Old 03-27-2013, 09:06 AM   #1
K20chevy
K20chevy's Avatar
LED / HID offroad light positioning
Hi,
does anybody have HID driving lights or LED light bars installed on their square body Chevy or GMC?
Iīd like to see different set ups for the bumper and roof/roll bar to help me decide what to do on my truck. Getting a new winch bumper and I want to get the setup mocked up before getting the bumper powder coated.
(Has someone maybe frenched in some LED light bars into the grill?)
78 Chevy K20 Custom Deluxe, build: http://67-72chevytrucks.com/vboard/s...d.php?t=612104
68 Chevy K20 Panel truck, build: http://67-72chevytrucks.com/vboard/s...41#post7263441
K20chevy is offline   Reply With Quote
Old 03-27-2013, 12:52 PM   #2
K20chevy
K20chevy's Avatar
Re: LED / HID offroad light positioning
Ok,
I should have mentioned that in my first post, I already have a ton of HID lights on the truck (4x Hella Rallye 4000 HID euro & 3x Hella Rallye 4000 pencil). Two euros are on the bumper and the two others plus the pencils are on a light bar in the bed. The light output is amazing.
BUT, with the light bar on the truck, it doesnīt fit inside the garage, itīs too high with 8" lights up top. Therefore I mostly leave it off to not mess with it every time I go in and out of the garage.
Another problem is, if you turn them on an off a lot, they wonīt last very long. Not so much an issue for the top lights, but more for the ones mounted on the bumper.
That is why my idea was to maybe mount a LED bar up top that is shallower and would make the truck fit in the garage. But since Iīm unsure about the distance (up top, pencil lights make more sense) of the LED bars, Iīm wondering wether that would be a good choice or not, considering the Hella pencils have 1 Lux at 1290m! That is f&%$ing far! Even the Euros have one Lux at ~500m.
So I made up these scenarios for the truck:
1. LED bar up top and LED bar on the bumper with small LED cornering lights, ditching the HIDs all together
2. Keeping the HIDs on the bumper, just adding the cornering LEDs and the LED bar up top
3. Ditching the roof lights all together and keeping the HID euros on the bumper and add two HID pencils on the bumper as well, also LED cornering lights. (Problem might be that the 4 8" lights block a lot of airflow to the radiator)
4. LED bar on bumper with two HID pencil beams for distance and the LED cornering lights
5. Some kind of LED setup in grille or bumper that does cornering, close range and long distance
[for a cleaner look, the OnX 1 cell would fit in the grille openings, so that could be hidden very well]
Therefore I was wondering what other people run, their experiance with the HID vs. LED and how they mounted theirs.
I really hate to ditch the 4000 HIDs, they were $$$ and put out more than enough light...
(sure I could mount them on a fold down light rack up top, but if I motorize that, thatīll be big $$$ too and even more wiring)
Wiring on the LEDīs should be easier too with only one realy for en entire bar versus multiple relays for all the HIDs.
Thanks for all the input!
Old 05-13-2013, 07:35 AM   #3
K20chevy
K20chevy's Avatar
Ok, so here is what I went with:
3 Cell OnX bar in driving combo from baja designs and two wide cornering squadrons from baja designs. Also in the bumper are two Hella fog lights from a Mercedes ML55 AMG.
Didnīt get a chance to try them out driving around yet, only lit them up in the garage, but they seem extremely bright!
Old 05-13-2013, 08:10 AM   #4
wraprail
wraprail's Avatar
They don't take up much space do they? Is that all you are using to replace all the lighting you mentioned above?
I didn't know LEDs were even used in off road.
wraprail is offline   Reply With Quote
Old 05-14-2013, 08:25 AM   #5
K20chevy
K20chevy's Avatar
No, they wonīt replace all the lights mentioned, but I set my mind to having the big round lights up top, kind of like they had the round daylighters up top back in the day, but keep the bumper lights more low profile and "hidden", to make it look more classic...
I think the shallow LED bars blend into the black bumper well and are not that much "in your face". They only replace the two hella 4000 HID and two 2000 cornering lights that used to be on the bumper (see my profile pic). One more bonus is less restricted airflow to the radiator.
LEDs are used a lot offroad now, but they donīt quite get the distance of good HIDs yet. Therefore LEDs on the bumper, but HIDs up top...
Old 05-14-2013, 10:44 AM   #6
wraprail
wraprail's Avatar
Nice truck.
Thanks for the info.
Old 05-14-2013, 02:25 PM   #7
K20chevy
K20chevy's Avatar
Nice truck.
Thanks!
Old 05-14-2013, 05:52 PM   #8
78gmc1
78gmc1's Avatar
Cool Setup.. I plan to Get some LED's For mine once i start getting it back together what kind of headlights are those?
78gmc1 is offline   Reply With Quote
Old 05-15-2013, 11:01 AM   #9
Jeepwm69
I have a set of Daylighters on my Jeep. Swapped in some VVME HID's from ebay ($50), mounted the ballasts under the front crossmember. The H3 bulbs in a Daylighter take an HID bulb just fine. Might be tough to find a place to mount the ballasts up there where they wouldn't be visible though.
Jeepwm69 is offline   Reply With Quote
Old 05-15-2013, 11:28 AM   #10
K20chevy
K20chevy's Avatar
these are 90mm hella bi xenon mudules in the ECE (european) version. So true factory HIDīs with high and low in one light. perfect sharp cut off and great light output. And since it is mandatory in europe on hid lights and makes sense anywhere else, these have an ultrasonic leveling system. So when you accelerate or load the truck, the lights adjust down to not blind traffic, when you hit the brakes hard, they adjust up so you can still see where you are going. so they always stay leveled and never blind oncoming traffic...
Not cheap though!
(Rolls Royce Phantom uses the same headlights)
Old 05-15-2013, 11:30 AM   #11
K20chevy
K20chevy's Avatar
true, better than the halogens in there, but nothing beats a HID light that was made to be hid. I had two Hella 4000 HID lights on the bumper before and 5 more on a removable bar behind the cab. Iīve seen HID converted hella 4000īs and they were impressive, but compared to the real thing - BIG DIFFERENCE in light quality and spread. But sure, all of this comes at a price...
Old 05-15-2013, 03:59 PM   #12
Jeepwm69
Daylighters were probably 20 years old, came on the Jeep. Looked like a flashlight with weak batteries shining through a beer filled glass.
HID's wer $47 shipped.
Wired them in through a Bosch relay to a mini toggle switch. They're bright, and the price was definitely bright.
True, they work better in HID specific housings, but I only run them off road, and they're better than the old Halogen headlights!
Old 05-16-2013, 01:34 AM   #13
K20chevy
K20chevy's Avatar
Anything is brighter than the stock halogen headlights! Iīm sure the HID kit made a huge difference. Optilux has some fairly cheap HID (true HID) lights as well in 4" and 6 or 7". They are "only" $140 a piece. Their light output is decent for the price they come at.
but sure nothing beats lights that were free on the vehicle anyways!
I drive a lot at night, that is why I want it very bright!
Old 05-16-2013, 02:58 AM   #14
andrewmp6
K20chevy where you get that front bumper tho?
Old 05-16-2013, 03:02 AM   #15
K20chevy
K20chevy's Avatar
it is a GMTC (GM Truck Center) Bumper that has been modified though. the pull points are different from their original design and the light holes, light tabs, smothed welds were done by myself. The powdercoating was custom too by a local guy here (it is semi gloss black).
Old 05-16-2013, 06:33 AM   #16
andrewmp6
I never heard of them but your bumper looks good.
Old 05-16-2013, 04:48 PM   #17
K20chevy
K20chevy's Avatar
Thanks!
Old 12-03-2013, 02:30 PM   #18
K20chevy
K20chevy's Avatar
I might actually sell the OnX and replace it with some RAllye 4000 LED/HID or Rallye compact LED/HID Hellas. The LED bars just donīt have enough distance for my taste....
I was hoping to get used to the short distance of the OnX as the spread is awesome, but I just miss the overall light output of my big HIDīs. So 4 or 5 of them are going back on the roof and on the bumper I might add some compacts...
Old 12-13-2013, 04:12 PM   #19
Jeepwm69
$45-50 VVME HID's in old Daylighter housings.....
Old 12-16-2013, 02:19 PM   #20
K20chevy
K20chevy's Avatar
Howīs the light output? Better or did the focal length of the hid bulb change so much that the beam pattern is way off??
Old 12-16-2013, 02:27 PM   #21
K20chevy
K20chevy's Avatar
I did play around with MS paint for a while... I think this could be the future light setup.
What do you guys think?
Old 12-27-2013, 04:51 PM   #22
Jeepwm69
They are bright enough to drown out my stock headlights (run through relays). With the HID's on I can't tell whether or not my headlights are on.
They are a bit too focused. I would prefer a shorter range/ wider beam.
Old 12-28-2013, 03:05 PM   #23
K20chevy
K20chevy's Avatar
canīt you run a diffused lense on one of them? I know in Australia they do that, run one focused pencil beam and one driving/flood beam, to get the best of both worlds. Donīt they make a lense like that for the lights you used?
Iīm pretty sure that would do the trick!
Old 01-03-2014, 12:41 PM   #24
K20chevy
K20chevy's Avatar
So I did some more renderings in MS paint. I have no idea how to start a vote thing for the different options... if someone knows, please let me know...
But here they are. What do you guys like the best?
#1 (current LED setup plus 2x Hella Rallye 4000 Compact Xenon pencil beam)
#2 (current LED setup plus 2x Hella Rallye 4000 Xenon Euro Beam)
#3 (2x BD Squadron wide cornering + 2x Hella Rallye 4000 Xenon Euro beam)
#4 (2x BD Squadron wide cornering + 2x Hella Rallye 4000 Compact Xenon driving beam + 2x Hella Rallye 4000 Compact Xenon pencil beam)
#5 (2x BD Squadron wide cornering + 2x Hella Rallye 4000 Xenon euro beam + 2x Hella Rallye 4000 Compact Xenon pencil beam)
#6 (2x BD Squadron wide cornering + 2x Hella Rallye 4000 Xenon euro beam + 2x Hella Rallye 4000 Xenon pencil beam)
#7 (2x HIDDEN BD Squadron wide cornering + 2x Hella Rallye 4000 Xenon euro beam + 2x Hella Rallye 4000 Compact Xenon pencil beam)
#8 (2x HIDDEN BD Squadron wide cornering + 2x Hella Rallye 4000 Xenon euro beam + 2x Hella Rallye 4000 Xenon pencil beam)
#9 (2x BD Squadron wide cornering + 2x Hella Rallye 4000 Compact Xenon driving beam + 2x Hella Rallye 4000 Compact Xenon pencil beam)
Old 01-03-2014, 03:41 PM   #25
Jeepwm69
I thought the reflector in the back of the housing was what directed the light, but I can see how a different lens could diffuse the beam and flood it.
These are ancient KC daylighter housings. I'll have to see what I can find.
I like #1. The pics with 4 round lights make the front of the truck look cluttered to me.
I'm weird and OCD though, so I'd go with what you prefer. YOUR truck!
