Old 03-04-2013, 11:27 PM   #1
85/05Silverado
85/05Silverado's Avatar
Lq4 Cam/ motor input ???
Ok so im in the midst of doing my first engine swap, I am using a lq4 out of a 2000 silverado, this is what I have, or will be getting so far,
Stock lq4 bottom end
Livernoise stage 2. 243 heads, stock replacement head gaskets
Doug thorley mid length 1 7/8" mid length headers
Plan on putting ls6 intake/ throttle body on top
Double roller timing chain
4l80e, probably a 3000 rpm stall running 3:73 posi in a 12 bolt rear end with a 28-29" tire
Looking for a good street able cam with a nice chop
So far I'm kinda set on the, TSP 228r with 112 lsa
Any input would be greatly appreciated, but bear with me as I'm still learning about building engines, ls swaps, Also anyone running a setup like this what kind of power are you making
Hows it goin Eh!
1985 Chevrolet C10 Silverado SWB-395 Stroker 490hp,700R4 12 bolt 3:73 posi,inferno red crystal pearl coat with black ralleystripes,custom leather seats, carbon fiber gauges
2005 silverado 1500 ecsb, Z71, 33x12.5 dick cepek
http://www.cardomain.com/id/Kearney
Stephen
85/05Silverado is offline   Reply With Quote
Old 03-05-2013, 02:32 AM   #2
BigDan3131
BigDan3131's Avatar
Re: Lq4 Cam/ motor input ???
If you want an actual rough idle your LSA should be tighter like 109-110.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 03-06-2013, 12:49 AM   #3
lt155ruck
lt155ruck's Avatar
Shoot the guys from Comp Cams a cam suggestion request, their Lsr cams are very specific to application. I contacted them for mine a 6l with L92 heads, 700r with 3.73 gears for my Blazer. They came up with the 281lsr, here is what it sounds like in a 2010 Camaro.... sorry motor for the blazer is still on the engine stand.
lt155ruck is offline   Reply With Quote
Old 03-06-2013, 12:52 AM   #4
85/05Silverado
Ok cool I might do that, that cam sounds good
Hows it goin Eh!
Stephen
Old 03-06-2013, 01:02 AM   #5
lt155ruck
lt155ruck's Avatar
It will take them a week or so to get back to you but...its worth it. Really, whats more disappointing than shelling out a crap load of cash for something that is suppose to make it faster and it falls flat on its face... As for the sound of that cam...I love it. I play it through the surround sound LOUD..It makes me happy
Old 03-06-2013, 01:46 AM   #6
Billett
Billett's Avatar
why 243s instead of 317s or l92 heads? Other than that you have pretty much the exact combo I'd like to put in mine. Be sure to link your build thread if you have one!
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 03-06-2013, 02:12 AM   #7
lt155ruck
lt155ruck's Avatar
Oohh ya... it made 455 hp at the Wheels
Old 03-06-2013, 02:26 AM   #8
85/05Silverado
The heads are from livernoise stage 2 ls heads,
I don't have a build thread yet but I'm taking some pics and might start one once I get into it a bit more
Hows it goin Eh!
Stephen
Old 03-06-2013, 03:13 PM   #9
Wasted Income
Boosted Member
Wasted Income's Avatar
I built this car for my brother. LQ4 with stock 317 heads, Comp Cams XR281HR, 228/230, .571"/.573" - 112 LSA, patriot dual springs, 4L80E with a 9.5" 3400 stall.
Made 536 to the tires on a 150 shot.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 03-06-2013, 04:01 PM   #10
lt155ruck
lt155ruck's Avatar
I was looking at that cam too,it makes great power and sounds awesome. With the L92 flow characteristics I can get away with some more lift. SWEET Monte.
Old 03-06-2013, 10:36 PM   #11
69CST6.0
This is a really good practical setup. I would go with a TBSS (trail blazer SS) or new style 07-13 intake( both are the same) and 90 mm throttle body. these will save you money in the long run. With this intake you can run the truck accessories. I would look at a 3500-3600 stall also. Get a custom stall from Yank, PI, Circle D or FTI.
69CST6.0 is offline   Reply With Quote
Old 03-07-2013, 10:31 AM   #12
Wasted Income
Boosted Member
Truck accessories and "car" intakes are not mutually exclusive.
More pics of the monte.
Turbo diesel
Old 03-08-2013, 09:49 PM   #13
mooseknuckles
mooseknuckles's Avatar
I've heard the ls6 cam and springs are a good alternative to the stock truck cam.....especially if you can find a good used one.....
mooseknuckles is offline   Reply With Quote
Old 02-02-2014, 11:29 PM   #14
sqrlnts
Onboard for future reference.
sqrlnts is offline   Reply With Quote
Old 02-03-2014, 02:10 AM   #15
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
OK guys, "Stage x" doesn't mean ANYTHING. Not since the Buick GS has the phrase "stage" in front of a setup mean anything, its just an arbitrary word. Stage 3 always sounds cooler than stage 2...its 1 more!
If you are going to buy expensive aftermarket heads, and do an intake swap...then just get an L92 setup and put the extra cash into the cam and stuff. The l92's are just nice with it in the flow game. The intake manifolds that go with them are also superior. Its not more work then what your already planning to do, and if you tell your harness person, it shouldn't make any drastic differences in the cost/work in the harness.
You can also run more cam since you'll have the flow to use it, between L92's and DT big tubes. Drop the lsa down, if you want that lump. 109-111 will usually get you there in good form. The 112 is ok depending on the cam, but anything higher and you might be disappointed.
I'd also think about going with a little more stall. With the right cam that will pull past 6k, and a good stall will give you a nice challenge to hold back with foot brakes.
North of 400 at the wheels wouldn't even be a second thought, even through the 80e.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-03-2014, 08:37 AM   #16
smoky02
Location: Sunny, Florida, some might call it South Alabama
I'm running the setup similar to what you are wanting and I love it. Please see my sig. I have a vid of my truck running with open headers some where, I'll see if I can find it and post it here.
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 02-03-2014, 10:32 AM   #17
softballnrd27
Always a work in progress
softballnrd27's Avatar
To get the most out of your combo, don't get an off the shelf cam. You can get everything you want and possibly a little more with a custom grind. PatG, Martin@tick, and a few others over on ls1tech will get you what you want. The price difference between off the shelf and custom grind is negligible. 243s are good heads and with some port work are great heads for stock castings and will give you fairly big bump in compression compare to 317s. Should be a good running combo for sure.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 02-03-2014, 02:22 PM   #18
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
And both fall short of what the l92 can do.
Old 02-03-2014, 07:37 PM   #19
Jon01
Jon01's Avatar
L92's on a stock short block 6 liter are overkill. You'll get more power under the curve with cathedral port heads. Sure, they'll make more power over 5500 but how often are you there?
Now, FI…another story.
Any decent aftermarket cam will get the job done. 228r is a great grind and a 112 will chatter nice at idle. The rest of your plan sounds good. It should move good. Maybe think about a little more converter.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's.
68 Charger R/T - #'s matching 440/auto car, 499/727/3.91.
68 GTX - 440/4-speed, Dana 60. 44,000 miles.
71 SWB C10 - LQ4+S476r
06 Duramax - LBZ - Exhaust, EFI Live, etc...
Jon01 is offline   Reply With Quote
Old 02-03-2014, 09:01 PM   #20
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
take-off L92's on a cammed 6.0, with the DT big primary longtubes, is not overkill...especially not when comparing it to going with an aftermarket head like was originally considered.
And again, why would you go through all the work of buying the ls car intake, aftermarket heads etc, and spending more to make less power.
Old 02-03-2014, 11:20 PM   #21
jamesjones
Freakin Awesome!
jamesjones's Avatar
I agree. If I didn't already have the van intake and DBC setup I'd probably be going L92.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 02-04-2014, 02:37 PM   #22
Jon01
Jon01's Avatar
A cathedral port will give more power under the curve on a stock displacement 6 liter than a rectangle port head.
That's what OP is after based on his mild converter and gear selection.
Peak power the rectangle will pull ahead but it shines over 5k.
I went rectangle on mine as with boost it's a whole different ballgame.
For OP, I'd just leave the 317's as they are, swap valvesprings and stick the cam in it and enjoy it. 317's have the same intake runner as 243's, just a bigger combustion chamber to drop compression.
If you want to bump compression pull them and have them milled or get a set of 799's.
Old 02-04-2014, 06:32 PM   #23
Robznob11
Robznob11's Avatar
um no not so. this is a very mild cam, does not even require a stall. 221/226 .565/.560 on 114 http://youtu.be/XGpzf7mNJxs now don't get me wrong its not radical sounding but it hits hard enough
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 02-04-2014, 08:45 PM   #24
Jon01
Jon01's Avatar
Sorry, that is not a big cam and it does not sound like one. Put exhaust on it and it will tame the lope down a lot.
LSA and overlap are the key components to a rowdy idle.
Here, good reading:
http://www.crankshaftcoalition.com/w...ose_a_camshaft
Old 02-04-2014, 09:18 PM   #25
Robznob11
Robznob11's Avatar
Here, good reading:
Well im not sure if this reply is for me but i said this is a mild cam, and it has a full 3" exhaust with headers and turbo muffler. Lsa does make the overlap and sound difference but what you really need to consider is the rpm range and driving style of the car or truck. I have. A friend with a dunk proven 450 whp ss camaro with oddles of $ thrown at it and another buddy with a ta with tune exhaust and 6speed eats his lunch in the 1/4.
LED TAILS
