Old 02-18-2013, 09:42 AM   #1
wsurf4me
wsurf4me's Avatar
Firewall Holes
So I've decided to fill in some of the holes in my swiss cheese firewall. The problem is I don't know which ones to leave. The previous owner had just the bare essentials, no heater or ac. I kind of hate to fill them all just to redrill later, is there any way to identify what to leave alone?
58 Fleetside
71 Cheyenne
wsurf4me is offline   Reply With Quote
Old 02-18-2013, 10:03 AM   #2
wsurf4me
wsurf4me's Avatar
Re: Firewall Holes
Here's some pics of what I have -
58 Fleetside
71 Cheyenne
Old 02-18-2013, 11:18 AM   #3
solidaxel
solidaxel's Avatar
Re: Firewall Holes
I have always filled all except the steering column and started fresh
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-18-2013, 12:48 PM   #4
_Ogre
_Ogre's Avatar
Re: Firewall Holes
i'm with solidaxle, i welded everything closed and cut very few after.
i also shaved the standing seam that joins the firewall to both cowl panels
if your using the stock elements plan accordingly, ie; hood hinges, battery tray, heater, wire harness
shop air compressor timer
Old 02-18-2013, 01:39 PM   #5
OrrieG
OrrieG's Avatar
Re: Firewall Holes
I did the same as Orge except I kept the battery box and ground behind it and stock throttle opening in the recess. Wanted a clean slate to start with.
Old 02-18-2013, 05:23 PM   #6
Denee007
Denee007's Avatar
Re: Firewall Holes
I did the same as all of the above! Ogre made me do it! lol and then you have to remove the ridge too! ha! It was a pain, but worth the effort. Mine is not nearly as good, but it looks good for my level of expertise. After having a blank wall of no holes, I hated to drill anywhere on my firewall! dne'
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
Old 02-18-2013, 07:39 PM   #7
wsurf4me
wsurf4me's Avatar
Re: Firewall Holes
Thanks for all the replies, I went ahead and dove in. Here's this afternoons progress.
58 Fleetside
71 Cheyenne
Old 02-18-2013, 08:45 PM   #8
Denee007
Denee007's Avatar
Re: Firewall Holes
Wow, you work fast!! ; )
Old 02-19-2013, 06:36 PM   #9
booger1949
Re: Firewall Holes
feel them all in but the brake an clutch an the steering column by that way if u need to add a hole u can redrill in a nice hidden spot an your firewall looks so much better
booger1949 is offline   Reply With Quote
Old 02-19-2013, 10:24 PM   #10
solidaxel
solidaxel's Avatar
Re: Firewall Holes
Originally Posted by booger1949 View Post
fill them all in but the brake an clutch an the steering column by that way if u need to add a hole u can redrill in a nice hidden spot an your firewall looks so much better
Yes, You will be much happier when you paint everything and hide the wires down low
LS 3 4L70E
Old 02-20-2013, 12:29 AM   #11
dirtracer81_2
Re: Firewall Holes
Hey surf thanks for the pictures on the cab mounts. I have decided to go with ez chassis make life a little more simple hopefully. And glad i ran across this I was debating which holes myself the other night.
dirtracer81_2 is offline   Reply With Quote
Old 02-20-2013, 09:51 PM   #12
wsurf4me
wsurf4me's Avatar
Re: Firewall Holes
My next move is to look at moving the harness down low, I have no idea why it's up high. I'm thinking that I can run most of it between the inner and outer fender walls, anyone have any insight on this?
58 Fleetside
71 Cheyenne
Old 02-20-2013, 09:52 PM   #13
wsurf4me
wsurf4me's Avatar
Re: Firewall Holes
No problem, hope it helped.
58 Fleetside
71 Cheyenne
Old 02-20-2013, 09:56 PM   #14
solidaxel
solidaxel's Avatar
Re: Firewall Holes
That is exactly where I put mine!!
LS 3 4L70E
Old 02-21-2013, 12:17 AM   #15
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Firewall Holes
Hopefully I won't get flamed all to hell! lol.
Has anyone tried one of THESE firewall covers?
http://www.nolimitparts.com/prodinfo.asp?number=CFWC
It's a little pricey but for someone who dosn't know how to weld, maybe it's a consideration?
I knew a guy that made his own from sheet metal and it looks fine. Since you cover the interior with sound deadner and carpet (typically) wouldn't this work fine? Do you guys consider it Mickey Mouse?
Dan in Pasadena is offline   Reply With Quote
Old 02-21-2013, 01:34 PM   #16
_Ogre
_Ogre's Avatar
Re: Firewall Holes
my rear harness exits next to my steering column right under my ezwire fuse panel.
my front harness is in the grey flex conduit next to my heater hoses.
my engine harness for the ramjet is huge and exits behind my distributor plus 2 wires you see
when i boxed my frame i stuck a straight piece of 1/2'' pvc in the frame that exits out the back for my rear harness
you can see a little white pvc sticking out behind my trans x-member
Old 02-22-2013, 02:14 PM   #17
wsurf4me
wsurf4me's Avatar
Re: Firewall Holes
Thanks Ogre! Just curious is there any reason you ran the front harness down the passenger side? I think I have a Painless harness and it was routed on the drivers side for both front and rear. I only have a few wires for the engine so it should be pretty straight forward.
58 Fleetside
71 Cheyenne
Old 04-13-2013, 08:59 PM   #18
wsurf4me
wsurf4me's Avatar
Re: Firewall Holes
So everything is welded up and new holes have been cut for the steering column and master cylinder. I'm trying to get ideas on how to run the harness, I like what Ogre did but am wondering what others have done. If I run it low how do I keep it out of sight or protected inside the cab?
58 Fleetside
71 Cheyenne
Old 04-14-2013, 01:40 AM   #19
SCHRUMGMC
SCHRUMGMC's Avatar
Re: Firewall Holes
What is with all of the holes ?
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 04-14-2013, 08:22 AM   #20
Indian113
Indian113's Avatar
Re: Firewall Holes
You'll find out if you ever get that GMC! They just drilled a hole any time, anywhere they needed it.
Indian113 is offline   Reply With Quote
Old 04-14-2013, 09:44 AM   #21
SCHRUMGMC
SCHRUMGMC's Avatar
Re: Firewall Holes
Oh I figured that
Soon my friend, soon
1971 GMC Sierra
1959 GMC 100
Old 04-14-2013, 11:20 AM   #22
Dan in Pasadena
Re: Firewall Holes
solidaxel,
What did you use to fill your smaller holes? It looks like a nail sticking out?
Old 04-14-2013, 11:53 AM   #23
mknittle
mknittle's Avatar
Re: Firewall Holes
And often with little thought.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 04-14-2013, 02:27 PM   #24
SCHRUMGMC
SCHRUMGMC's Avatar
Re: Firewall Holes
Looks awesome now
1971 GMC Sierra
1959 GMC 100
Old 04-14-2013, 02:50 PM   #25
Russell Ashley
Russell Ashley's Avatar
Re: Firewall Holes
You are fortunate if they drilled them. The extra holes on my truck were made with a chisel.
Russell Ashley is offline   Reply With Quote
