Old 04-15-2013, 11:34 AM   #1
theastronaut
theastronaut's Avatar
1966 F100 Short/Fleet Full Stock Resto Build Thread
I posted a few build threads before and had someone ask for me to post our newest build here. Our shop started a full restoration of a '66 F100 back to stock specs about a month ago. It was originally light tan and white two-tone. It's pretty straight, complete, and rust-free apart from the outer edges of the floors and radiator support. It had a 302 added at some point but the owner still has the original 352 and three speed transmission, the engine has been rebuilt already.
This a picture that the owner sent us. The bottom and top of the roof was light tan.
theastronaut is offline   Reply With Quote
Old 04-15-2013, 11:35 AM   #2
theastronaut
Re: 1966 F100 Short/Fleen Full Stock Resto Build Thread
Teardown pics.
Fiberglass patches in the floor and kick panel, not a good sign...
Found the original masking lines under the trim and behind the bed.
Front clip, bed, and doors removed.
Engine/trans removal.
Old 04-15-2013, 11:36 AM   #3
theastronaut
More teardown.
Cab stripped bare.
Rust in the floors.
Cab off, frame disassembled.
Old 04-15-2013, 11:37 AM   #4
theastronaut
We had the frame sandblasted and I shot it with a few coats of PPG DPLF epoxy, let it sit over the weekend and lightly wetsanded it with 500 grit to knock down the orange peel and nib the dust/trash.
Old 04-15-2013, 11:38 AM   #5
theastronaut
I sprayed the frame using PPG Omni MTK single stage urethane, flattened with 1/3rd PPG One Choice matting agent, and reduced 10%. Sprays very well and covered great since it was going over the black epoxy. Nibbing the Epoxy made the paint lay down much smoother- as you can see in the "wet paint" pics.
Straight out of the gun-
Starting to flatten out.
Old 04-15-2013, 11:48 AM   #6
MP&C
MP&C's Avatar
That was looking pretty solid until the f/g came out. Nice and straight too...
Robert
MP&C is offline   Reply With Quote
Old 04-15-2013, 01:50 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice progress!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 04-15-2013, 01:57 PM   #8
theastronaut
It's not in bad shape at all, although my perception of "bad shape" has changes since I started on the '55 International...
Originally Posted by 72BlckButy View Post
Nice progress!
Thanks!
Old 04-15-2013, 01:58 PM   #9
theastronaut
Got the cab and doors back from the blaster. There was more rust-thru than expected, and the passenger side door has some wrinkles right through the upper body line. I stripped out the seam sealer (it was too soft for the blaster to remove) and will be picking up a couple quarts of Ospho so it can sit in bare metal without flash rusting while we do the metalwork. All the metalwork and dent repair will be done before priming with epoxy. We will also re-blast the seams to fully clean them out before we shoot epoxy on it. I picked up a gallon of PPG DP74LF epoxy that is the same color as red oxide, which I believe was the original primer color.
The next step will be to repair the rust and fit the doors to the door openings. The bodylines will be matched up, the gaps will be evened out by welding 1/8" welding rods to the edges and grinding the gap even, and the doors will be reshaped to fit flush with the cab and fender. I make a feeler gauge the size that the gaps will be and grind the welding rod to fit the feeler gauge.
Old 04-15-2013, 01:59 PM   #10
theastronaut
Here is how the doors fit before removal. It will require a bit of work to make them fit flush with even gaps and body lines.
Passenger side:
Old 04-15-2013, 02:00 PM   #12
theastronaut
This is a '65 C10 that I restored (my first paint/restoratioin job), this is what the gaps and panel alignment will look like after we rework them.
Old 04-15-2013, 02:04 PM   #13
theastronaut
I found pictures of this 15K mile original paint truck which has the same color scheme. It show the dash painted white, tan column/wheel and gas tank, and the masking lines in the rear door jamb.
Old 04-15-2013, 02:05 PM   #14
theastronaut
Cut out the rear floor rust to get inside the floor brace. We'll blast and prime inside the brace before welding the floor pans back in. We didn't cut the front floors out yet since the new pans aren't here yet- didn't want to cut too much.
Blasted and primed the wheels and brake drums with PPG DPLF epoxy.
Cleaned out the drums, had new races installed, and had them turned.
Sandblasted the front suspension parts and pulled the bushings out. We are sending them out to have the king pins replaced and then we'll prime/paint them all separately.
Old 04-15-2013, 02:08 PM   #15
theastronaut
If anyone's interested, we have taken about 380 pics so far of the teardown. Most of it is just boring stuff for reference when we start reassembly but I know you guys are picture junkies!
Link to pics:
http://apicdn.viglink.com/api/click?...-thread-3.html
Old 04-15-2013, 02:09 PM   #16
67ChevyRedneck
67ChevyRedneck's Avatar
That's going to turn out great! Great work on the 65 too! Do you have an actual shop or is this something you do on the side at your home? If it's a shop I'd love to stop by some friday or so that I have off and check out your progress!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-15-2013, 02:23 PM   #17
theastronaut
Thanks! We have a shop- Anderson Auto Glass right off 28 bypass near Westside high school. The auto glass industry has changed for the worst (unless you are Safelite) so we have started doing more restoration work to keep us busy.
Old 04-17-2013, 02:22 PM   #18
theastronaut
The front drums are painted, cleaned, and bearings are packed and installed. I sprayed epoxy on the axle last night, then nibbed it and sprayed flattened single stage urethane on it after lunch today. I left the carrier in red oxide primer as the factory did. We're getting more of the pieces blasted so we can start reassembling the frame. I will get the rear brakes installed on the axle later today.
Picked up a bunch of parts yesterday at Early Ford V8 Sales in Easley SC.
Old 04-17-2013, 05:20 PM   #19
theastronaut
Had a hold-up with the brakes, it'll be Friday before Napa has the rear brake hardware (didn't order it all the first time)... I did get the lines and wheel cylinders installed. Anyone have a source for the vent bolts that hold the brake line distribution block?
Drums ready to install.
Old 04-18-2013, 03:06 AM   #20
plainred65
plainred65's Avatar
I'll definitely be tuned into this one!
plainred65 is offline   Reply With Quote
Old 04-18-2013, 03:16 PM   #21
theastronaut
Thanks!
Got the yoke and hardware for the carrier detailed today.
Old 04-25-2013, 09:35 PM   #22
cAlvis165
cAlvis165's Avatar
This is all looking really nice! Keep up the good work.
Chad
Success is not final, failure is not fatal: it is the courage to continue that counts. Winston Churchill
DD 2000 Chevy Suburban 4x4/5.3 Vortec/4L60E/4:10s, 18" Escalade rims, Electric fans
Project Dooley One-Ton 4x4 on 38.5s Corn-binder build
cAlvis165 is offline   Reply With Quote
Old 04-25-2013, 10:27 PM   #23
theastronaut
Chad
Thanks Chad!
Few more recent pics. Got the rear suspension parts blasted, epoxied with PPG DPLF, and painted. Those rear leaf and hanger bushings were a pain to remove! I'll shoot epoxy on the front suspension parts tomorrow. We bought a 110# soda blaster and a couple bags of soda (non abrasive) for blasting the 352. It was poorly repainted when it was rebuilt and we don't want to paint over the rattle can paint that's on it. We'll have single stage color matched so we can spray it with a hardened paint for better oil and gas resistance.
Epoxy:
Flattened single stage:
The I-beams were blasted, then new king pins and bushings were installed. They're prepped with PPG DX series Metal Cleaner and Metal Conditioner and ready for epoxy.
The manifolds were blasted and coated with Calyx manifold dressing.
Old 04-26-2013, 02:05 PM   #24
inovermyhead
Great attention to detail as always.
81 GMC C15 RC SWB 5.3L 4L80E project
inovermyhead is offline   Reply With Quote
Old 04-26-2013, 03:10 PM   #25
theastronaut
Thanks!
I picked up some "EZ-Slide" graphite based lubricant paint for the leaf springs, I found it at Tractor Supply. Should let the springs move easier so it rides better. Also picked up some model paint for the paint marking on the transmission.
Lightly washed the trans to document the paint dabs.
Yellow "6Y"
Orange along the edge.
This one showed faint traces of orange paint.
Outlined to see it better.
Another orange spot.
Blue spot.
Two yellow dabs.
Another yellow spot.
