03-29-2013, 02:58 AM | #1 |
Small block short water pump A/C brackets, complete, blasted primed and painted
My latest build had an aftermarket under dash A/C system, but utilized a stock axial A/C compressor under the hood. I have decided to clean things up under the dash and install a modern aftermarket A/C system.
$100 shipped to the lower 48 for all brackets, bolts, mounting hardware, even a new belt!) with the exception of the compressor. It turns over and is not locked up, but I do not know the condition. I will sell it as well, but it is heavy and the shipping cost would probably be a deal killer. I also have the old aftermarket in cab under dash A/C evaporator and the condenser, but no photos at this time. Contact me if you are interested in theses as well. Basically I have all components needed for a complete AC system with the exception of hoses. The truck did not have crimped lines. It had hose clamps on the connections. Rats chewed up the rubber hoses. I believe I have a set of 72 small block a/c hoses if needed. I haven't removed the brackets yet, but here are a few photos of it installed. |
03-29-2013, 03:17 AM | #2 |
Re: Small block short water pump A/C brackets, complete, blasted primed and painted
Are the valve covers and water neck powder coated? is that a performer intake? Are you gonna have a stove and pipe? also...interested in ac brackets.
03-29-2013, 03:22 AM | #3 |
How much for the 72 AC hoses >?? got any pics? thanks
03-29-2013, 07:42 AM | #4 | |
Posted via Mobile Device |
03-29-2013, 07:43 AM | #5 |
03-29-2013, 09:38 AM | #6 |
Thanks..It looks like your doin the same color scheme as me. I was wondering if the stove pipe wood still reach the breather with a performer intake. I thought the height of the intake wood affect it.
Have you allready painted AC brackets? I am goin to powdercoat the ones I buy gloss black. You need to buy some stuff from me so I can have a lil play money in paypal. thanks..I want to see more of your engine bay pics as you progress. |
03-31-2013, 08:57 PM | #7 |
Brackets are painted.
03-31-2013, 09:17 PM | #8 |
Do you have any loose AC brackets? I dont need a full set.
03-31-2013, 09:19 PM | #9 |
04-02-2013, 11:37 PM | #10 |
what is the very best you can do on the AC bracket set? I would be a buyer at 80.00 shipped, minus the compressor..
thanks |
04-02-2013, 11:50 PM | #11 |
Could you split it with me at $90 shipped?
04-03-2013, 12:24 AM | #12 |
04-03-2013, 12:37 AM | #13 |
Deal! Pm sent
04-03-2013, 06:42 PM | #14 |
Thanks but I am going to pass on AC brackets
04-05-2013, 11:11 PM | #15 |
looking for power steering bracket if you have one, sbc swp
04-06-2013, 12:26 AM | #16 |
Sorry, no
05-02-2013, 10:38 PM | #17 |
Ttt
05-12-2013, 01:15 PM | #18 |
Ttt
05-12-2013, 06:36 PM | #19 |
I only need this bracket
Perhaps Darren and I can split the set.
05-13-2013, 12:54 AM | #20 |
Sorry BigDav ,I have all I need, except for a correct heat stove..
06-10-2013, 03:02 PM | #21 |
ttt
06-23-2013, 02:09 AM | #22 |
The brackets have been removed. I taped the bolts to the holes where they came out in order to make installation easier. $100 SHIPPED to lower 48 for brackets. I will include the compressor for another $50 shipped.
06-23-2013, 04:43 AM | #23 |
Will this setup work with heads without accessory holes?
06-23-2013, 10:03 AM | #24 | |
06-23-2013, 10:07 AM | #25 |
Correction: one bracket (for compressor rear) uses two intake boltsand another bracket (compressor front) uses another intake bolt, but none into front of head. I am sure someone else can confirm this as well (Darren magoo?)
