337's Avatar
Re: 49/54 LS driver
Love this build thread. Very nice work!
av8tr33337
AKA Bartman Email av8tr33337@yahoo.com
Bartman's Ad-S10 Chassis Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=415418
My First Youtube Video
http://www.youtube.com/watch?v=B6hSt...eature=channel
More Pics of the 51 Project
http://s668.photobucket.com/albums/v...hassis%20Swap/
1951 3100 Pickup
av8tr33337 is offline   Reply With Quote
Old 08-12-2013, 12:08 AM   #23
STOCKISH
STOCKISH's Avatar
Re: 49/54 LS driver
Any progress on the AC install bro?
--Josh
Old 08-12-2013, 07:57 AM   #24
chev3600
chev3600's Avatar
Re: 49/54 LS driver
I think I'm having truck withdrawal symptoms. It's been up on stands for two months now.
Well, I managed to mount the compressor, add a recirculating heater valve, got all the a/c lines run (need them crimped now), and biggest headache was getting the interior box fitted and all the associated parts.
On a side note till I can get pics up of that stuff, I did buy one of those "old navy" display trucks and pillaged the grill and bumpers! Anybody want to buy a blue truck?!
Old 08-12-2013, 09:08 AM   #25
chev3600
chev3600's Avatar
Re: 49/54 LS driver
72supercheyenne: thanks for the help the other weekend, I needed a kick in the ass jump start to get going again.
