Old 04-06-2013, 09:52 PM   #1
hatred
hatred's Avatar
Mid 80's steering wheel install
Took the cheap Grant knock-off wheel off today and got a wheel from a mid 80-90 truck. Whats needed to get this on? It doesn't seem to want to slide onto the shaft.
05 QSM GTO - M6, Corsa, King Springs
70 SWB CST - 350/Auto, Foose 18/17
I upset whiners too....
hatred is offline   Reply With Quote
Old 04-07-2013, 12:26 AM   #2
kcsa75
kcsa75's Avatar
Re: Mid 80's steering wheel install
It should slide right on. Do you have photos? That might make it easier to diagnose the problem.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 04-07-2013, 12:59 AM   #3
hatred
hatred's Avatar
Ill take pics in the am when I start on it again. It seems like the new wheel is bottoming out on the column and not sliding onto the shaft.
Old 04-07-2013, 01:12 AM   #4
FirstOwner69
FirstOwner69's Avatar
Is your wheel like the one in the pic below (probably without the leather wrap)? Does yours engage the splines on the steering shaft at all? Or, does it engage the splines and just have a gap between the wheel hub and column?
FirstOwner69 is offline   Reply With Quote
Old 04-07-2013, 01:45 AM   #5
hatred
hatred's Avatar
Looks identic to that one. It feels like the shaft is too big, and it may also be hitting the housing on the column. Ill take pics of it sitting on the end of the column and all the parts I have. Never had this happen before.
Old 04-07-2013, 09:52 AM   #6
I put one in my '71 tow truck and it slid right on...and off. Does anyone have the nut that holds the wheel on? That may help and be a tad safer,ya think?
Old 04-07-2013, 03:37 PM   #7
hatred
hatred's Avatar
K, I took some pics today...
This is the new wheel on the shaft. The shaft is flush with the end of the splined part
[IMG] Uploaded with ImageShack.us[/IMG]
As you can see, its hitting the column housing (still flush as in the pic above)
This is all that came off (wheel, horn cap, horn wire) the donor truck.
This is what I took out of my truck...
I put one of these wheels in my old 67 C10 about 20 years ago, and I thought it basically slid right on and fit... Am I missing something here???
Old 04-07-2013, 03:38 PM   #8
hatred
hatred's Avatar
If I figure this crap out, I'll send you one of these that I don't use (provided they're the same)
Old 04-07-2013, 04:54 PM   #9
FirstOwner69
Something is not normal. Shoot a picture of the underhood end of the column. It looks like the shaft may be positioned too far forward in the column somehow. Not sure if that's even possible.
Old 04-07-2013, 05:02 PM   #10
WIDESIDE72
WIDESIDE72's Avatar
I would be interested I. The old wheel and installation kit you took off if you decide to part with it
WIDESIDE72 is offline   Reply With Quote
Old 04-07-2013, 05:03 PM   #11
WIDESIDE72
WIDESIDE72's Avatar
Sorry I don't have any advice on the install. I had a wheel of a mid 80's s10 on my72 for a while and it fit fine. I've never tried to install a wheel like yours on a 67-72.
Old 04-07-2013, 05:06 PM   #12
hatred
hatred's Avatar
Its put back together with the old wheel cause I had to move it. The shaft was pushed down some, but even when I pulled it up some it hit the column housing before I could get the nut started.
Old 04-07-2013, 08:38 PM   #13
wgr2112
When swapping steering wheels on my 72, there seemed to be a lot of in and out movement of the shaft itself.
When I first put it on, it would barely engage the threads. I pulled up on the shaft and got a little more meat. It came up the rest of the way as I tightened the shaft nut.
If everything lines up properly, it should slide right on.
Not sure if the horn button will work or not without a little modification.
wgr2112 is offline   Reply With Quote
Old 04-07-2013, 08:47 PM   #14
chiefcfd
chiefcfd's Avatar
Looks like the shaft has slid down out of the column. Probably lower bearing has come loose under the hood.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 04-07-2013, 10:54 PM   #15
JOJABOY
need photo of end of your steering column with no wheel installed. sounds like your turn signal cancel cam is hitting the bottom of your steering wheel. you said you pulled the shaft up right? what cancel cam do you have on there?
i installed same wheel on my 69 and had to modify the horn spring a little (nothing crazy) but all works very well.
JOJABOY is offline   Reply With Quote
Old 04-07-2013, 11:31 PM   #16
hatred
hatred's Avatar
Ill work on trying to take it apart again tomorrow for more pics. The cancel cam im not sure about. ..
Old 04-07-2013, 11:36 PM   #17
JOJABOY
The cancel cam for that steering wheel is convexed. Meaning it bumps up. You need to run the cancel cam for a 1972 steering column. You will need the spring and bushing from the mid 80's steering wheel. and will need to wedge it in the tube thing for the horn to work. Super easy to do and can explain better later.
But I ran into the same thing with mine when I was figuring it out. If you have the wrong cancel cam on the shaft...the steering wheel won't go all the way on.
Old 04-07-2013, 11:37 PM   #18
JOJABOY
http://67-72chevytrucks.com/vboard/s...d.php?t=559128
This is from when I went through the pains of figuring it out.
Old 04-08-2013, 10:08 PM   #19
hatred
hatred's Avatar
Swung by the pull-a-part and took a pic of the column I got the steering wheel off of. It's a 91 chevy with a tilt column. I only had a steering wheel puller so I couldnt get anything else off. Think I might try and get the signal cam for a 91 and see if it works.
Old 04-08-2013, 10:12 PM   #20
JOJABOY
lol....pick of your column please.
Old 04-08-2013, 10:34 PM   #21
knomadd
knomadd's Avatar
[IMG][/IMG]
There's more to it than the cancel cam. The cam wouldn't make the steering wheel sit flush with the end of the shaft AND touch the turn signal lever. If it was the cam, you'd have a mile wide gap between the column and the wheel. With the wheel hitting the turn signal lever, you obviously have no more room to push the wheel onto the column. The cancel cam won't give you more room for that. Your steering shaft is too far into the column for that wheel. I don't know if the newer style wheel is supposed to fit as I've never installed one of them before, but the steering shaft in your column isn't long enough for that wheel.
I'd suggest looking under your hood at the column to see if there are any issues down there like FirstOwner69 and chiefcfd suggested.
Good luck.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 04-08-2013, 10:40 PM   #22
JOJABOY
I am thinking the column shaft it pushed in too far. Was hoping he could take a photo of the end of his column so we could see and possibly help him out.
Old 04-08-2013, 10:47 PM   #23
FirstOwner69
I don't know if you have the right cam or not. However, in the pictures you posted it looks like the wheel is in contact with the top of the column and the shaft still isn't protruding beyond the wheel hub. The wheel has to have some space between the hub and column or it won't turn. As a couple of us have already said, it appears your shaft is not protruding enough from your column.
We NEED A PICTURE of what the column looks like under the hood without a steering wheel mounted.
I had the same wheel on my 69 with the same column, and the cam and everything else were the original to the truck. Here's a pic.
Edit: I see knomadd and JOJABOY beat me to this!
Old 04-08-2013, 11:32 PM   #24
hatred
hatred's Avatar
I will take the wheel off tomorrow and take a pic of the column and under the hood. I know the shaft was pushed in some, but even after I managed to pull it back out the wheel wouldn't fit. With the cam it hit the column housing, and with the cam there wasnt enough threads on the shaft to get the nut started.
Old 04-09-2013, 12:10 AM   #25
FirstOwner69
Read this thread (http://67-72chevytrucks.com/vboard/s...d.php?t=471499) thoroughly before you look under the hood. Then compare what you see to what you read in that thread. Do you have the spring and washer at the bottom of the column? Is the bottom bearing properly seated into the bottom of the column and held there by the spring? I'm betting this is where you have a problem. I believe the spring holds the shaft in place where you need it.
Edit: I believe, when properly installed you should be able to slightly compress the spring by pushing on the steering wheel toward the front and it should be popped back toward the seat by the spring when released. You should not ever have to pull the shaft out to install the wheel.
