Old 01-31-2013, 12:58 PM   #1
70chevytruck
C20 Tire Size
Pictures and sizes of tires on C20's....Just picked up some F**D 16x8 Wheels and need to see what size tires look good!
Also tire pricing...man they have gone up since I have bought some last....Where and what brand is the best?
Bought tires for my 07 GMC at Sam's Club and they were a great deal..maybe need to go back!
Thanks,
70chevytruck
70chevytruck is offline   Reply With Quote
Old 01-31-2013, 01:08 PM   #2
Scott>72-GMC
Scott>72-GMC's Avatar
Re: C20 Tire Size
Posted via Mobile Devicenothing special by any means this is how it came but they are new so they are staying on for now
Scott>72-GMC is offline   Reply With Quote
Old 01-31-2013, 01:30 PM   #3
70chevytruck
Re: C20 Tire Size
I was thinking 275/75/16.....thoughts?
70chevytruck
Old 01-31-2013, 03:26 PM   #4
jocko
jocko's Avatar
Re: C20 Tire Size
i like 265-75-16 as a good choice for a c20 - here's a pic:
Old 01-31-2013, 03:29 PM   #5
MidLifer
MidLifer's Avatar
Re: C20 Tire Size
My "heavy 10" (c10 into which the PO swapped a 20-series driveline) has 235/85/16s. I kind of like the extra height of the 85 profile.
Cheapest tires I've seen in that size run about $160/ea.
MidLifer is offline   Reply With Quote
Old 01-31-2013, 04:23 PM   #6
k2rm
k2rm's Avatar
Re: C20 Tire Size
I went for a staggered look.
245 75 r16 in the front
285 75 r16 in the back (10" wide)
k2rm is offline   Reply With Quote
Old 01-31-2013, 06:40 PM   #7
Sicklajoie
The Niner
Sicklajoie's Avatar
Re: C20 Tire Size
265/75/16 here
They are the same height as 235/85/16 and an inch taller than 245/75/16
I've got 16 x 7 rims. The 265's should still look good on your 16 x 8 rims. The 235's might be stretching them a little on a wider rim like what you got.
I went with an expensive set of Michelins ($850 for a set). They're worth it though. The sidewalls are soft which makes for a great ride and they wear like hockey pucks so they'll last a long, long time.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 01-31-2013, 06:55 PM   #8
70chevytruck
Re: C20 Tire Size
Thank you all....sounds like 265.75.16 is the way to go.
70chevytruck
Old 01-31-2013, 07:25 PM   #9
Number98
Prestige Worldwide
Number98's Avatar
Re: C20 Tire Size
I know it is off the subject but hat is one beautiful truck Sicklajoie!
Number98 is offline   Reply With Quote
Old 01-31-2013, 07:44 PM   #10
Mayo
Cool Truck
Mayo's Avatar
Re: C20 Tire Size
Here is my C20 on 265/75/16 Michelins
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 01-31-2013, 08:09 PM   #11
Sideways
Sideways's Avatar
Re: C20 Tire Size
I run Michelin LTX M/S in a 275/70-16 most of the time and a 285/75-16 A/T on the back with the camper.
Sideways is offline   Reply With Quote
Old 01-31-2013, 08:37 PM   #12
69Rumbler
69Rumbler's Avatar
Re: C20 Tire Size
i got 265 75 16 on mine but i need to get new ones..... looking at 800 for the set
1969 C20 CUSTOM "RUMBLEr"
69Rumbler is offline   Reply With Quote
Old 01-31-2013, 09:15 PM   #13
daves72C10D
daves72C10D's Avatar
Re: C20 Tire Size
edit, never mind.
1972 Custom 10 Deluxe- original paint, interior- 72k miles
http://www.cardomain.com/ride/2466316
Cheap, Fast or Good. Pick any two.
1990 Eagle Talon AWD
1991.5 W250 CTD
1992 Cushman Truckster- Haulster
daves72C10D is offline   Reply With Quote
Old 01-31-2013, 09:17 PM   #14
Scott>72-GMC
Re: C20 Tire Size
Lovin the camper
72 GMC super custom.
Old 02-02-2013, 10:53 PM   #15
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Re: C20 Tire Size
I run 285/70-17 on all 4 corners of my '69 C/20. I like the look.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 02-03-2013, 03:18 AM   #16
72restorationvirgin
Active Member
72restorationvirgin's Avatar
Re: C20 Tire Size
Dan not to steal the thread but is your truck lifted or is it just the wheels and tire size that raises it? What brand of wheels are those?
67 C20 283/4 Speed
72restorationvirgin is offline   Reply With Quote
Old 02-03-2013, 10:36 AM   #17
Mayo
Cool Truck
Mayo's Avatar
Re: C20 Tire Size
Those look like Hummer H2 wheels
Old 02-03-2013, 01:25 PM   #18
69C20396
69C20396's Avatar
Re: C20 Tire Size
They are H2's, I am also interested in whether or not the blue truck is lifted. i have seen some for sale locally with the same size tire on them and was wondering if they will go on the front with rubbing with stock suspension. Lets us know!
Joshua
69C20396 is offline   Reply With Quote
Old 02-03-2013, 03:38 PM   #19
derotoreut
derotoreut's Avatar
Re: C20 Tire Size
When I did front disc conversion I changed out the front springs. I installed some HD springs bought from NAPA. The stock HD C20 springs are as follows:
http://www.napaonline.com/Catalog/Ca...752_0162319756
Part No.: 2771752
No. of Coils: 7.92
Free Height: 12.94"
Spring ID: 3.68"
Spring Load Height: 10"
Design Load: 2950
Spring Rate: 1016
Wire Diameter: 0.812"
The springs I put on from C10, C20, C30 from 1973-83. They are as follows:
http://www.napaonline.com/Catalog/Ca...074_0162301536
Part No.: 2772074
No. of Coils: 8
Free Height: 13.61"
Spring ID: 3.676"
Design Load: 3841
Spring Rate: 1060
Wire Diameter: 0.83"
You could also use C30 mid '80's 1-ton springs, but I thought they would be too stiff. Those are:
http://www.napaonline.com/Catalog/Ca...085_0162304063
Part No.: 2773085
No. of Coils: 7.93
Free Height: 13.34"
Spring ID: 3.65"
Spring Load Height: 11"
Design Load: 3289
Spring Rate: 1318
Wire Diameter: 0.906"
The wheels are chrome Hummer H2 wheels from 2003-07.
~ Dan
Old 02-03-2013, 06:35 PM   #20
72restorationvirgin
Active Member
Re: C20 Tire Size
Very nice!! Thanks Dan
67 C20 283/4 Speed
Old 02-05-2013, 11:08 PM   #21
Jimmora
Re: C20 Tire Size
I have this exact Q right now. So the 265/75/16s on a 8" Rim won't ever rub? I'm replacing my split Rims w/ Wheel Vintiques 16x8's. Name:  IMG_2221.jpg
Jimmora is offline   Reply With Quote
Old 02-06-2013, 07:27 AM   #22
Mayo
Cool Truck
Mayo's Avatar
Re: C20 Tire Size
Originally Posted by Jimmora View Post
I have this exact Q right now. So the 265/75/16s on a 8" Rim won't ever rub? I'm replacing my split Rims w/ Wheel Vintiques 16x8's. Attachment 1055644
Yeah, I believe so. My rims are 16x8 with 4.25 backspace and -5 offset. I run 265/75/16s and have never had any rubbing issues.
Old 05-28-2017, 11:18 PM   #23
thetruckrman
Re: C20 Tire Size
Do you have a pic of one of your wheels/tires you could post?
thetruckrman is offline   Reply With Quote
Old 05-29-2017, 07:31 AM   #24
Jimmora
Old 03-22-2018, 10:21 PM   #25
KevinK7
KevinK7's Avatar
Re: C20 Tire Size
An older thread, but those H2 wheels look great...
KevinK7 is offline   Reply With Quote
