Old 04-04-2013, 09:36 PM   #1
bobshotrodblazer
BigBlockBobby
Working on a 71 swb
Doing a complete frame off on this 1971 leaf spring rear swb C/10
I've been doing these trucks as a hobby over 30 years now and I still enjoy it.
Bob
bobshotrodblazer is offline   Reply With Quote
Old 04-04-2013, 09:48 PM   #2
bobshotrodblazer
BigBlockBobby
Re: Working on a 71 swb
More pics
sandblast frame and paint chassis black
Rebuilt all brakes ,bushings ,balljoints,etc.
New ss brake lines and fuel line
Bob
Old 04-04-2013, 10:01 PM   #3
bobshotrodblazer
BigBlockBobby
More
New Eaton posi unit with 373 gears
BB springs
2 1/2" drop spindles\2" drop shackles in rear
5" drop leaf springs
Bob
Old 04-05-2013, 12:58 PM   #4
bobshotrodblazer
BigBlockBobby
continuing
Install nice 427 Big Block with a built 700r4
all Alan Grove brackets for v belt accessories
y pipes welded in for future electric cutouts
Bob
Old 04-05-2013, 03:32 PM   #5
bobshotrodblazer
BigBlockBobby
more pictures of progress
Tranny cooler and gas tank installed
Bob
Old 04-06-2013, 02:35 PM   #6
67cheby
67cheby
67cheby's Avatar
looking good !
67cheby is offline   Reply With Quote
Old 04-07-2013, 09:21 PM   #7
bobshotrodblazer
BigBlockBobby
Some of my other builds
Bob
Old 04-25-2013, 05:19 PM   #8
bobshotrodblazer
BigBlockBobby
Installed new 4 " lowered leaf springs in rear with 2" lowered shackles for a total of 6 " in the rear
Cut full coil out of new front BB springs along with 2 1/2 "drop spindle gives a total of 4 1/2" in front .Pretty sure I will cut more out of front spring but Im going to wait until I drive it .Set the bed on to cut hole for fuel neck .Going to use a blazer neck turned in and cover with stock blazer cover.
Bob
Old 04-25-2013, 05:47 PM   #9
lolife99
67-72 parts collector,…
lolife99's Avatar
You do NICE work!!!
Keith
Convert to disc brakes.
Old 04-25-2013, 09:05 PM   #10
bobshotrodblazer
BigBlockBobby
thanks
heres another
Bob
Old 04-25-2013, 10:35 PM   #11
thelonerife
thelonerife's Avatar
Love the 4x4
thelonerife is offline   Reply With Quote
Old 04-28-2013, 01:32 PM   #12
bobshotrodblazer
BigBlockBobby
Got the beast outside today on its own power and new brakes. Put the bad cab on just to test every thing out the new cab fab is next. Check out my temp. battery box on the fire wall and core support(pc.of 2x4)
Bob
Old 04-28-2013, 01:43 PM   #13
CG
BlahBlahBlah
Well I guess you know what you are doing (lol). Nice work so far and a bunch of nice trucks you've already done.
This is a very lucky 71 to have found you =)
Old 05-01-2013, 03:03 PM   #14
bobshotrodblazer
BigBlockBobby
Started work On this other cab I picked up. The fire wall is already smoothed back to one piece (no lip)
Cutting out the existing dash and installing a a/c dash
It needs new outer rockers and a little kick panel floor work .other the that it's pretty sweet.
Bob
Old 05-17-2013, 02:07 PM   #15
bobshotrodblazer
BigBlockBobby
Finished gas fill. Had to weld up S pipe to around behind leaf spring shackle. Used a Marine fill cap on an old blazer cover
Bob
Old 05-17-2013, 05:33 PM   #16
bobshotrodblazer
BigBlockBobby
Cut drivers side rocker out . I never seen so many spot welds on one little piece.Must have been 40.
Test fit new rocker.
Weld up cab gas fill.
repair floor where po cutout too much for my removable cover i'm going to use
Bob
Old 06-01-2013, 09:03 PM   #17
bobshotrodblazer
BigBlockBobby
patching the dash today
Bob
Old 06-18-2013, 05:51 PM   #18
bobshotrodblazer
BigBlockBobby
dash welded in over the weekend
Bob
Old 06-18-2013, 05:52 PM   #19
bobshotrodblazer
BigBlockBobby
new wheel tubes and rubber floor mat installed
Bob
Old 06-18-2013, 05:56 PM   #20
bobshotrodblazer
BigBlockBobby
All my front end parts waiting to be installed
Bob
Old 07-25-2013, 09:27 AM   #21
bobshotrodblazer
BigBlockBobby
Installed my Lokar shifter .Bolts right to the back of the tranny. Works sweet.
Bob
Old 07-25-2013, 09:36 AM   #22
bobshotrodblazer
BigBlockBobby
Finished stripping old surface rust and old primer off my cab. Hit it with new etching primer. Next I will lay it on it's back and do the bottom which is structurally good just needs striping and paint.
Bob
Old 08-24-2013, 10:23 PM   #23
bobshotrodblazer
BigBlockBobby
fitting and adjusting sheet metal today
Bob
Old 08-26-2013, 12:41 AM   #24
Hardesty454
Hardesty454's Avatar
Awesome build. I like your previous projects as well!
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 08-31-2013, 05:27 PM   #25
bobshotrodblazer
BigBlockBobby
Setting up and adjusting sheet metal
Bob
