Old 03-22-2015, 09:51 AM   #1
Macster
Re: LSX swappers what ya got?!?!
Model: 1979 GMC C1500 S/B
Motor: 5.3, 700R4
Fuel tank: stock with external Fuel pump
Motor mounts: Hooker adapters/stock BBC engine side (had to relieve pass side due to AC provisions on 5.3 block)
Tranny mount: Stock.
Oil pan: Stock 5.3 truck
Radiator: aluminum direct fit (summit racing)
Shift linkage: stock auto- so far no exhaust clearance issues
Headers: do not fit-hit pass side firewall due to head offset on 5.3 (and mt location)
Gears: 3.73 richmond/eaton posi locker
Rear End: 12 bolt
Tire size: 255/70R-15 Stock rims
Bagged: N/A
Running: Not Yet
Build thread: need one
Carb or FI: Carb; Edel-7118 LS kit; 600 CFM carb
Still hooking everything up
Macster is offline   Reply With Quote
Old 04-23-2015, 08:48 PM   #2
engairuph
Model: 1969 4wd Suburban
Motor/transmission: 2005 LM7 5.3 / 4L80e stage 3 1500 stall
Fuel tank: stock
Motor mounts: ECB
Tranny mount: factory 1969
Oil pan: stock
Radiator: Aluminum 4 core / dual fans
Shift linkage: Shift Link
Exhaust manifolds: LS3 camaro
Gears: 3:73
Rear End: 12 Bolt posi
Tire size: 295-65/15
Bagged: no
Running: Yes
Build thread:
Carb or FI: FI multitech
Go Fast:Just going first
the transfer case is a np205 with 32 spline upgrade, 2 1/2 pipe from front to rear with Borlas mufflers complete dualed.
Ralph L. Jasper
69 4x4 Suburban PTO winch(NAVY)
13 GMC Ext cab
12 Ford Fusion SE(wife)
MAI
Interior shop
engairuph is offline   Reply With Quote
Old 08-06-2015, 01:59 PM   #3
BigCountryx
BigCountryx's Avatar
Model: 1970 SWB C10
Motor: 2001 Silverado 5.3 with 221/228 600/605 112+2 cam
Transmission: 1997 c3500 4L80e, hd2 shift kit and circle D 3000 stall
Oil pan: 2001 Silverado, hangs an inch below the factory crossmember
Motor mounts: ECE
Tranny mount: ECE
Tranny Tunnel: Low hump
Radiator: Champion for Big Block w/ 2002 camaro fans
Fuel tank: Jeep Cherokee tank with 87 Chevy TBI sending unit and ep241 pump... don't think it's enough pump
Shift linkage: 72 c30 floor shift column... nothing on the column. 2001 silverado shift cable, 1967 C10 E-brake used as shifter.
Exhaust manifolds: 1998 camaro
Gears: 3.73
Tire size: 29
Carb or EFI: EFI
Bagged: no, 5.5/8 static
Running: yes, drove the second half of the 2015 Power Tour in it.
Go Fast: just a cam and tune
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped
1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant
BigCountryx is offline   Reply With Quote
Old 09-10-2015, 11:23 AM   #4
MattPSU
MattPSU's Avatar
Model: 1972 Cheyenne SWB
Motor/transmission: 5.3l / 4L60e from a 2005 Avalanche
Fuel tank: Boyd Welding
Motor mounts: Stock SBC stands & mounts with eBay plates
Tranny mount: Stock
Oil pan: Cadillac CTS-V
Radiator: Champion LS Swap 3 Row
Shift linkage: Modified stock
Exhaust manifolds: BBK Camaro Headers
Gears: Stock 3.08
Rear End: Stock 10 bolt
Tire size: 275/60R15
Bagged: Yes – Porterbuilt Stage 1 front, Stage 2 rear
Running: YES
Build thread: http://67-72chevytrucks.com/vboard/s...22887&posted=1
Carb or FI: FI
Go Fast: Brian Tooley Racing Stage 3 Cam 218/224/.553/.553 113+3
Matt Criswell - Lyman, SC
1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank
UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE
MattPSU is offline   Reply With Quote
Old 09-10-2015, 12:21 PM   #5
solidaxel
solidaxel's Avatar
Nice ride!
I like the coil covers.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-02-2015, 11:41 AM   #6
Billyburban
Hello everyone I see a lot of ppl using tbss manifolds did you have to cut frame or modify anything ? Thanks
Billyburban is offline   Reply With Quote
Old 12-03-2015, 02:46 PM   #7
grad70
Model: 1970 C10 LWB
Motor/transmission: 2010 L96/2004 4L80E
Fuel tank: Byod Fuel Cell
Motor mounts: Dirty Dingo
Oil pan: Stock (currently)
Radiator: Entropy LSX Radiator w/ dual elec fans
Shift linkage: Lokar Adjustable Column shift linkage
Exhaust manifolds: Doug's Tri-Y
Gears: 3:07
Rear End: '70 12 bolt
Tire size: In Process
Bagged: NO
Running: YES!
Build thread: None
Carb or FI: FI
Go Fast: Stock for now, Cam in future?
grad70 is offline   Reply With Quote
Old 12-09-2015, 02:00 PM   #8
tucker69
tucker69's Avatar
Model: 1969 c/10 stepside
engine: 2001 lq4 6.0, stroked to 408
trans: 4l80e
diff: Stock 12bolt with 3.73 posi
frame: Boxed & "x" braced
suspension: 4-wheel coilovers with new front crossmenber & 4-link fatbar all from "no limit"
steering: Power rack & pinion
fuel tank: Boyd's 19 gallon relocated to rear of frame
, used corvette fuel pressure regulator/filter to delete the return line from engine
just fired engine for first time this past weekend, still have several body mods, driveshaft, interior, gages, wheels/tires, bed, climate control, paint and numerous other tidbits....gee and i thought i was making headway
tucker69 is offline   Reply With Quote
Old 12-09-2015, 10:34 PM   #9
mild68
mild68's Avatar
Model: 94 S10
Motor/transmission: 5.3 NV3500 5speed
Fuel tank: stock
Motor mounts: current performance poly urethane
Tranny mount: stock
Oil pan: GM muscle car pan
Radiator: S10 V6 HD w dodge Intrepid dual elec fans
Exhaust manifolds: Sanderson shorty headers
Rear End: changing out to 8.8 w 373:1
Build thread: http://67-72chevytrucks.com/vboard/s....php?p=7400447
Carb or FI: fuel inj w truck intake
mild68 is offline   Reply With Quote
Old 12-14-2015, 11:39 AM   #10
roushinator
roushinator's Avatar
Model: 1972 C10 Stepside
Motor: 2014 6.2 (Camaro)
Transmission: 2014 6L80E
Oil pan: 2008 Cadilac CTS-V
Motor mounts: ECE
Tranny mount: Porterbuilt Inner Frame Stiffner
Tranny Tunnel: High hump
Radiator: Entropy dual pass with electric fans
Fuel tank: Boyd's Welding stainless in tank pump
Shift linkage: TBD
Exhaust manifolds: Doug Thorley 324Ys
Gears: TBD
Tire size: TBD
Carb or EFI: EFI
Bagged: no
Running: not yet...
Go Fast: TBD
Build thread:
http://67-72chevytrucks.com/vboard/s....php?p=5532411
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
Old 02-07-2016, 06:47 AM   #11
OKGMC4
OKGMC4's Avatar
Model: 1969 C10
Body mods: 67 GMC front clip, bed cut 23 inches, unibodied, mild chop
Motor: 2005 6.0 LQ4 bored .020, flat tops, 224R cam on 112 centers
Transmission: 2005 4L60E
Oil pan: silverado
Radiator: 2001 TA with stock dual fans
Fuel tank: TANKS inc poly for 48 Ford
Exhaust manifolds: Doug Thorley long tube
Gears: 3,73
Tire size: 285/35r20 rear, 255/40r20 front
Carb or EFI: EFI
Bagged: no
Running: not yet...
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 10-07-2016, 11:04 AM   #12
Qwk
Qwk's Avatar
Model: 87 R10
Motor/transmission: LS1/T56
Fuel tank: Stock w/Racetronix 340 pump
Tranny mount: Energy Suspension
Oil pan: GM
Radiator: Afco
Shift linkage:
Exhaust manifolds: Hedman Headers 1-7/8"
Gears: 4:10
Tire size: 295/50-15
Bagged: Nope
Running: Yes
Build thread: http://ls1tech.com/forums/conversion...t56-build.html
Carb or FI: Holley HP
Go Fast:
My LS/T56 C10 build...http://ls1tech.com/forums/conversion...t56-build.html
Qwk is offline   Reply With Quote
Old 10-25-2016, 01:19 PM   #13
Hart_Rod
Hart_Rod's Avatar
It's alive!!!!
https://www.instagram.com/p/BL4kC6IBQpa/
Hart_Rod is offline   Reply With Quote
Old 11-02-2016, 07:32 AM   #14
greystoke
Awesome, that's a beautiful burb. Congrats!!!
"Fear makes the wolf look bigger"
http://67-72chevytrucks.com/vboard/s...d.php?t=305629
greystoke is offline   Reply With Quote
Old 11-12-2016, 01:41 AM   #15
ZackD1212
ZackD1212's Avatar
Subscribed
Bagged 68 panel 5.3 4L60e
17 Tesla Model S 100D
03 Tahoe
ZackD1212 is offline   Reply With Quote
Old 11-12-2016, 10:08 PM   #16
70c10guy
Model: 1970 c10
Motor/transmission: 2001 LM7 5.3/1989 s10 t5
Fuel tank: brand new stock in cab.
Motor mounts: dirty dingo sliders/rubber
Tranny mount: speedway tubular 6" drop
Oil pan: gmpp swap pan
Radiator: stock 1970 replacement
Shift linkage: stock bellhousing/fork. Custom pivot and lengthened pushrod
Exhaust manifolds: speed engineering 1- 5/8 full length headers
Gears: stock, unsure of gears
Rear End: stock, 12 bolt
Tire size: 235/65/15
Bagged: nope!
Running: absolutely!!!
Build thread: nope
Carb or FI: carb, holley dp 650
Go Fast: nope
70c10guy is offline   Reply With Quote
Old 12-09-2016, 06:53 PM   #17
Kabwe
Certified Car Nut
Kabwe's Avatar
Model: 1958 Chevy with 1955 Front clip
Motor: 2002 Tahoe DBW 5.3 bored out to a 5.7, PSI Conversion wiring harness
Cam: TSP 228
Heads. LS 243
transmission: 4L60E
Fuel tank: Tanks.Inc
Motor mounts: Self Fabricated.
Oil pan: 2000 Fbody
Exhaust manifolds:Stainless Steel Headers
Gears: 3.42
Rear End: Narrowed 8.5
Tire size: 295/50/18
Build thread:Yes
Kabwe is offline   Reply With Quote
Old 01-05-2017, 03:43 PM   #18
JML55
JML55's Avatar
Model: 1955 2nd series GMC 9300 (Canadian version of the 100)
Motor: 2002 5.3 Silverado
Transmission: 2004 4L60E
Oil pan: LS1 F-body Camaro
Motor mounts: Home made stands, adaptor plate with early sb mounts
Tranny mount: After market
Tranny Tunnel: 4 speed floor shift tranny floor cover
Radiator: Aluminum factory looking dual one inch with electric fan
Fuel tank: CPP aliminum under bed,in tank pump,filler in L/R fender
Shift linkage: Column/Lokar
Exhaust manifolds: Elderbrock bloc hunger
Gears: 3.73, S10
Tire size: 225/45R17, 255/45R17
Carb or EFI: EFI
Bagged: no
Suspension: 1985 C4 flat out enginering front and 4 links panard bar rear
Shocks: Coil overs all aroud
Brakes: Disc all around
Running: 3 years now
Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=316140
Go Fast: Just a nice cruiser
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 03-07-2017, 11:49 AM   #19
shanman310
shanman310's Avatar
Model: 70 C10 Short fleet
Motor/transmission: L33/700R4
Fuel tank:
Motor mounts: Stock
Tranny mount: Stock
Oil pan: Ctsv
Radiator: Griffin
Shift linkage:
Exhaust manifolds: Heddman mid length
Gears: 3.73
Rear End: 12 bolt Eaton posi
Tire size:
Bagged: Lowered 4/6 springs/lowering blocks
Running: Yes,Driving..no
Build thread:
Carb or FI: FI
Go Fast: 224r Texas speed cam,Prc 2.5 heads,Psi harness
shanman310 is offline   Reply With Quote
Old 03-28-2017, 03:33 PM   #20
scoot_mcgrute
Model: 1966 C10
Motor: 2002 5.3 (Silverado)
Transmission: S10 T5, until I blows up
Oil pan: F body Camaro
Motor mounts: ICT adapter to factory style poly mounts
Tranny mount: poly mount
Radiator: Northern radiator with Northern dual electric fan setup
Fuel tank: LMC top fill with a Bosch inline pump and Corvette regulator
Shift linkage: N/A
Exhaust manifolds: Hooker block hugger manifolds
Gears: 3.73
Tire size: 235/75r15 (for now)
Carb or EFI: EFI
Bagged: Static
Running: Soon
Go Fast: None... Yet
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=691778 - LS swap starts on page 9
1966 Army Truck
scoot_mcgrute is offline   Reply With Quote
Old 04-24-2017, 07:58 PM   #21
1957 Chief
Model: 1984 Silverado
Motor/transmission: Stock 5.3/4L60 with corvette servo
Fuel tank: 1987 tank with Ep381 pump
Tranny mount: Hooker double hump crossmember
Oil pan: Truck
Radiator: 2004 Silverado with 2007 Silverado cooling fans
Shift linkage: Stock
Exhaust manifolds: Ebay stainless headers
Gears: 3.42
Rear End: 8.5 with Auburn Diff
Tire size: Front 275/40/17 Rear 285/40/17
Bagged: No
Running: Like a Champ
Carb or FI: Ebay sheetmetal fuel injection manifold
Go Fast: Mild street tune
1957 Chief is offline   Reply With Quote
Old 04-24-2017, 09:43 PM   #22
sprint_9
sprint_9's Avatar
Model: 1972 C10
Motor/transmission: 5.3 Gen 4, Built 4L60e
Fuel tank: Boyd Efi
Motor mounts: 84 C20 Clam Shell
Tranny mount: ECE crossmember, 72 mount
Oil pan: Stock Gen 4 Truck
Radiator: Cold Case stock aluminum replacement
Shift linkage: Not that far yet, probably Lokar
Exhaust manifolds: Speed Engineering 1 3/4 Long Tubes
Gears: 3.73 w/eaton posi
Rear End: 72 12 bolt truck
Tire size: Probably 295/40/20
Bagged: Static 4.5x6.5
Running: No
Build thread: Signature
Carb or FI: Fuel Injected, Wix Vette Regulator, Holley fuel rails
Go Fast: DOD Delete, Texas Speed 212/218, .600"/.600", 112 LSA. PAC Valve springs, Hardend pushrods, Comp Rocker Arm Trunion upgrade, LS7 Lifters.
sprint_9 is offline   Reply With Quote
Old 05-26-2017, 06:44 PM   #23
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Ok guys and gals, been a while since I been on here...so howdy..lol...Sweet Pea is getting an upgrade. 5.3 twin turbo. I have done a few L.S swaps but none in the 63 to 72 chassis...so my question is what oil pan are you guys running with air or lowered?. I have the stock truck pan, but I think there will be clearance issues when aired out... I also have a stock 6.0 pan out of a camaro. Which I think will clear the ground better but will have chassis issues....any help would be awesome...
Tony
bad6772 is offline   Reply With Quote
Old 05-26-2017, 10:20 PM   #24
crakarjax
crakarjax's Avatar
Tony
02 f-body pan, 1" above the stock crossmember and fits fine.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 08-05-2017, 12:49 AM   #25
ivorton74
ivorton74's Avatar
Model: 1983 C-10 Silverado Longbed
Motor/transmission: 1999 LM7 5.3, 2002 4L60E
Fuel tank: Stock w/Walbro 255 external pump
Motor mounts: Ebay Cutthroat Adjustable Mounts
Tranny mount: Stock
Oil pan: Stock 5.3 pan
Radiator: Stock SBC
Shift linkage: Stock with B&M Hammer floor shifter
Exhaust manifolds: Stock 98 Camaro manifolds
Gears: 2.73👎...swapping this out for sure
Rear End: Stock 10 Bolt
Tire size: 275/60/15
Bagged: No...static drop 4.5/6
Running: YES!!!!
Build thread: none
Carb or FI: Stock EFI
Go Fast: Eventually I hope
1983 C10 Silverado 5.3 swap
1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122
2001 BMW 530i 5 speed
2019 Nissan Titan SV Midnight
1979 Datsun 210 4 door
1980 Datsun 120y(back home in Trinidad)
ivorton74 is offline   Reply With Quote
