03-16-2013, 11:58 AM | #1 |
Gauges used for LSx swaps
I'm at the point where it's time to decide on gauges to get for our project with a 6.0/4L80E. I've searched around here. Sure would be nice if there was a dedicated sticky to just this subject. Swappers, please take a moment to explain what gauges you used, how they were to install, how they are working and the cost. Much appreciated.
03-16-2013, 02:07 PM | #2 |
Re: Gauges used for LSx swaps
well I have sun pro mechanical gauges. I used a hose connector in my top radiator hose to put the temp sender, got it off ebay cheap and already was tapped for sender. I broke off the oe oil sender at the back of the manifold and tapped it for the oil gauge hose, and the super sunpro super tach is a programmable model that will work for 2 4 6 or 8 cyl so you can set it and hook it directly to the puter ouput. no speedo or fuel gauge yet but im thinking I may go with a gps speedo for easy no wire hook up and im still trying to figure out the fuel. well I really have not messed with it much but I know that you can use an ohm meter and check the range of the stock sender then just buy a gauge for that range.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
03-16-2013, 02:13 PM | #3 |
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
03-16-2013, 03:04 PM | #4 |
meowMEOWmeowMEOW
built a new gauge cluster,An hour of cutting and trimming stainless followed by 15 minutes of wiring connections and slapping a scangaugeII on it. Doesn't get much simpler.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
03-16-2013, 05:06 PM | #5 |
Thanks for the input. I should have explained it's a 67-72 dash cluster I'm interested in. It seems there's plenty of choices. I'd like to take the KISS approach.
03-17-2013, 02:37 PM | #6 | |
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
03-17-2013, 11:55 PM | #7 |
I like what you did. It shows some real ingenuity. I appreciate the link you posted too. I'm still hunting around. Speedhut gauges are interesting to me with the use of microprocessors and the way you can personalize the appearance. Very cool.
What I'm going to say might offend some but I think the original style dash with all those gauges is too busy. Speedhut has a 2 gauge custom set - 4" dual speedometer and tach along with 4" quad gauge - oil, water, fuel volts. They are selling the set currently for $531. I think these will make for a very clean looking dash. If I purchase a 3 hole dash bezel and make a thin bezel sheet to hold these it should work okay. |
03-18-2013, 01:38 PM | #8 |
Truck and auto performance nut
Autometer has 5" quad gauges and 5" speedo's including a small tach across the bottom.
They also have 3 3/8" dual gauges. I have the dual fuel/oil pressure one as shown below. I also have Aeroforce Interceptor on the dash for info off OBDII diagnostic port, but may move it to replace trans or a/f gauge.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
03-18-2013, 02:07 PM | #9 |
I've got some speed hut gauges on thier way to my house. We will see how they turn out.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
03-18-2013, 02:12 PM | #10 |
03-18-2013, 02:45 PM | #11 |
They should be here in a couple of days. I used the 4 1/2" tach and speedo, and the 2 1/16"
Can bus oil pressure, tranny temp, water temp, and volt gauge. They also made me a custom 3 3/8 can bus gauge. I'll post pics when I get it all put together! Posted via Mobile Device
03-18-2013, 02:56 PM | #12 |
sub'd for my swap
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
03-18-2013, 07:04 PM | #13 |
I used gauges out of a Silverado ($40) and later upgraded to Escalade gauges ($100). The Escalade gauges have a more vintage look to them and fit the look of the truck as well as the added trans temp gauge.
Another 71 My truck In tank fuel pump how to LS factory gauges wiring how to-post 18 |
03-24-2013, 02:30 PM | #14 |
Tchncndan, can you post a better pic of the 2nd set of guages, the Escalade ones. That sounds interesting and somewhat inexpensive..Thanks. Jim
03-25-2013, 12:26 AM | #15 | |
Good luck with your setup. Posted via Mobile Device Posted via Mobile Device
This is my Build A 5.3L 1965 C-10 Fleetside http://67-72chevytrucks.com/vboard/s...d.php?t=502100 |
03-25-2013, 11:10 AM | #16 |
That's nice, where did you get that turn signal lever with the cruise. Also is it a three wire or four cruise
Posted via Mobile Device |
03-25-2013, 08:13 PM | #17 |
Dakota Digital VHX with their PCM interface. The speed, RPM, Water Temp, etc are feed to the gauges via the PCM.
Mark ----------------------- Crash's 69 4x4 SWB Crash's Roof over Lake Home Crash's 1988 Land Cruiser Build |
03-25-2013, 08:18 PM | #18 | |
Pin color use A1-2-not used A3---pink------fused ignition feed A4---not used A5---tan/wht--brake warning indicator lamp input NOT USED A6-7-not used A8---brwn/wht-SES light A9---not used A10--orn-------fused battery feed A11--not used A12--lt blu------left turn input A13--ppl/wht---seat belt indicator NOT USED A14-16-not used A17--lt grn------high beam indicator B1---brn--------park lamp feed B2---not used B3---gry--------security indicator input B4---not used B5---ppl/wht----fused ignition feed B6---gry--------Class 2 Serial Data *********** B7---orn/blk-----rear compartment lid ajar indicator NOT USED B8---dk grn/wht--vehicle speed signal B9---gry---------instrument cluster lamp feed B10--dk blu------right turn indicator input B11--blk----ground B12-13--not used B14--tan---------oil pressure gauge input B15--blk wht------ground B16-17- not used I unplugged the ribbon cable to the message center otherwise the security light will always flash when on. The oil pressure switch is different for 99-02 and 03-06 so you have to use the switch of the same year as the cluster. The 03-06 gets its oil pressure from the PCM and the 99-02 is wired direct as above.
03-26-2013, 12:36 AM | #19 |
that looks somewhat clean.
03-26-2013, 10:24 PM | #20 | |
Robert Posted via Mobile Device
03-27-2013, 04:34 PM | #21 |
Thanks TchnchDen, pretty cool idea. Does look more Classic than the other too. Lots of cool ideas floating around here. Jim
03-28-2013, 03:32 PM | #22 |
I'm in the middle of swapping a '65 c10 dash into my '86 c10 lq4/4l80....all electric autometer american muscle gauges, and a boese engineering gauge panel...I dont have them wired up yet, but should work awesome...
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
03-29-2013, 10:08 AM | #23 |
Mooseknuckles, that is one sweet looking guage panel. The American Muscle guages look very nice.
03-29-2013, 01:34 PM | #24 |
TechncnDen, i sure like the way you did your dash.... might have to borrow that idea... thanks for sharing.
03-29-2013, 04:16 PM | #25 |
thanks!....I've been wanting those gauges since they first came out....
