Re: Project Madera: A Jimmy GT
Cool, I wish I still had my 75 XL350, what a great bike.
very cool build.
1968 chevy c10 lwb, 250 inline6, 4 speed, ![]() |
Junk Yartist
MMMMM..... boost
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
If I get power hungry one day maybe, but likely if I do it'll be a centrifugal supercharger, but for now, it's stacks.
The obligatory photos of rocker ugliness, just to dispel the notion that Cali trucks are immune, they ain't:
Parts for the nose job, 67 donor grill (for the top filler) and the new 67-68 cowl hood:
That is a pretty cool engine to be putting in there. Never considered that I6. I had a trailblazer with that 6 in it and have been a fan of them.
Thanks for the support.
Weekend after next it starts the next phase the disassembly, blasting and such. The truck is chock full of Hickey parts currently, roof rack (on the sagging top), spare and Jerry carrier (actually that's off already), I think the sunroof is a Hickey item, as are the coilover shocks front and rear. The body guy wants me to have the body blasted before he finishes up the rockers, understandable, it was a mess in there. The trim holes are all filled, I have the 67 grill with the door cap and did some test fitting of the trucks new slanty nose: |
Can you put up some pics of these Hickey coil over shocks? Interested in that set up. Did it ride smooth(er) with them?
1967 SWB C-10 1972 Blazer 4x4 2011 Silverado |
The Hickey shocks are a suppliment to the leafs, not in place of if that is what you are thinking, they simply mount to the stock shock mounts. I'll look to see if i have any pictures of them. The truck had (err has) a bad bearing in the rear diff somewhere, or the posi is locked up, well anyway the truck drove feet not miles when I got it and makes some awful noises doing it, so I have no idea how it drives. I was planning on replacing the diff with a widened Moser anyway, and not really keeping anything from the drivetrain at all for that matter, so the locked up diff and the three grand discount because of it was a bonus for me, about what the new Moser costs, Unfortunatly not for you because it prevents me from really answering your question.
Yeah i see what you mean. I wish i knew someone who uses em, ive seen that "coil over stock-shock" design before and had wondered how they were for ride quality. I dont guess ive seen anyone use them?
Also , what trans are you gonna use?! I would love to use that motor!! Posted via Mobile Device
The Atlas 6 is kind of married to a 4l60/65e although there is some adapters to use other things like a 5 speed manual and a Chevy SB pattern but it's kind of odd since the Atlas 6 mounts the starter about mid block on the drivers side, not at under pan level on the passenger side as is more common. This eliminates anything with a tight bell housing like a 700r4 although there are guys running 4l80s.
For now I'm planning on a built up 4l60e but hope once the pricing calms down that I'll move to a 6l80e and a paddle shifter, I'm kind of planning this with that in mind. I'll be moving it to a floor shift (you still need a shifter for P-N-R-D even with a paddle shifter), putting in a shorter tilt column (with a spacer the size of the paddle shifter), and a TCU that can do both (Compu-shift). I won't see more than about mid 400s for hp without boost so a built 4l60e should be fine. 6l80s are in the $4-5000 range because there just aren't many cores out there yet, but then again 4 speed OD transmissions were that way when they were a new thing. My '91 Suburban has a 4l80e in it and the core charge on one of those used to be $1500-2000 now you can buy one and they don't even want your core. |
#13 | |
Boosted Member
Just another option for you. http://www.jegs.com/i/TCI/890/611641...oductId=757631 ![]()
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
The compushift/paddle shifter option still retains automatic shifting, actually 2 different selectable profiles for automatic shifting and then electronically allows full manual shifting with the paddle shifter by pulling the right paddle and holding it for a couple seconds. Everyone I talk to seems to put the compushift TCU in a whole other category from all the other TCUs out there. Cheap it ain't though.
Anyway, this all goes along with the dynamically reconfigurable approach I'm trying to get to with this truck, I'm going to be using the electronically selectable Ridetech Select coil overs. I've chosen the ECU because it has the hooks to do launch control, and a lot of spare analog and digital I/O ports, which I can use for, um... stuff. The engine in its native habitat has things like VVT and knock sensors which I may try and make do useful things eventually, although the stock cam grinds really use the VVT to do emission compliance and smooth out the torque curve so that the kids toys don't roll around in the back so much, not my priority. I am trying to figure out a hackable double din Sat/Nav head unit that maybe I can tap into the touch screen output and video input so I can manipulate an onboard mITX PC to do ECU/TCU monitoring as well as control things like the Vintage Air system. If I can figure that all out I can pretty much eliminate virtually all switches and knobs from my dash. We'll see, that's more down the road. I see the value in all the modern stuff new cars come with, well a lot of it anyway, but not so interested in the plastic tub it comes in, or the California "don't touch anything" rules, or the fact that I'm lucky if I truly understand 20% of how the controls really work. My goal is to build a technology advanced vehicle with a durable retro racing inspired shell. I know I don't get airbags, crumple zones and anti lock brakes, the last of which I find more of a nuisance than a feature, and the first 2, well I'm going to try not to crash into anything ![]() |
#15 | ||
Boosted Member
![]() ![]() http://www.msgpio.com/manuals/mshift/4L60e.html Quote:
#16 |
I see! I think its going to be awesome!! Are you gonna stay with the np205 and move the motor forward? And what about motor mounts, will the 6 mount in like a small block chevy?
This truck is gonna be awesome no doubt! Posted via Mobile Device
#17 |
NP205? um, no, Porterbuilt mild drop, trailing arms and coil overs, no transfer case, and no 4wd and not a dragger either. It'll be about 8 inches to the frame midway. The goal is to make it handle like a slot car. pushing the track width out by about 4 inches in the front and 6 inches in the rear then using the really deep back spacing on the wheels to narrow it back up. This puts the steering knuckle into the wheel with the goal of making it have fast steering without being twitchy and also being able to get a 12" wide section width 28" tall tire in the wells by reducing the back and forth of tire movement.
#18 |
Awesome! Cant wait to see it, im sure you cant either!
#19 |
It's so much to do, I'm basically keeping the body and the frame rails and not much else. But yes I can't wait.
This is the best shots I have of the Hickey shocks, they aren't great but then again I wasn't really trying to take pics of them....and well truth be told I kind of tasked the girlfriend with photo duty. It's a difficult photo situation at the body shop the truck is pretty surrounded by some more impressive machinery than mine. In this shop at the moment are several hotrods, a Studebaker Avanti, a '37 Cord roadster, a wicked pro street '68 Elco and many others, I think my truck is the newest thing in the shop. |
#20 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Sounds like a great build cant wait to see some more..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#21 |
wow you have a lot of great things going into this one sounds like you project is in the right hands!! cant wait to see more
#22 |
Progress, It is 4 by 4 no more, well I guess it still has a transfer case for the moment. Got the rear pulled apart on Saturday (in pic) the front cam off on Sunday after some snotty weld grinding that seemed to serve no purpose other that to make it impossible to remove the front bolt from the drivers side leaf. I guess some time in the last 43 years there was a wave of thefts of drivers side leaf springs, dunno. Didn't get a picture of the naked front end, it got dark. But I did get a picture of the ultra rare aftermarket Turbo Vapor Injection system
#23 |
I'll bite. What the heck Is a Turbo Vapor kit? Nice build BTW!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#24 |
#25 |
Junk Yartist
Chuck Norris in a Bottle?
